Question about Whirlpool Kitchen Ranges
Gy397lxu502 touch pad button bake don't work, timer button don't work #4 button don't work
4 Suggested Answers
CompuGuy44
  • 432 Answers
SOURCE: Touch pad not working
You'll need to have the electronics board replaced if its this far gone. Try Sears Appliance Repair.
Posted on Jun 27, 2007
aborcass
  • 2651 Answers
SOURCE: KitchenAid KESH307HBL4 Electric smooth top
that a tough one, when you press the start do you here a tione indicating that you depressed it??? if so then i would say your getting the power from the switch, and the burnt relay is the issue, but if theres no audio indication of hitting the button id replace both
Posted on Oct 26, 2008
aborcass
  • 2651 Answers
SOURCE: Bake button broken on KESC307HBS4
other then cleaning the glass, and making sure your finger is alas oclean and dry, no reall easy fix other then replacement od the console,i gues if you wante dto try you could llift teh console( 2 screws on either side, nad 4 screes acroos bottom) this will allow you to tilt the console back, and from there i would disconnect the ribbon connector, connecting the glass to the circuit board and try cleaning the end of cable with an eraser form a pencil..( sometimes,works, limited success but worth a try! diconnect power first LIVE WIRES!!!!!!!!!!!!!!!
Posted on Jun 15, 2009
Touch pad all lit up on GE 30 " slide in range
locate service manul / wiring diagram comees with all usually convenietly located taped to back inside pannel. shut off breaker , or slide out an unplug, read, manul if present plug back in fallow the set up steps,an trouble shoting. press,bake, set temp,and press start press timer,set timer ,and,press start again.should do it,.if not check for loose wire on oven senser.possible touch pad replacement. worst case. good luck
Feb 22, 2013 | GE Ovens
The left click button is partially pushed down and is difficult to make it click
This is an easy fix:
Step 1: Find a flat tip screw driver, the smaller the better.
Step 2: Gently pry around the edges of the left click button on the touch pad. It should pop off easily, don't force it!
Step 3: When you get it off you should see a small nipple that the plastic button pushes down. Make sure the nipple is secure and free of debris.
Step 4: Gently snap the touch pad button back on.
That's it!
Nov 12, 2012 | ASUS K501J WXGA HD 15.6" LED Panel
GE Spectra control panel buttons not working
Most likely control is bad and will have to be replaced
Aug 30, 2017 | GE Profile Spectra JBP95 Electric Kitchen...
Kitchenaid superba kgsc308lssc keypad not working
Hello Ron,
On that touch pad not working do any button at all work?? its not a uncommon thing for the touch pad to quit working,in some case its just a matter of making sure the plug on it has a good connection where it plugs into the control board. If certain button work while others don't its a sign that the control board itself is good and the problem lies within the touch pad and it would need to be replaced. It may possible as to clean the connection of the ribbon cable on the touch pad by using a pencil eraser and try cleaning the ends of the ribbon cable,again if that doesn't work the touch pad would need need to be replaced . On that model the touch pad is integrated onto the control console and the part number for it is 9782418CB just so ya know its pricey (over $200 )
Good luck,GENE
Oct 06, 2011 | KitchenAid KESC307 Electric Kitchen Range
I want to disable the touchpad and use the external mouse exclusively
Some laptops don't have dedicated buttons but you can use Function keys (like Fn + F5 on Dell computers) to toggle the state of your touch pad. In the case of HP laptops, you can hold the top-left corner of the touchpad for few seconds and it will disable the touch pad - repeat this to re-activate it.
New laptop computers either have a physical on/off button to easily disable the touch pad or there's an icon in the system tray that lets you manage the various settings of the touchpad. If you don't have that icon, you can go to Control Panel -> Mouse Properties -> Touch Pad to enable or disable the touchpad.
The touch pad can also be disabled through the device manager. Type devmgmt.msc in the Windows Run box to start the device manager, expand "Mice and other Pointing devices", right-click and disable the driver entry that says Touch pad or likewise.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 30, 2011 | Toshiba Satellite P305DS8836 Notebook
VIK ROSE 45010050 Stitch size button will go up but not down in size...
Possibly the touch pad is bad. Are they any other buttons that don't work? Usually when the touch pad is bad other buttons won't work either. If only the stitch length won't work then the step motor for the feed is bad or you have a bad board.
Apr 20, 2011 | Husqvarna Rose
Oven touch pad not working properly.
Hi. this will only get worse. i would replace this defective touch pad asap if possible.
Jun 23, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jun 27, 2007 | KitchenAid KGRT607 Gas Kitchen Range
Kitchen Ranges Logo
22 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
