Question about Everbilt Locks & Locksmithing
How to remove door hinge with security locking feature
4 Suggested Answers
  • 135 Answers
SOURCE: model number mgr5775qdb. someone removed the oven
If there is a hole in the metal hinge near the base; put a nail in the hole to keep the hinge from closing until you get the door in place and then remove the nail.
Posted on Sep 03, 2009
airjer995
  • 5332 Answers
SOURCE: when I put the key in door to unlock it locks and
You either have a bad "arm/disarm" switch or the switch has fallen off from the lock cylinder.
What is happening is the security system is not receiving the disarm signal when you unlock the door with the key. It thinks the car is being stolen so it continues to lock the lock to prevent this.
There arm/disarm switch is clipped onto the door lock cylinders on the front doors and the rear hatch. If it does the same thing with the other doors than there may be an issue with the security system. If the other doors work fine than I would pull the door panel (I assume you are getting this problem with the drivers front door) and inspect the switch.
If you have any questions let me know.
Posted on Oct 14, 2011
claudeinmo
  • 9098 Answers
SOURCE: Why is it that after I removed the door I'm not able to get the hinges to hook so the door will stay secure it keeps falling out.RBS305PDS16
When you re-install the door, make sure it snaps in tightly; inspect the clutch connection.
Posted on Jul 14, 2015
When truck is idling sometimes doors lock 97yukon what can it be dont wanna get locked out
Either disconnect the auto lock security system or remove the power door lock fuse. Go W / the security disconnect .if it makes you uncomfortable. Its a standard feature w/ most security systems. Good Luck, Frank M.
Feb 21, 2016 | Cars & Trucks
I would like to reverse the door on my Zanussi ZDC68560W dryer
REVERSIBILITY OF THE DOOR
Proceed as follows:
    1.Remove the screws which secure the hinges to the cabinet (fig.A.1). Remove the door.
    2.Remove the screws which secure the hinge hole masking plates (fig.A-2) and fit the plates to the holes to which the hinges were previously fitted (fig.A-1).
    3.Remove the canister.
    4.Remove the work top.
    5.Remove the left- and right-hand panels.
    6.Remove the front panel hole cap (fig.A-4). To do so, squeeze together the anchor tabs which secure it to the cabinet.
    7.Remove the screws which secure the door interlock (fig.A-3) to the cabinet and remove the lock.
    8.Detach the connector from the door lock.
    9.Remove the tapes from the wiring (fig. B) and separate the wires for the door lock from the remaining wires.
    10.Re-tape the remaining wiring.
    11.Insert the general wiring harness into the support(s) positioned on the duct (fig. C) and position them parallel to the front panel so that they cannot come into contact with the drum. Attach to the anchor using a wire tie.
    12.Insert the door lock connector between the drum and the canister container, then remove it from the position shown by the arrow (fig.D-1).
    13.Insert it beneath the front brush cover (fig.D-2), secure to the anchors on the duct (fig.D-3), and remove the wiring from the other side of the cabinet.
    14.Insert the door lock connector and secure with screws to the front panel (fig.E-5). Ensure that the wiring is not trapped between the door lock and the front panel.
    15.Check that the wiring is routed through all the anchors released when removing the door lock wiring.
    16.The excess section of the door lock wiring should be secured using a wire tie to the wiring cover (fig.D-6). Fit the masking cap into the hole from which the door lock was removed (fig.E-4).
    Dado
25637655-hcssld2gpo2sm22yg24xoxcy-3-2.jpg 25637655-hcssld2gpo2sm22yg24xoxcy-3-5.jpg 25637655-hcssld2gpo2sm22yg24xoxcy-3-9.jpg
Apr 09, 2015 | Zanussi Dryers
How to open locked security toilet loock from outside
Look for a small hole or slot on or around the handle, Push a pin inside to unlock it.
Jul 24, 2014 | Amerock Hardware & Accessories
Remove oven door from hinges
the door is removed with the hinges in place. with the door open, lock the hinge sections together with the little clips on lowest hinge section. When locked, lift up on the door (not the handle) sides, swinging it up until it can be pulled out. Install in reverse order.
Feb 17, 2014 | Thermador Ovens
Kenmore oven door fails to lock
1. Remove the pan drawer
2. With someone holding glass up, remove the four screws at the bottom of the door that hold the glass front to the door frame. Gently lower the panel about two inches until the side guides are below the door trim cap. Place out of the way so it doesn't fall over etc.
3. Keeping the door closed, use a spring puller to remove each spring from the hinge. (I made one out of a hanger and a screwdriver. Double thickness at the hook, wrapped and secured around the screwdriver to make a handle) If you do things this way be VERY careful. Be sure it is really strong and is not going to slip. The springs are really under tension and will shrink down about an inch from where they are hooked. (Be sure to support the door so it does not fall open when the springs are removed. It will just make things worse.)
4. After the springs are off gently open the door all of the way.
5. Pull down the hinge locks from the oven body and lift the base of the door up. This will lift the door hinges off of the mounts in the oven frame and allow you to pull the door away from the body.
6. Place the door on your box or workbench etc
7. Remove the two screws on each side of the door that hold the hinges in place. Remove the hinges.
Reinstallation is in reverse.
Hinge repair.
By placing the lower part of the hinge (by the axle) against a ruler I was able to see that the upper section was bent out on each hinge. To correct it I placed the hinge over a pair of 4x4 blocks so that it curved up in the center, and hit it a few times with a hammer. The metal was very responsive and quickly bent back into shape. Be careful here as you don't want to bend them too far. I actually went a little past true, wanting to get a little more push at the top of the door. I placed the hinges directly on the oven to see the difference and they looked good (Be sure to put a piece of cardboard or rag between them and the top to keep them from scratching the surface.
Put the hinges back in the door, screw it together and hang it back on the stove, replace the springs and the glass, and check your fit. Good luck.
Feb 01, 2013 | Kenmore Ovens
I have preloaded the replacement hinge, but it appears that to remove the old hinge it must be unloaded. If that is true, how do you load the new hinge while it is on the door?
Ovens come in many varieties including freestanding units and stacked models that are inserted into a wall. Kitchen oven units that get a lot of use or are getting old may have problems develop, such as a loose or squeaky door which may require replacing the hinges. You can replace the hinges on the door to your oven by first removing the door from the rest of the oven.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderate Instructions Things You'll Need:
  • Screwdriver
  1. Step 1 Open the oven door and examine the hinges to see how the they are secured to the door. Some oven doors slide into the hinge assembly or have a locking mechanism that secures the door to a latch on the main unit.
  2. Step 2 Remove the door from the oven by disengaging the locking mechanism and then pull the oven door out. You may need to release a catch on the door or remove a pin from a hole in the hinge.
  3. Step 3 Place the door on a flat surface such as a table or the floor.
  4. Step 4 Remove the screws that hold the sections of the door together to access the hinges.
  5. Step 5 Remove the hinges from the door. The hinges may be attached to the door with screws or they may be held in place when the door sections are tightened or secured.
  6. Step 6 Insert the new hinges into the door and secure them with the screwdriver or place the section of door back on. Tighten all of the screws securing the sections together.
  7. Step 7 Place the oven door back into place by sliding it on the same way that it came off.
Regards
Iversh
Jul 24, 2010 | Ovens
Fit a new door hinge
Remove the wire clamp securing rubber seal to front of washer, pull seal of front of washer, this will give you clear access to tjhe door hinge, ondo the 2 screws securing the door hinge, remove door ,and seperate the 2 door halves by removing the screws securing it together
Replace with new hinge, fit back in reverse order.
Please rate my solution.
Thanks.
Nov 12, 2009 | Creda W120VW Front Load Washer
My Amana gas range's oven door will not stay shut. It is not snug against the oven. Repair says I need new hinges. Are they easy to replace?
they're not too bad, you may need to take apart part of the door to remove the hinges, just remember where everything goes as you take it apart. bring the door to the first stop, then bring the hinge pin locks into place to secure the door hinge lock, then remove door, or just slide the door up. then replace the hinges as needed.
Jul 09, 2009 | Amana ACF3355AS Gas Kitchen Range
Can you change the way the door opens on the neptune washer
Yes you can reverse the door on your washer.
Open the door, remove the screw in the middle of both hinges, (carefull not to drop them inside). Lift the door straight up and "wiggle" the door hinge straight out of the slot.
On the opposite side of the opening you will find two inserts, remove them and install them into the slots you removed the door from. Now the fun part... remove the hinges from your door side.
Make sure you note how they attach, now intall them on the other side of the door,EXACTLY, the way they were first installed. Do one at at time. After you have them on the other side and you put the other screws back in the side you removed the hinge from, lift the door and slide the hinge into the bottom and top slots of the washer opening. Secure the hinge with screws removed in the beginning making sure the door is closing properly and locking.
Apr 10, 2009 | Maytag Neptune MAH6500A Front Load Washer
Thermador oven (c301u) door hinges weak, how to install new hinge
This is a relatively easy fix however you will need to remove the door and it is heavy!
Start by opening the door completely and engage the small "locks" that are at the base of the hinge. This will ensure that the spring loaded hinges do not "spring open" when you remove the door. You then will need to remove the hinges from the door via a series of phillips head screws that hold the hinge assembly in place. The new hinges must be "preloaded" into the Open position using a vise or some means of holding the hinge in place while you use a small section of pipe to provide leverage needed to open the hinge so that the Locks can be engaged.
Once the new hinges are "pre-loaded" and the locks are engaged, you can reverse the procedure to re-install the hinges into the door and re-install the door.
Good luck!!
The hinges are commercially avaialble from Applianceparts.com
Jan 18, 2009 | Thermador C301U Electric Single Oven
Locks & Locksmithing Logo
288 people viewed this question
Top Everbilt Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you an Everbilt Lock and Locksmithing Expert? Answer questions, earn points and help others
