Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
Garage door will not close from remote or car.
Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual control inside the garage until it is completely close; otherwise, it will stop as soon as I quit pressing. It is the Chamberlain Liftmaster Professional Formula I model.
  • 74 Answers
Check the safety photocells is theres not obstacle between then, check both photecells leds are on.. otherwise no need to replace them
Posted on Mar 15, 2009
  • 25 Answers
WI have never heard of this problem. you have to hold the button on your wall in to close the door. no way this is not right something wrong with your board insid the opener. get help from a pro. I would love to see this been doing this for 20 years never heard of this.
Posted on Jun 20, 2009
  • Mark Belanger Dec 25, 2012
    I have the same exact problem. I believe it is related to the sensors that determine if anything is blocking the door closure. I'm trying to figure out how to adjust those so they are aligned properly rather than giving false signals that something is in the way and stopping closure.
  • Susan Fierros
    Susan Fierros May 13, 2014
    I have this same problem. Does anyone have a solution yet?
3 Suggested Answers
  • 333 Answers
SOURCE: Garage door will open from remote or car;but wont close,only closes by inside wall unit
Something could be blocking the electric eye.they are down at ground level on both sides of the door
Posted on Jan 09, 2012
mcgiveral
  • 68 Answers
SOURCE: Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the ma
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
Posted on Jan 21, 2012
Digidoor remote
"Another reason is problems with the radio frequency of the remote control system used, some older systems use frequencies that are liable to interference from various sources such as police and fire department radios and military communications. The effects of this interference are many for example, the garage door may open and close on its own or the operating range of your remote control may become so poor you cannot open or close the door with your remote control even whilst standing next to it."
source
Jul 29, 2013 | Audio Players & Recorders
Garage door opener remote does'nt work when the garage door is shut
Probably you have a weak battery in your remote transmitter. When the garage door is closed it requires a stronger signal. Open the remote and replace the battery.
Oct 20, 2012 | Home Security
Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual...
Jan 21, 2012 | liftmaster Chamberlain Garage Door Opener...
Dec 20, 2011 | liftmaster Chamberlain Garage Door Opener...
I have a Sears Model 139.53879 (3-Function Remote Control) garage door opener. It's about 12 years old. The remote controls open the door fine but the remotes do not close the door; it has to be closed...
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Mar 31, 2011 | Sears Genie Garage Door Gpwk12 Wireless...
Garage door only closes halfway
If the main light is flashing 10 times when the door reverses when closing it is a door sensor problem. You can override this with the door control but not with a remote. Make sure the door sensors are pointed at one another and the small light on each one is on and not flickering.
Jul 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
We moved into a house with a LiftMaster garage door opener that we are guessing is almost 10 years old. No problems when using the one handheld remote we were given or the wall control; however, when...
Just to satisfy me would you try your original handheld remote once to make sure it is working properly. The wall control is hardwired so it is not a question.
Sep 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Sep 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not respond to security plus remotes
Reset the Liftmaster unit. There should be a red reset button on the unit in the garage. If this does not work, reset the breaker. Good Luck!
Jul 03, 2009 | liftmaster Chamberlain Garage Door Opener...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
1,267 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
