Question about Watches
Find fossil watch es-4040 110508
Two tone metal. Large plain face. Ladies watch.
  • 14 Answers
SOURCE: new fossil watch
It is not likely that there is a protective cover over the battery itself, if there is anything on it to prevent use while not owned it is a little pc of plastic holding the stem out. It is sad to say but there is no way to tell how long the watch had the current battery in it before you received it. It is common to get a new watch and have the battery die shortly after or be already dead. Go to a local jewelry store to have replaced, make sure they are able to test the old one FIRST, if the battery is dead, allow them to replace it, if the battery is fine, return the watch to Amazon.
Posted on Dec 05, 2007
SOURCE: How to remove links from Fossil metal band?
I've had a Fossil before, but forgot how easy it is. Thanks for the refresher.
Posted on Jan 14, 2008
escapement
  • 2334 Answers
SOURCE: remove links from fossil metal band
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 07, 2009
escapement
  • 2334 Answers
SOURCE: remove the winding stem/crown.
There is a tiny point (end of small metal piece called setting lever) on the left side of the stem (on watch movement, very close where the stem is entering the movement).
You have to push that point down with a metal pin or tweezers. Crown (winder) must be pushed in to normal position otherwise you will not be able to put the stem back properly.
So, do as follows:
1) Push the crown in,
2) Lay the watch down on flat surface and push on setting lever point,
3) While holding setting lever pushed in- extract the setting lever by gently pulling crown out of watch.
Do not forget to rate, please.
Posted on Jan 09, 2009
  • 4 Answers
SOURCE: Remove link from Watch Band
I would suggest that you take it to local jewler or watch repair center, it normally runs less then $10 to remove an unlimited number.
Wal-Mart used to be a good place to go, but have since decided to support only watches that are sold in the store, which are crappy at best.
If you want to do it personally...I would discouage it. It is normally a simple process but without training, can turn into a big problem with minimal effort.
Have a great day!
Posted on Jan 13, 2009
INSTRUCTION MANUAL FOR FOSSIL CH2698
See https://www.fossil.com/content/dam/fossil/PDF/watchinstructions/Fossil_Watch_Instructions_EN_US.pdf
The file is a compendium of instructions for a large number of Fossil movements, but it is unclertain which movements the model CH-2331 and CH-2698 watches use. However, movement OS10 (page 15) appears to be the only one that matches the dial layout, button layout and also has a date window as the CH-2331. The watch has a quartz analog mechanism and uses one SR927W 1.55-volt silver oxide button cell. Silver oxide cells have low current output, but very long shelf life, so if the stem is pulled out completely when the watch isn't being worn, the battery could last many years. Scan the instructions to match up the CH-2698 with a movement number. A good guess from examining photos of the face of a CH-2698 watch would be movements OS20 / FS00 or VD53.
Apr 07, 2014 | Fossil CH2331 Wrist Watch
Does anyone know where I can get an old diesel watch it's got a strtechy strap and had orange bits on it? With a rectangular metal face? Please help, my girlfriend loved it!
Try the web site "zugoo.com/dieselladies.html", they have a large range of ladies Diesel watches.
Don't know about the "old" bit though!
Jan 06, 2010 | Diesel Watch DZ7071
Fossil ladies 2-tone watch with blue dial
vinegar and bicarbinate of soda will work perfectly
Aug 15, 2009 | Watches
Remove the winding stem/crown.
So, do as follows:
Jan 09, 2009 | Fossil AM3425 Wrist Watch
Hi, My ladies black and siver ladies bracelet watch is not keeping time. first the plate in the face kept moving position according to the movement of my wrist. Then it stopped keeping time, so I took it...
I would send it to Fossil anyways. You say the plate is moving, I'm thinking that's the dial (the thing with the Fossil logo and # on it) That is deffinantly under a warrenty. Fossil is pretty good with helping even if you don't have the paperwork, and don't live in the United States. Look them up on the internet, and if you can call first they will give you a # so when you send the watch they already know what to do and can start fixing your watch faster. Tell me what happens , or if I can assits you further. Good Luck!!!
Jul 08, 2008 | Fossil Watches
Indiana (IU) Fossil Kaleidoscope watch
It has two batteries.  The 2nd one is not obvious.
Jun 10, 2007 | Fossil Sport Washington State University...
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
