Question about Maytag Admiral LER3330AAW / LER3330AAZ / LER3330AAB Electric Kitchen Range
Top burners work, oven not getting gas electronic ignition comes
On for broiler, I'm not sure for oven I can't tell.
The electronic ignition system (a ceramic plate that glows red) lets some power pass through to allow the gas to flwo when it has reached lighting temperature. The ceramic lighter needs replacing. Either that or the general electronic in the stove are shot.
Posted on Oct 04, 2009
Gas burners on top of stove work but broiler & oven do not heat up.
Hello'
Does your model have an electronic ignition? If so open broiler drawer ,turn on oven and look for bright orange glow. May take a few seconds.If it glows but no or poor flame .replace oven igniter.If no glow at all , check for voltage at igniter when switched on to see if it may be oven thermostat . Get a tech to test if not sure.All easy to fix.
Hope this helps
Aug 16, 2011 | Ovens
MY MAYTAG OVEN WILL NOT TURN ON WHEN I SET THE ELECTRONIC DIGITAL THERMOSTSTAT LIKE SAY I PROGRAM IT TO 350 DEGREES,,, NOTHING HAPPENS,,, BUT WHEN I GO TO SET THE BROILER THE BROILER WORKS JUST FINE,,, I...
First I want to commend you for your giving us good information to start with!
So-- we know we have gas, and we know the Broiler Valve and ignitor works-- Good observation!
However-- we have no ignitor (No bright red/Yellow glow)-- like you go for the Broiler-- right?
Well, we can NOT get ignition on the main burner-- unless we have the ignitor for the main burner getting hot, and then the gas valve to that burner can light, and give you heat...
Soo-- Likely we have an ignitor failure for the Main burner---
Do you have a warranty on the stove?
Do you have a service person qualified to tackle this job?
There will be electrical work, and parts obtainment issues to deal with now---
I suggest you call the local service people for this stove, and tell that that you need to have the main gas burner ignotor replaced for this stove model number-- and see what they tell you.
Let me know if I can help more--
Mack B
Dec 30, 2010 | Maytag Ovens
Gas stove top works, broiler works, oven does not
is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
Feb 06, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven doesn't light. I have a Maytag MGR5750. The pre-heat light comes on but no ignition. Stove top burners work okay.
First thing to do is verify if the hot surface igniter or spark igniter is working. If the oven has a bottom broiler compartment then you can check from the bottom compartment. If it has a top broiler then you may need to remove the inner bottom cover inside the oven to look at the burner and igniter. Now turn on the oven and watch for the hot surface igniter to start to glow or the spark igniter to come on. If the igniter comes on then give the gas control valve(located at the bottom broiler/storage compartment) a tap with a wrench or a screwdriver. If the burner comes on then shut the oven back off and on several times COMPLETELY. If it works then you may have fixed the problem by dislodging debris in the valve. If it does not come back on then the gas control valve may be defective or the igniter could be weak. The igniter should be tested with a ohm meter and if it tests good(500-700 ohms usually) then the gas control valve will need to be replaced otherwise the igniter is bad. On spark ignition systems there is a different procedure. Another thing to check is the "runaway valve" that is located on the gas regulator for the range. It is a little lever located where the oven gas pipe comes off the regulator and cuts the gas to the burner when closed.
Oct 16, 2009 | Maytag Kitchen Ranges
Whirlpool SF377PEGQ 0 ,Gas Oven not igniting...
if you have 120 v to ignitor then ignitor is bad.
Dec 26, 2008 | Kitchen Ranges
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
TAPPAN MILLENIUM GAS RANGE
hi thanks for the question so in your onen you are saying that the top broiler works but not the bake there is a igniter in the bottom of the oven ita an igniter same as the top replace it
Sep 15, 2008 | Kitchen Ranges
Spark module clicks and gas will not stay lit, flame comes on but goes out
hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
thank u.................
Sep 11, 2008 | Ovens
Maytag gas oven won't light
After moving my oven out of the room to lay a floor, the oven wouldn't work when I put it back. Everything else worked (top burners, broiler).
I spent much time here and elsewhere on line trying to get enough knowledge to at least diagnose the problem, if not fix it. There is nothing worse than not knowing what is wrong when the repair guy comes, because you are then at their mercy, and some of them are less than merciful!
I took it apart, observed how the broiler worked, and assumed logically that the oven should work similarly.
The igniter on the bottom/oven part seemed slightly further away from the gas tube than the broiler igniter did. I just touched it and it moved!
As it turned out, the bracket that holds it in place had become jarred when I moved it, and had moved almost imperceptibly away from the gas tube.
This tiny difference was enough that the ignition didn't take place. Instead, after 4 clicks, the igniter shut off, a safety issue built into it, I suppose.
I attached the igniter to the gas tube with wire, readjusted and tightened the clamp, and Bob's your uncle, i have my oven back!
So, I guess the 'tip" is to simply make sure the igniter is close enough to the gas tube to actually ignite the gas.
As any repairman will tell you, the order to check things out in should always start with the simplest thing first!
May 26, 2008 | Kitchen Ranges
Maytag Admiral LER3330AAW / LER3330AAZ / LER3330AAB Electric Kitchen Range Logo
324 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
