Question about RCA R52WH76 Television
Tv went off wont turn on green light flases 5 times then 9 times
Tv went by itself attempts to turn on results in a series of power button flashes 5 times then 9 times
SOURCE: won't turn on
Replace the small signal board and take the eeproms off the old board put on new board to avoid convergence alignment and geometry problems
Posted on Jun 21, 2007
Slinteriors
  • 8617 Answers
SOURCE: 52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
ladywinn
  • 5138 Answers
SOURCE: I have an RCA R52WH74
Replace 3 capacitors cp150 2200uf 16v If it is puffed up on top it is bad ,need to replace 2 more caps cp120 cp114 220uf 35v they are green with gold writing on them.
Posted on Dec 25, 2008
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
Slinteriors
  • 8617 Answers
SOURCE: tv wont turn on, RCA D56w20, 56" rear prjection
replace the flyback 259296 and the CP150 capacitor. You can get the replacement parts with free instructions at the following link.
Posted on May 17, 2009
Standby light flashes twice
The power supply board may have been damaged. Try leaving the TV unplugged overnight so the Tv can discharge and reset itself. If this doesn't work, the power supply board may need to be looked into by a TV repair shop.
If you have some electronic experience and wish to try to fix it yourself, you can most times find a Service Manual for your TV over the internet for less than $20. It will have schematics, diagrams and parts list for your TV.
Aug 21, 2009 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV doesn't turn on, red light flashing
numder of flasing indicate error code . so i need how many flash you can see when power on the tv using front power butten then i will suggest the solution
Jan 15, 2009 | Sony KV-32S45 32" TV
Timer light will not go off and I cannot turn on TV
ybhughes,
Are you asking about the wd62525? If so that's a v26 chassis and equipped with a self diagnostic test by flashing a series of two digit sequence after depressing the power button. After depressing the power button count the number of flashes - then you'll see a slight pause - then another series of flashes. (for example: four flashes, pause and four more flashes is an error code 44). The unit repeats this coding at least three times so be as accurate as possible...
Bill
Sep 26, 2008 | Televison & Video
Sleep light
i have a simular problem with my sony kvfs120 32, my stand by timer is flashing and the tv will do nothing else. the flasing light is actually a self diagonistic code mine is flasing 5 times.
Ray
May 20, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Directv remote
1) Use 2 new AA batteries in RC32 remote control;
2) Slide mode switch to "TV";
3) Press and hold the MUTE and SELECT keys at the same
time until the green light under the selected switch
position flashes twice, then release both keys.
4) Enter 9-9-1-1.
5) Press PWR button on TV.
6) Point the remote at the TV and press CHAN+. Repeatedly press CHAN+ until the TV turns off. Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7) Use the CHAN- key to step back a code.
8) When the TV turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key. If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the TV remote control.
9) To verify the code, slide the MODE switch to the appropriate position.
10) Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
11) Enter 9-9-0. (The green light under the selected
switch position flashes twice.)
12) To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down in the TV owner manual.
13) Press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
To control TV volume from Directv RC32:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Feb 11, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
RCA R52WH76 Television Logo
22 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
