Question about Panasonic KX-T7633 Corded Phone
Kxt77633 system directory
In vista how to use the del command
open a dos prompt.
to make a directory type md "name of directory"
to remove a directory type rd "name of directory"
to change from one to another type cd "name of directory"
to go up one directory type cd..
to change drives type cd drive letter
All commands are typed without quotes
Mar 20, 2014 | Microsoft Windows Vista Home Premium with...
How to program or update the directory list in the vodavi telephone system
It depends on if it's the voice mail dial by name directory or the directory on the phone system.
Louis at CT Innovations
502-814-5100
Nov 26, 2012 | Vodavi Mach 1 Telephone System W/ 7...
What is the dos command to move up directories
To move up one directory you would type the current directory command again with two periods like this
cd ..
To move up one directory and then into a sub folder an example would be
cd ..\example
Aug 09, 2011 | Microsoft Windows XP Home Edition English...
How do you delete very directories???
Open My Computer
Open the icon for the WD external drive.
Click once on a directory.
Press the DELETE key on the keyboard.
Click 'Yes' to confirm that you want to delete the whole directory, including its contents.
Aug 19, 2010 | Western Digital My Book World Edition 1TB...
The message light on the MD110 is not working. I think I pressed something that disabled it. How to I get it back on?
detail_no-screenshot.gif Erlang R11B
Erlang is a full-featured programming language developed at the Ericsson CS Laboratory. more>> Erlang is a programming language designed at the Ericsson Computer Science Laboratory.
Open-source Erlang is being released to help encourage the spread of Erlang outside Ericsson.
Installation
When installed, the entire system, except for a small start-up script, resides in a single directory tree. The location of this directory tree can be chosen arbitrarily by the installer, and it does not need to be in the users $PATH.
The only requirements are that the file system where it is placed has enough free space, and that the users who run Erlang/OTP have read access to it. In the example below, the directory tree is assumed to be located at /usr/local/erlang, which is here called the top-level directory.
It is assumed that you have the compressed tar file, the name of which is < PREFIX >.tar.gz, where < PREFIX > is a string denoting the particular Erlang/OTP release, e.g. otp_LXA_11930_sunos5_R9B.
Wherever the string < PREFIX > is used below, it should be replaced by the actual name prefix of the compressed tar file.
The tape archive file does not have one single directory in which all other files are rooted. Therefore the tape archive file must be extracted into an empty (newly created) directory.
1. If the top-level directory does not already exist, create it:
mkdir /usr/local/erlang
2. Change the current directory to the top level directory:
cd /usr/local/erlang
3. Create the installation directory with an appropriate name. For example:
mkdir otp_r7b
4. Change to the installation directory, e.g.
cd otp_r7b
5. Assuming the compressed tar file resides in the directory ,. extract the compressed tar file into the current directory:
gunzip -c / .tar.gz | tar xfp -
6. Read the README file in the installation directory for last minute updates, before proceeding.
7. Run the Install script in the installation directory, with the absolute path of the installation directory as argument,
./Install /usr/local/erlang/otp_r7b
and supply answers to the prompts.
In most cases, there is a default answer in square brackets ([]). If the default is satisfactory, just press . In general you are only prompted for one thing:
- "Do you want to use a minimal system startup instead of the SASL startup?"
In a minimal system, only the Kernel and STDLIB applications are loaded and started. If the SASL startup is used, the SASL application is included as well. Normally, the minimal system is enough.
8. Make Erlang/OTP available for users, either by putting the path /usr/local/erlang/otp_r7b/bin in users $PATH variable, or link the executable /usr/local/erlang/otp_r7b/bin/erl accordingly, e.g.:
ln -s /usr/local/erlang/otp_r7b/bin/erl /usr/local/bin/erl
Enhancements:
- Among other things, SMP support was added.
<<less Download (10.3MB) Added: 2006-05-18 License: GPL (GNU General Public License) Price: 1259 downloads
Mar 05, 2010 | Lands Phones
Rename a folder in c drive using java code
import java.io.*;
public class RenameFileOrDir{
public static void main(String[] args) throws IOException{
BufferedReader in = new BufferedReader(new InputStreamReader(System.in));
System.out.print("Please enter the file or directory
name which has to be Renamed : ");
String old_name = in.readLine();
File oldfile = new File(old_name);
if(!oldfile.exists())
System.out.println("File or directory does not exist.");
System.exit(0);
System.out.print("please enter the new file or directory name : ");
String new_name = in.readLine();
File newfile = new File(new_name);
System.out.println("Old File or directory name : "+ oldfile);
System.out.println("New File or directory name : "+ newfile);
boolean Rename = oldfile.renameTo(newfile);
if(!Rename)
System.out.println("File or directory does not rename successfully.");
System.exit(0);
else {
System.out.println("File or directory rename is successfully.");
Mar 30, 2009 | Sun Java Programming Language (cdj-275)
Active directory is rebuilding
if u edit settings in active directory and editing the rools
bake up your setting
and remove active directory
them stup it agien
Nov 06, 2008 | Microsoft Windows Server Standard 2003 for...
Changing numbers?
To program the personal directory Its diferent to program the system directory. the personal has 8 number capaciti and the system has 999 number. To program the System directory
1.- Enter to PBX program mode from your station 101
2.- Choose program 001 to enter the quick dial numbers
3.- Choose program 002 to enter (Or change ) the Labels
Jul 05, 2008 | Panasonic KX-T7630 Corded Phone
Regarding ActiveDirectory Services in Windows system
Active Directory (AD) is a technology created by Microsoft that provides a variety of network services, including: using the same database, for use primarily in Windows environments. Active Directory also allows administrators to assign policies, deploy software, and apply critical updates to an organization. Active Directory stores information and settings in a central database. Active Directory networks can vary from a small installation with a few hundred objects, to a large installation with millions of objects (though not easily [3]).
Active Directory was previewed in 1996, released first with Windows 2000 Server edition, and revised to extend functionality and improve administration in Windows Server 2003. Additional improvements were made in both Windows Server 2003 R2 and Windows Server 2008.
Active Directory was called NTDS (NT Directory Service) in older Microsoft documents. This name can still be seen in some AD binaries.
There is a common misconception that Active Directory provides software distribution. Software distribution is run by a separate service that uses additional proprietary schema attributes that work in conjunction with the LDAP protocol. Active Directory does not automate software distribution, but provides a mechanism by which other services can provide software distribution.
Jul 01, 2008 | Microsoft Windows Server Standard 2003 for...
Panasonic KX-T7633 Corded Phone Logo
46 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
