Question about Electric Mobility Pride Electric Wheelchair Powerchair Scooter Parts
My prider model 2904-24l won't start. The turn signals and horns work, and it says the battery has a good charge.
3 Suggested Answers
gewiz
  • 1263 Answers
SOURCE: 230 chauffeur doesn't charge. Batteries new and
hi, ok you mentioned nothing about the charger, is it built in ? or stand alone charger, can you try another charger ??
If you have a Electrical meter tester check that the charging socket pins do actually connect to the batteries if not check the charging socket,
of the three charging pins two are the positive & negative so should show 24 volts the odd one out the one in the middle just below the other two is the inhibit , that is normally grounded otherwords negative.
Sound like a loose connection so please check all connections if you are sure the charger is ok.
Regards
GeWiz.
Posted on Dec 31, 2009
SOURCE: scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Posted on Aug 10, 2012
Start button won't ignight
Do you have power on the bike, do the lights work, horn work, does the battery have a good charge.
Jun 07, 2013 | Triumph Motorcycles
2000 VW golf horn won't work, fuse is good , relay 53 is good but changed it anyway. No voltage reading at horns. Tested horn off car and it is fine
Did you check the power to the relay? and then the signal wire (ground) at the relay to see if it's being signaled? Otherwise you may have a clockspring or module problem not allowing the signal to pass through to the relay.
Dec 15, 2012 | 2000 Volkswagen Golf
Horn doesn't work, revrese lights won't come on, and 2 of the 3 break lights won't come on on 1995 Geo Tracker. Fuses are good and bulbs are good.
for how long, 1 day, 1 year , 1 decade? is it a daily driver
or a barn stored, winter car.?
the real question,is there 12v exiting the fuse, the acid test. that.
any volt meter does that in 5min flat.
3rd brake light is bad bulb or corroded socket.
what tranny< 3,4,5,sp.? but in each case it takes a good rev.
switch, if 12v enters said switch and does not exit, its bad.
0v bad,6v rev. path shorted to ground,12v good.
btw, all clamps can short, try 1 new one. in each path all by lonesome. dig?
bulbs good means what.
1: look good.
2: glow when placed on a 12v battery
3:measure 0 ohms with meter (means good or shorted.
4: or they are new and assumed good, (p/n ? what is the p/n?)
head lamps good.? parking lamps, blinker, are all other lamps working. does car start?
Dec 05, 2012 | 1995 Geo Tracker
Have a1993HondaShadow Stopped at storean won't start,nothinf will work.Lights horn Etc.
First check the main fuse, then battery connections,then check battery for voltage,ignition switch. If your battery went dead you need to check the charging system.
Oct 26, 2012 | Motorcycles
No turn signal, hatch won't release, no horn, fuse ok
Are you sure you don't have a low battery? have it tested first then check for other problems if the battery tests ok.
Sep 03, 2012 | 1996 Chevrolet Blazer
02 Mean Streak has no power
It sounds like a power "chip" that controls a set numbers of switches.
Jul 25, 2012 | kawasaki VN 1500 Vulcan Meanstreak...
2007 grand prix won't start but lights and horn work
Your battery is to low on power it needs a good charge, or replace it is the best option for a brand new one!
Feb 27, 2012 | 2007 Pontiac Grand Prix
Bike won't start, starter soliniod clicks but starter won't roll over, it will hum and not turn over.
Those are the typical symptoms of a weak battery. Try either to charge the battery, try a jump start or replace the battery. Lights or horn working do not give an indication of the battery charge status.
Jun 13, 2011 | 1984 Yamaha XJ 400
Electric Mobility Pride Electric Wheelchair Powerchair Scooter Parts Logo
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
