Question about HP Office Equipment & Supplies
Remove in tray of hp 6600 printer
How to remove the paper in tray from the machine
5 Suggested Answers
  • 300 Answers
SOURCE: Printer will not grab paper
You may need to obtain the HP Paper Feed Cleaning Kit from Customer Service by contacting them here. While your speaking with them you may want to ask about any issue that have came up with your particular model because I have read they have replaced some models that were even out of warranty.
To use:
It seems that by what Im reading, this is mostly caused by a dried out roller (especially if they are grey so you also may have some other options:
NOTE: These options may void warranty.
  • You may try applying a thin layer of vaseline on the rollers that pull paper. You can usually access these rollers from a door at the back of your printer. This should also soften the rubber. I would suggest running a sheet of plain paper through a couple times to clean off any excess.
  • You can try the Rubber Rejuvenator listed here.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Nov 19, 2008
POCBM
  • 121 Answers
SOURCE: paper feed
Check tray 1 there should be an arm hanging down in the center of the tray the arm goes thru a slot in the metal plate. This arm moves when you install paper in tray 1. If the arm is missing or not in the slot the machine will think paper is in tray 1 and try to feed from tray 1. You can try changing the paper size setting for tray one to something other than the size in tray 2.
For example If tray 2 is set for 8.5x11 set tray 1 for legal.
The machine should then pull the correct size based on the print job.
Hope this helps
Posted on Mar 04, 2009
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
shadiabed
  • 72 Answers
SOURCE: Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Posted on Jan 08, 2010
How remove feeder tray from 6600
Hi Ed Walsh,
When you say feeder tray, are you speaking of the document feeder tray, or the paper input tray? The document feeder tray is not customer replaceable so it will not be removable. The input paper tray is however removable. Perhaps you will find the support page for your Officejet 6600 helpful:
HP Officejet 6600 All in One Printer H711a H711g How to
I hope this helps.
I work on behalf of HP.
Jul 14, 2015 | HP OfficeJet 6600 e-All-In-One Inkjet...
How do I put the paper tray back into my HP LaserJet P3015 printer
Make sure that you did not lower the duplex tray. Look into the printer where the paper tray goes and make sure the path is clear. The duplex tray is dropped by pushing on a green lever on the left front of the duplex tray. Simply push the tray up until if clicks and locks in place. This is the only reason I have run into with clients as to why they cannot insert the paper tray.
Sep 13, 2014 | HP Laserjet P3015X Printer
How do I remove paper tray
Instructions
Grasp the front of the output tray located beneath the control panel. Remove the output tray by lifting the front of the tray up and pulling the tray out. Set the output tray aside.
Read more: How to Load Paper into an HP Officejet All-in-One Printer ' eHow.com http://www.ehow.com/how_4489317_load-paper-hp-officejet-allinone.html#ixzz2NjlQ4lhl
Mar 16, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
Tell me please hp laserjet printer 2420 paper tray setting
    1. Remove the packing material from the printer.
      1. Remove the all orange tape from the outside of the printer.
    1. Load all paper trays.
      1. Pull the paper trays completely out of the printer.
    2. Press the blue tab on the rear paper length guide and adjust the rear guide so that the pointer matches the size of the paper to be loaded. c00318778.gif
    3. Move the side width guides outward to match the desired paper size. c00318779.gif
    4. Add the media to the paper trays, make sure that it is flat in the tray at all four corners. Keep the media below the height tabs on the sides and rear of the tray. Push down on the metal lift plate to lock it in place. c00318780.gif
    6. Install the print cartridge.
      1. Remove the print cartridge from the packaging.
    7. Rock the print cartridge back and forth several times to "mix" the toner. c00318783.gif
    8. Pull the sealing tape from the end of the print cartridge to remove the entire length of the tape. c00318784.gif
    12. Connect the LAN cable (optional). (HP LaserJet 2420n, 2420dn, 2430tn, and 2430dtn models only) c00318788.gif
    Jan 13, 2011 | HP LaserJet 2420 Printer
    My printer says out of paper even though theres paper in the tray.
    remove the paper from the tray and look at where the paper enters the machine, you should see a small actuator, ensure that this has not stuck,
    Jan 05, 2011 | HP PhotoSmart C4280 Laser Printer
    HP Color LaserJet 8550DN input device failure, check cables and cycle power | error code: 66.01.02
    This error message indicates a lifter malfunction has occurred. When the 2000-sheet input tray (Tray 4) is closed, the paper deck lifts the paper stack until it is just below the feed rollers. Photosensor flag PS34, the paper surface photosensor, determines when the paper stack is lifted into the feed position. When PS34 does not detect paper in the expected time, the printer reports a 66 error. SOLUTION: Follow the steps below to troubleshoot and resolve the issue.
    1. Turn the printer off, open and close the tray, then turn the printer back on to see if the error clears.
    2. Open the drawer and check for extra paper or items stored on the left side of the tray. This will prevent the tray from lifting due to excess weight or blocking the lift of the tray.
    3. Remove all the paper from the tray. Remove the tray guides and reseat them. Verify the guides are not bent or broken.
    4. Lift the paper deck manually to verify there are no obstructions in the path.
    5. Pull the tray out as far as possible and observe the white bushing on the back right side of the tray. If the white bushing is broken, the tray will not lift properly.
    Oct 23, 2009 | HP Digital Sender 9100C Multifunction...
    Input tray jammed/locked
    The input paper tray is removeable. So try the link below to try to get your all in one machine set up  again. http://h10032.www1.hp.com/ctg/Manual/c00737614.pdf
    Jan 26, 2009 | HP Photosmart C5180 All-In-One InkJet...
    I have a paper jam and can not get to the paper
    If the machine says paper jam then the machine will not function until the paper is removed. The machine has to be disassembled and the paper removed.
    Nov 22, 2008 | HP - HP Photosmart 8250 printer
    HP 4350n Printer says paper jam .
    check the paper sensor maybe one of the sensor stuck
    Feb 12, 2008 | HP LaserJet 4350 Printer
    209 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
