Question about Dell Computers & Internet
Full Hard drive
Dell Dimension 4300 c 40 Gig hard drive. I have both XPhome and XP Prof OS's installed and different programs on each. How can I transfer XPhome programs to XP Pro and remove XPhome from the hard drive to free up space?
    Novelist:
  • 113 Answers
You can merge to partitions on a single disk, although this should be one of your last resorts. when two partitions are created on a single drive the OS recognizes the two partitions as two seperate drives. From win xp pro, you can access all the data on the partition with xp home platform. the second partition will take up close to a gig of space that could be used. the simplest way would be to creat shortcuts to the programs you want in the partition for xp pro. then right click my computer> properties> advanced> start up and recovery settings> select win xp as the default OS and deselect the box marked "time to display operating systems"
this will stop that annoying 30 sec pause that you get when you start your computer asking which OS you want to run.
or if you seriously want to merge the two, here is a link with a download that will help.....download this file and creat an disk to insert into the disk drive and restart to load from the disk
http://download2.lsoft.net/BootDiskDemo-Setup.exe
the only thing is that if you write over or delete files that those programs need to run smoothly, you will have to reinstall them completely. in which case you would be just as well off to back up your info and do a clean install. i trust you will be able to determin which solution is best for you needs.
Personally if i had programs i wanted to save, i would take the first option and just have two partitions
Posted on Mar 11, 2009
Dell 8400 Boots to Black Error Screen in XP States to reinstall System 32
This might be caused by hard-drive failure. You should run hard drive test from BIOS to make sure hard drive is ok. You can access BIOS by pressing F2 during start up, from there start hard disk self test and wait for it to complete.
If hard drive is ok after test, insert in your original Windows installation media and reinstall OS.
Oct 02, 2012 | Dell Dimension 8400 PC Desktop
Hi just installed Windows XP Pro on a Dell Dimension 3000 with 1 gig RAM. This machine was running W2000 pro with no problems. But after formatting the drive and installing Windows XP pro and all updates...
Well you definately tried everything I would have sudgested.
It sounds like the Hard drive is near the end of its life.
If you have only just installed windows, it may be worth getting a new drive, installing your OS on that, you could then use the other drive as extra storage.
I have had a few HD that started to fail. Maybe the format and installation pushed it over the edge. You could always run maxtors drive check tool to see if it can detect a problem.( maxtor is now seagate)
http://www.seagate.com/www/en-us/support/downloads/seatools
Aug 06, 2010 | Maxtor Hard Drive
Misplaced cd for operating system
reinstall CD will not help u do a clean install after formating, so u need to get a windows install CD....try piratebay.org u can get the torrent link file there for any win OS and download that, it will get u the full working version of any Win OS in google do a search "Torrent piratebay Windows XP" u also need to get/install BitTorrent software from google/internet to get the torrent link file...
the full file of WinOS say 400 - 700 mb may be a ISO file that u need to burn to a CD so that u can boot from the disk and install windows
Feb 01, 2010 | Dell DIMENSION 3000 CELERON 2.4GHZ...
I am installing a new WD3200AAJB HD in a Dell Dimension 4550. This is the only HD in the system. There are also 2 CD drives and a floppy drive. I used the jumper settings the drive came with which pins...
Reinstall your old hard drive as master and install the new hard drive as slave.
Here is the link to jumper settings from Westrn Digital;
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1540&p_created=#jumper
If you've got your jumper settings wrong and installed your os on the 127 GB section of the 320 GB Hard drive and you change jumper settings and then you have problems you may need to reinstall the old hard drive as master and the new hard drive as slave. Reformat the new hard drive as 320 GB, and as a bootable drive. You can either do a disk copy from old to new or reinstall your os on the 320 GB drive. Please let me know how this goes. You can get to me @ johnkariotisjr91741@yahoo.com
Oct 25, 2009 | Dell Dimension 4550 PC Desktop
Need to know how to upgrade a hard drive from a 8 gig to 80 gig
I am typing this on a Dell 4600 RIght now. You need to look up how to set the jumpers on the internal hard disk ( 8GB) to SLAVE MODE, and set the 80GB to Master.
Remove the 8GB from the metal bracket, and put the 80GB in its place. Put the 8GB beside it. Plug the 80GB into the end of the IDE cable, and the 8GB into the middle. When you boot, you can hit F2 to go into the bios, and change the boot order from HD0 to HD1 and you can boot from your 8GB.
Now, If you want to boot from the 80GB, ( which I would ) you need an operating system.
Get your Disk labeled Reinstallation CD, Microsoft Windows XP Home Edition, Including Service Pack 1, and boot from it. Then format the 80GB, and install the OS There.. You will need your WIndows XP Home Key. ( you can either get it off the case or use Magic Jelly Bean Key finder to get it off your 8GB. Get the key and write it down. ITS IMPORTANT ).
Then you can change your boot order in BIOS, back to HD0, and boot from your fresh copy of XP Home.
If your interested in having a close to seamless experence as possible, you might want to invest in a copy of Partition Magic Pro. It can copy both the restore partition, ( the first 600MB of your 8gb disk ) and the primary partition of the 8gb, and resize the 8gbs primary partion on the 80gb to 80gb. ( YEA! ).
If you have *any* *any* lack of understanding please clarify
Oct 01, 2009 | Dell Dimension 4600 PC Desktop
I have a PC Dell Dimension 2400 with a hard 40 GB
Basically when you install a new boot drive you need to install Windows operating system on the new hard drive, also the device drivers (eg video, audio, modem, LAN etc), your programs and data. The reason programs has to be installed is because the installation process copied DLL files to the System folders and makes changes to the registry.
You can only copy your data onto the new hard disk.
To avoid copying your data to the new hard drive, you can set up the old hard drive as second hard drive (ie. slave drive), if you delete the redundant folders and leave only the data folders then you have an adddition 40Gb of disk space.
Aug 27, 2009 | Dell Dimension 2400 PC Desktop
Additional Hard Drive
The Motherboard will be able to handle it and XP will read the hardrive i have used a 500 gig hard drive in my old computer before it should work just fine
Apr 08, 2009 | Dell Dimension 2400 PC Desktop
Move HD from Dimension 4300 into Dimension 4700 / XP HomeED both.
You can change the hard drive, but it will create major driver issues.
You will have to let the computer tell you which drivers are missing and go back and download them from the manufacturers website or use the software that you have.
You cannot damage the hdd doing this.
The easy way to do this would be to install this as a secondary hdd, this would allow for more storage and less problems.
Dec 30, 2008 | Dell OptiPlex GX270 PC Desktop
Can't reboot windows cd on with cd drives
If you have it available, boot to the Dell DImension Resource CD and run the diagnostics on the hard drive. From the description of you problem, you may have a failing hard drive.
Other things to check:
1. Ensure the system BIOS (F2 at boot) sees the hard drive and has the correct date and time. If the motherboard battery is failing, the time and date will not be retained when system is powered off.
2. If you are able to format the hard drive, but the windows XP installation process gives you file copy errors, then you may have a bad RAM module. If the system has 2 or more modules, take out all but 1, retry the install. If you get file copy errors again, try a different module.
3. If the Hard drive passes dieagnostics, but fails to complete a format, replace the hard drive.
Jun 01, 2008 | Dell Dimension 4600 PC Desktop
New hard drive(s) in Dell4500s
You would have to contact dell for the OS disk.
I dont think you can install the hard disk in place of floppy drive. An external Hard disk would be a better option.
May 04, 2008 | Dell Dimension 4500S PC Desktop
Computers & Internet Logo
87 people viewed this question
Alun Cox
