Question about Fishman Music
How do i get a circuit schematic for a fishman Dual Parametric D.I.
Direct box with dual parametric equalizer need schematic so a tech can fix it
2 Suggested Answers
guitarmanjoe
  • 336 Answers
SOURCE: can I download and print the manual for the ART 355 Dual 31 Bank Graphic Equalizer
Simple, how much instruction would you need? Check here http://www.manualslib.com/manual/210377/Art-355-Eq.html
Posted on Mar 06, 2013
How do I get a schematic diagram for Fishman SA220?
Fishman generally doesn't supply schematics to end users. Your best bet would be to find the authorized repair center nearest to you and jus t let them deal with it.
Feb 27, 2017 | Fishman SA220 Solo Performance System...
Factory reset Behringer FBQ2496
After my FBQ 2496 began to go "wild", it finally went blank with a ticking sound. I tried pressing and holding the "Reset" and "Bypass" buttons, simultaneously during power on. It worked after 3 or 4 tries.
Feb 24, 2014 | Behringer USA FBQ2496 Ultra Fast 24 Bit 96...
Can I download and print the manual for the ART 355 Dual 31 Bank Graphic Equalizer
Mar 05, 2013 | ART 355 Dual 31 Band Graphic Equalizer
How do i hook up a feedback destroyer to my EQ,COMPRESSOR,COSSOVER
Put at end of the chain. In this order: (1) EQ (2) Compressor (3) Crossover, (4) Feedback Destroyer.
Dec 12, 2012 | Behringer Dsp1124p Feedback Destroyer Pro...
Getting hum through the speaker but when i put my hand on the jack socket it stops
If you are in the US, take a length of light-gauge wire (AWG 20-24) attach it to the center screw that keeps the cover on over the standard dual AC receptacle and to a screw on the back of your unit. This kind of problem often is caused by a poor grounding of the cover or chassis.
May 16, 2011 | Fishman Matrix Infinity Acoustic Pickup...
How o u hook up behringer feedback destroyer to a powered mixer
In order for this to work properly it must be inserted between the last pre-amp stage and the power amp. Can you please update this with the mixer that you are using? With the make and model of the mixer, I can provide you with a connection description. Since each mixer will have different labeling and options, it is not possible for me to accurately describe the connections without hte make and model.
Thanks,
Dan
Feb 02, 2011 | Behringer Dsp1124p Feedback Destroyer Pro...
How to connect feedback destroyer pro dsp1124p ?
It all depends what you are connecting it to... Essentially wire it someplace between the preamps of microphones and the power amps that drive speakers. The only stipulation is that you want the levels to be "line level" signals.
If you are using a powered mixer, you will do this as an "insert" using the insert effect jacks. The preamp signal goes to the "in" of the destroyer, and the "out" goes to the following amp.
Dec 13, 2010 | Behringer Dsp1124p Feedback Destroyer Pro...
Show me how to hook up the Behringer destroyer pro?
What are you going to hook up to?
Essentially you connect the power cord to power and connect outputs from say a mixer to the inputs using TRS balanced cables... and connect the outputs of the unit to your power amplifier.
Note taht there are MANY other possibilities using "inserts:on some devices.
Dec 02, 2010 | Behringer Dsp1124p Feedback Destroyer Pro...
Music Logo
59 people viewed this question
Top Fishman Music Experts
Matthew Spark
Matthew Spark
Michial Gueffroy
Are you a Fishman Music Expert? Answer questions, earn points and help others
