Question about Rowenta Rs-dc0080 Vapor Tip
Need to replace the vapor tip on my rowenta IS8100 steamer
SOURCE: rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Posted on Oct 31, 2008
  • 6 Answers
SOURCE: i have rowenta is9100 steamer but water tank is broken how i can get new one ?
buy one if you have the money
Posted on Jan 09, 2012
SOURCE: Cap is stuck on Rowenta IS8100 water holder.
The stainless steel plug in the water station is stuck! I cannot unscrew it to rinse out the water station. Please HELP!
Posted on Jun 01, 2012
  • 36 Answers
SOURCE: Rowenta Pro Steamer only works 5 minutes then shuts off!
temp limit switch bad... replace iron(sorry)
Posted on Jul 04, 2012
Need Replacement Support Pole for Rowenta Commercial Steamer
According to eReplacementparts the DC0084 part you're looking for is not available for retail sale. They do however inform that that the part is avaiable for sale via Rowenta Service Centers. You can find a list of these Rowenta Service Repair Centers by state, here. I hope this helps & good luck!
Nov 07, 2013 | Rowenta Irons
Rowenta Commercial Garment Steamer - Silver Mod. IS8100
So is difficult to say. The best way is to take the electrical iron and see with the person, What can they do . Otherwise you must investigate in Internet if there are some catalogue or parts available with photo and take it , and get it as sample for the repair shop.
God bless you
Jan 25, 2013 | Irons
Jul 04, 2012 | Rowenta Irons
Sep 30, 2011 | Rowenta IS8100 Iron
I have the vertical commercial steamer model IS 8100. Machine lights up, no steam. The cord doesn't even get hot. I've tried to demineralize it by allowing vinegar to sit in the well of the base. Thanks...
My unit did the same thing. There is a temperature fuse attached to the heating chamber. If the unit overheats it will blow this fuse. It is not re-setable and must be replaced. Radio Shack carries these items.
Check your chamber for crude. Mine was pretty bad and I ended up filling it up with white vinegar over night. If you can get it to work, boil a solution of 1/4 white vinegar and DISTILLED water. Let it run through a whole tank of it and then run it with just DISTILLED water until you don't smell vinegar anymore. Do this every few months with heavy use.
Jan 10, 2011 | Rowenta IS8100 Iron
Lack of steam
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Feb 06, 2010 | Rowenta IS8100 Iron
Need replacement water tank due to a crack that leaks for the Rowenta 8050 steamer
krups bought out Rowenta. contact them at http://www.krupsusa.com/ to see if they have the parts or know where to get them
please take a moment to rate this solution. thanks
robert
Nov 23, 2009 | Rowenta Commercial Garment Steamer - White
IS8100 Commercial Steamer is leaking water
Try "cleaning it" with vinegar. It could be clogged with calcium carbonate. Replace the water with a potent solution of white vinegar and water and operate the unit until the vinegar solution is used up. I use 100% of the supermarket white vinegar and avoid breathing in the "steam." Repeat the procedure once or twice with plain water. If this works, let me know.
Dec 24, 2008 | Rowenta Commercial Garment Steamer - White
Rowenta Rs-dc0080 Vapor Tip Logo
154 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
