Question about Panasonic TH-42PZ800U TH-42PZ80B TH-42PZ80BA TH-42PZ80U TH-42PZ81B TH-42PZ82BA TH-42PZ85U TH-42PZ8BA TXNSD1RLTU / TNPA4413 Buffer - In Stock
Panasonic viera freesat no signal - Panasonic TH-42PZ800U TH-42PZ80B TH-42PZ80BA TH-42PZ80U TH-42PZ81B TH-42PZ82BA TH-42PZ85U TH-42PZ8BA TXNSD1RLTU / TNPA4413 Buffer - In Stock
3 Suggested Answers
  • 45 Answers
SOURCE: I have just bought a
no, just plug your anologue aerial into it and go into tv's menu and into setup then tv installation and it should take you through it step by step
Posted on Jul 23, 2008
  • 6 Answers
SOURCE: my panasonic viera tv suddently is not picking up
The most common reason for a digital TV to read "No Signal," or to constantly suffer from frozen screens is poor cable connections. First thing you want to do is to check to make sure they are all correct, and that you are using cables rated for your system. Next is that you want to remember that the fewer lines you use, the stronger your connection will be. If your connections are all good, check to see if you are using splitters. Imagine your cables are actually water lines. It would be easy to see how thin your flow will be if you have a half a different different directions and lines through which you are forcing it to flow. If you can limit the number of lines you have connected, then your signal will be stronger. There are often a number of different ways to wire a sound system and peripheral components to your home theater. Sit down and review it. Anyplace you can eliminate a line (or mess of lines!), the stronger your signal will ultimately be when it gets to your TV's receiver.
If you are using cable and none of this works, chances are you have a "leak" in your line somewhere which needs to be reviewed by your provider. Be sure to remove all splitters and all such diverting sources before they arrive, though, as if the problem is found indoors, you will very likely be charged for this as a service call.
Posted on May 09, 2010
I STILL CARNT LINK MY FACE BOOK WITH MY PANASOIC SMART VIERA IT SAYS INVALED TOKEN I HAVE RESTORED IT BACK TO SHIPPING SETTINGS ALSO I HAVE TURNED THE VIERA LINK ON AND STILL NOHING ANY MORE SUGGESTIONS
Resetting your TV should make your TV create a new Facebook token. This token should then be entered on your computer at www.facebook.com/device.
A tutorial on how to reset your TV can be found at http://shop.panasonic.com/docs/how-to/2013/tv/reset-procedure/How_to_Reset_your_Panasonic_Viera.html
A tutorial on how to register Facebook can be found at http://shop.panasonic.com/docs/how-to/2013/tv/register-facebook/2013_How_to_Register_Facebook.html
Aug 05, 2013 | Panasonic Smart VIERA TX-P42GT30B 42-inch...
Panasonic viera no signal
Try connecting the input to a different TV. Also just check whether any of the buttons on the remote are jammed. If it works there, this might need attention by a qualified service technician.
Jul 15, 2012 | Televison & Video
What type of cable connector should I use for my Panasonic Viera 32" LCD TV? My old tv uses a screw on cable connector. It doesn't fit my new Panasonic Viera 32 LCD.
The incomming broadcasting signal cable connector are been standard,since the late 80 til now,why doesn't fit,is a mystries to me.U have cable or satalite dish services wright?Call their customer service,they'll send out a Tv tech. to check it out for u.
Dec 14, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
Panasonic plasma viera tv will not auto tune, can not pick up any signals at all. All cables are plugged in correctly. Model number TH-P46G10A
Reboot all cables,satalites,and telicoms boxes.Like unplug,replug the box an hour later.Let the boxes up grade software,go to ur tv menu setup rescan all channels again well get them back.Ur signal not there after that, than ur Tuner Signal board is dead.Need it replaced.
Mar 13, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
How do I setup my full hd freesat tv I have sky + do I take the dish cable out of the sky box or do I need another cable from the dish
If you really want to do this, well then you could use and antenna switcher, a small control box that the Antenna from the dish plugs into it and the Sky Box & Freeview each, plug separately into that box too, and then, you can select, which one the antenna is connected to. (Some even have remotes) OR you could simply "Split" the signal "IN" with an Antenna "Splitter" and run one feed to Sky & the other to Freeview. Now thats all amusing that you can get freeview from that Dish.
Feb 05, 2010 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
Panasonic Viera query
This as called goasting, it will do this on most fast moveing obcects, it is caused by video compression, need to eather get a better cable, or have your signal checked.
Jan 08, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
I have just bought a panasonic viera 42" tv. How can you get the HD working? It says it has freesat and HD built in but do I need to buy anything else to get this working?
Jul 23, 2008 | Panasonic Televison & Video
Panasonic TH-42PZ800U TH-42PZ80B TH-42PZ80BA TH-42PZ80U TH-42PZ81B TH-42PZ82BA TH-42PZ85U TH-42PZ8BA TXNSD1RLTU / TNPA4413 Buffer - In Stock Logo
18 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
