Question about Microsoft Xbox 360 Console
Disk stuck Hello our 1 year old got Maddon 09 stuck above or below where you slide the disk in. Any help? Do we need to take the xbox apart?
    Problem Solver:
  • 16 Answers
Never ever take your xbox console apart since it will void the warranty. Best thing to do is to contact call support for xbox, they will either help you remove it or send you a box for you to send it to them. Their number is 1800-4-MYXBOX.
Posted on Mar 12, 2009
How to replace the electronic interior rear view mirrow on 2004 Envoy SLT. I have a new one to install and need to figure out how to remove the old one on the truck...
Hello lindleyjl,
1. You will need to disconnect the wire cove from the upper mirror base. (See image below)
2. Use a flat blade screw driver to disconnect the electrical connector from the mirror. Number 1 in the image.
3. Use a torx driver to loosen the set screw that holds the mirror base to the windshield button.
4. Slide the mirror upward off the the rear view mirror button; number 1 in the image below.
To install, reverse the above outlined procedure.
I hope this helps.
Regards,
netvan
Jul 24, 2011 | 2004 GMC Envoy
Why does my xbox 360 say open tray
This is a case of the disc not reading. The solution is to call Microsoft (1-800-4MYXBOX) and have them go through the trouble shooting steps, and if that does not work you will have to send the console in.
Apr 30, 2011 | Microsoft Xbox 360 Console
Disk reader is not working..xbox less than a year old
Hi there susanthomas4
What to do when your Xbox Has problems with reading disks and you have tried cleaning the disk.
This does not mean your Disk Drive needs replacing more often than not it just needs the laser to be readjusted.
Option 1
You can send this off to Microsoft if your still in warranty because it is included in there free fixes so they will do the collecting for you, fix it and return the Xbox to you, all for free, but it will take 4-6 weeks.
Option 2
If you are out of warranty its the same process as above but its $130 in cost
Option 3
now a new Disk drive would cost around $75 for a compatible one and you may need some one to fit it at a cost as well.
Option 4
What I recommend is a XBOX REPAIR GUIDE that will show you the simple steps yourself, you will be up and running again in less than an hour and the cost is far less than option 2 & 3
Good Luck
xboxrestore
Feel Free to leave me a comment if you need further assistance.
Nov 28, 2010 | Microsoft Xbox 360 Console
Hi my xbox 360 wont read some disks it just says 'open tray'
The lens is out of alignment so doesn't know where the start of the disk is. This means that you wiil get the "Open tray" message with each disk you place a disk in the drive.
If you have any warranty on the Xbox 360 then i recommend that you sent it back to Microsoft for adjustment.
If there is no warranty then what you could do is lay the Xbox on its side and repeatedly tap the top of the Xbox when you put a disk in to see if it will read.
If not then you will have to take the Xbox apart which is a difficult job, then take the CD/DVD drive out. Take that apart and adjust the lens unit yourself or take the console to a repair store.
Regards.
Jul 04, 2010 | Microsoft Xbox 360 Console
Xbox 360 disk read problems only on some games some of the time
jc take the console apart there are tutorials all over the place start with youtube
clean your drive if this does not help you might either need a new lazer or a new drive itself take it apart and check for yourself just remember if you open it your rrod warranty is kuput..so which is more important cod6
or 360
Oct 18, 2009 | Microsoft Xbox 360 Console
Maddon 09 froze is it possible for the PS3 to overheat and freeze up
HI, this is a hard disk issue. you would get a yellow light if the unit was overheating. contact Sony for this repair. the hard disk will need to be replaced.
Jul 13, 2009 | Sony Playstation 3 (PS3) Console
Nba live 09 disk unreadable
your disk is messed up ok u cant do anything about it but i know how to can get it fixed for about 5dollars rent the same game at blockbuster and see if that works then after that switch the games so u have the good 1 and they have the messed up one=)... 1 love =)
Apr 15, 2009 | Microsoft Xbox 360 Console
Fifa 09 xbox 360
DWGY-KGXP-4F43-G4F2-7RLD
HBX7-LEED-FETH-VFER-MRLD
5KVV-FXB9-A3FE-AA3D-JRLD
Hi. One of the above keys should work.
Mar 27, 2009 | Microsoft Xbox 360 Console
Xbox 360
get disc cleaner at ur local Game$top
Jan 20, 2008 | Microsoft Wireless Network Adapter Xbox...
2 disks stuck in one slot of DVD player
Looks like it will have to come apart. Can you see how? Usually the top/side casing is simply 5/6 screws 2 each side and 1/2 at the back then slide back away from the from panel. Technical help at Panasonic may be helpful.
Jul 02, 2007 | Panasonic SC-HT680 System
Microsoft Xbox 360 Console Logo
44 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
