Question about Logitech QuickCam Connect Webcam
Unable to see image
I just installed a Logitech Webcam Connect and I can't get the video to work; I have multi-color lines going across the screen. even i am not able to take a picture.Reinstalled software and drivers but no joy.. please help me with this .
  • 43 Answers
Try to use this driver: http://www.softwarepatch.com/software/driverscanner.html
Posted on Mar 12, 2009
How do I connect my Logitech webcam to my free skype?
Connect the Logitech Quickcam into the computer's USB port.
Install the Logitech Quickcam device driver.
Open Skype then click on Tools - Options - Video settings.
Select the WEBcam - Logitech Quickcam and you should see your image in front of the WEBcam.
You can set options for people to view you etc. Then click SAVE.
Oct 16, 2010 | Logitech Quickcam Chat Webcam
Webcam is not showing any video at all!
Connect your webcam
Launch the logitech webcam toolbar from your desktop or if you chose not to install the shortcut - launch it from "All programs" or from your C drive - Programs and files.
Open the Quick Capture menu (2 film frames pic)
Check your image here
If it shows white - you have a logitech/computer software problem
If its OK you have failed to configure it correctly to whatever program you are using it in.
Did you install the support software required to run Logitech cameras - Directx 10 ?
Apr 24, 2010 | Logitech Webcam
Nothing but multi colered lines verticly on the screen
Try this:
Turn it off.
Disconnect power cord and any other device attached to it.
Take battery out.
Without anything attached. Hold down the power button for 10-15 seconds.
Connect the power cord only.
Hold down F2 (while it's off)
Turn it on while holding down F2.
Let go of F2 when something comes out of the screen.
If multi colored lines still appears.
You have either defective LCD(screen) or video card.
Jan 30, 2010 | Toshiba Tecra M2 Notebook
Video is snowy with vertical white lines constantly. Picture is not good at all.
Hi friend,
Logitech webcam display is not good because your background color is dark...so please increase your background light..then it will improve...
Dec 26, 2009 | Logitech Webcam
No problems to install the logitech webcamera but
Launch the logitech webcam toolbar and make sure you do not have a Video effect selected
1) The video effects can be accessed from the 2 theatre masks on the pictorial toolbar
2) Check you have the latest version of DirectX installed from the microsoft download centre
Sep 28, 2009 | Logitech Webcam
My webcam only shows colored lines
I FIXED MINE= i installed a webcam program called av something...it come with a webcam driver so every time i used my webcam on FB or msn it was using the av driver instead of my crystal eye driver, just go to start control panel hardware and sound, device manager then click sound video and game controllers and uninstall the device, (NOT THE ONE THAT CAME WITH YOUR PC OR WEBCAM) or disable it if u think u will want it...hoope it helped!
Jan 20, 2009 | Logitech Webcam
Logitech QuickCam Communicate MP - black screen
  1. Either one of these image sizes:
    • Small image size: 160 x 120
    • Large image size: 320 x 240
  2. RGB, I420, or IYUV formats. (Each is fine; we recommend RGB 24.)
  3. Microsoft DirectX version 9.0
To get this information, click here to download a Microsoft application that checks to see if your webcam device meets these requirements.
To make it easy, when you’re asked where to Save the program, just save it on your Desktop.
Once it’s downloaded, here’s what to do:
  1. Double-click the amcap.exe file on your desktop.
    • If you have more than one webcam installed, click the Devices menu and select the one you want to use.
  2. Click the Options menu, then click “Video capture Pin.”
  3. Under “Color Space/Compression:”, choose one of the following formats:
    • RGB 24 (our recommendation)
    • I420
    • IYUV
    Note: If one of the options above isn’t in the list, then your webcam is not compatible with Yahoo!7 Messenger.
  4. Under “Output Size”, choose one of the following:
    • 160 x 120
    • 320 x 240
  5. Click OK
  6. Close the ampcap application.
  7. From your desktop, click ‘Start’ and select ‘Run’.
  8. In the run box, type: dxdiag
  9. In the confirmation dialog box, click OK.
  10. On the System Tab under ‘System Information’, look for DirectXversion. Verify that your version is DirectX 9.0. If it is, just click Exit. If your version is older than 9.0 (any lower number), click here to download the latest version of DirectX.
  11. Start the webcam from Messenger by clicking My Webcam in the Messenger menu.
Attention Logitech webcam users:
Some Logitech webcam drivers may cause one of the following problems:
  • Windows freezes when accessing the webcam
  • A black screen appears when using the webcam in Messenger
  • A ‘Webcam not found’ error message appears.
  • After 3 seconds, the sound drops out of calls made via Messenger
If you already verified that your device is compatible through the above steps and you’re a Logitech webcam user, please click here to update your Logitech webcam driver.
Dec 16, 2008 | Computers & Internet
Webcam E2500 no video
c program files
try to change video settings
if that does'nt do it
you'll have to uninstall and reinstall software
Nov 20, 2008 | Logitech QuickCam Connect Webcam
Lost my webcam installation cd
if lost my web cam installation cd n where can i find the software to download its program???
Apr 17, 2008 | Logitech Webcam
Logitech QuickCam Connect Webcam Logo
103 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
