Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
AV-56WP74 My AV-56WP74 has been repaired twice for the same problem under extended warranty - I have no bill/invoice that show me which parts were replaced but I my problem is that when I turn it on, I hear the "heartbeat" sound for several seconds, then nothing. The power light blinks on/off but no picture or sound otherwise. The last repairman told me he replaced with more heat resistant parts and replaced "both" of them - that was 2 years ago and he's no longer in business or has moved. I just spoke with the first repairman who worked on it and he says it could be the power supply overloaded by the IC components but they wouldn't know until they look at it $425 if it's the IC parts plus another $75 for the service call. Please help me diagnose so I can either buy the part or the service manual from servicemanuals. I'm not sure what I need to buy because I'm not sure what is actually causing the problem.
  • stephanie7 Mar 23, 2009
    Is there a schematic or service manual I can get as well?
  • JVC Master
  • 3,459 Answers
Could be shorted convergence chips. There are two of them in the TV. If they short they will shut the TV down. One quick test is to desolder both of them...then power the TV on..if it fires up the chips were shorted and would need to be replaced. You can get a complete kit from www.TvRepairKits.com
Posted on Mar 21, 2009
AV-56WP74 the convergence is off. blue is way out!
You will need to replace the Convergence ICs and resistors you can get the JVC repair kit called the AV48WP74-65WP74 convergence repair kit from www.tvrepairworld.com which contains the ICs , resistors and the CD with instructions,
Sep 23, 2010 | JVC AV-56WP74 56" Rear Projection...
Sony bravia kdl52xbr2 problem
hi,hoping that the cable connections are right(check the cable connections once again)..... Sounds like you may have a problem with the video driver boards? I would call up the store where you bought it and ask for a new set or service on this one.
More than likely this is a bad display (lcd screen) the drivers in the lcd display have some problem...... the tv is just a month old so you are still under the warranty period....... just contact the sony outluet where you purchased or the manufacturer for servicing of tv
Oct 24, 2007 | Sony BRAVIA KDL52XBR2 Television
I need help calling someone that can repair an LG AC that has a bad compreser under warranty
Get prepared by going to outdoor section and record model plus serial
number. Get installer invoice or bill of sale from retailer to establish start-up date. If installer or retailer now not in business, go to LG
website and acquire local distrubtor/service contractor number.
Please note any licensed contractor can replace compressor no charge
if all warranty conditions met, but may have to charge for labour if not
covered under warranty.
Aug 04, 2009 | LG Heating & Cooling
Just took 2001 Jeep Grand Cherokee in to dealer because of Tranny. Found metal shavings, and they said it will need to be replaced. It is still under the premium extended warranty we purchased through...
If your car is covered by a premium extended warranty, then it is covered. Many dealerships have told their clients in the past that some repairs are not covered by their warranty and charged them for the repairs, while billing the manufacturer for the parts and labor that were covered in the first place. This way the dealer gets paid twice, by the car owner, and by the manufacturer. And in many cases, the parts that are needed for the repairs are obtained free by the dealer since they are covered under warranty. Read your warranty, post it here if necessary, and if they dealer tells you that your repairs are not covered then ask them why, and to prove it to you in writing so you can contact the manufacturer, or even Chrysler itself, and verify. This will make them understand that they can't just bill you for stuff you should be covered already.
Jul 26, 2009 | 1995 Jeep Grand Cherokee
Store closed. Warranty paid. Need repairs
The warranty company is the only one that would extend it. This happens alot. Is the warranty thru another company? Like GE? My advise is to call the warranty company and see if they can help. Otherwise the extended warranty is no good.
May 13, 2009 | Maytag Kitchen Ranges
Blue lines
Hi, convergence amps have failed, your going to need a tech for that repair, involves un--soldering and re-installing parts as well as an alignment, hope this helps, video-tek
Feb 11, 2009 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74
there are two i.c chiyou have to replace they have to do with the conversion go to electronix.com you can both for 5 a piece plus 5 for shipping and handling so 20 dollars total you have to replace both of them
Oct 13, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 Convergence part #'s
(2) STK392-110 Convergence Amp ICs
(3) 220 ohm 2watt metal film resistors
(3) 150 ohm 2watt metal film resistors
(2) 1.5 ohm 1watt metal resistors
(2) 2.2 ohm 1watt metal film resistors
(1) 1.8 ohm 1watt metal film resistor
(1) 3.3ohm 1watt metal film resistor
You can get the entire convergence repair kit which contains all the parts listed at the following link its called the AV48WP30 Convergence repair kit , but it applies to your model as well, and they include free installation instructions.
http://servicemanuals.vstore.ca/
Aug 18, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56 in
You don't have to replace the board, just the amps. This set uses two stk392-110 Sanyo built amps. You will also need to test and possibly replace one or more of the 1.5 ohm feed resistors in that circuit.
If you're doing this at component level try Acme in Florida for amps and resistors: 1-800-575-9833 http://www.acme-sales.net/index.shtml and if you're doing this at modular level send it to PTS http://www.ptscorp.com/ 1-800-844-7871
Bill
Nov 27, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 projection TV green sagging and can not be adjusted out.
The convergence amps need to be replaced. If you're having a shop do this call around and ask what they charge for repairing the convergence. If you're doing this repair this set uses two stk392-110 Sanyo built amps. You will also need to test and possibly replace one or more of the 1.5 ohm feed resistors in that circuit.
Bill
Nov 06, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
144 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
