Question about Garden
I need a deck belt for a wizard hydro 42" cut lawnmower
lester482529
  • 226 Answers
SOURCE: Deck belt
go to partstree.com click mtd,then put in your model#;then click deck assembly. it will show you your belt routing;then scroll or click the item #.it should tell you the lenth of your belt.hope this helps.please rate this;thank;s
Posted on Jul 03, 2009
dropndeal
  • 2931 Answers
SOURCE: Need a belt diagram for a husky 42 inch riding
If you have your model number and serial number handy, then enter both here to view available manuals.
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10451
I hope this helps.
DROPNDEAL
Posted on Jul 19, 2009
mickey813
  • 472 Answers
SOURCE: We have a Weatern Auto Wizard Riding Lawnmower.
19c5756.gifHOPE THIS HELPS LET ME KNOW
Posted on Nov 19, 2009
  • 20 Answers
SOURCE: poulan pro hydro 18.5-42 riding lawnmower - back
Your hydro transmission is low/out of oil or it need to be rebuilt or a new one.
Posted on Jan 18, 2010
SOURCE: i need a deck diagram for a 19.5 hp 42' cut
Craftsman 42 in deck makes terrible noise and middle wheel shakes. started while mowing.
Posted on Jul 30, 2010
42inch LT 2000, Kohler pro17OHV. What is the drive belt size?
Craftsman Replacement Belt for 42 in. Deck - Lawn ... - Sears
www.sears.com/craftsman-replacement-belt...42.../p-07133153000.. Sears
Rating: 3.5 - ‎42 votes
Jun 1, 2010 - Replacement Belt for 42 in. tractor deck. ... After a wast of time at searssaying that they could not find the belt we walked out angry and .... The Craftsman 42" Ground Hydro Drive Tractor Belt replaces manufacturers #140294.
Aug 11, 2015 | Craftsman Garden
I have a 17hp craftsmans lawnmower with a 42 inch deck. The motor runs fine, I just cant get the deck to engage. How do i fix this?
I hope you didn,t put wd40 on the belt that will cause it to slip, also with the motor OFF you should be able to engage the belt, so try that just to make sure it does engage and check the tension on the belt it should be snug. Again only with the motor OFF.
Mar 26, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Deck belt broken, l need a diagram to replace new belt on a Troy bilt riding lawnmower, 42 " cut 20 Hp, model # 13AP60TG563. Thanks
You will find the diagram on the left side of the deck as you sit on tractor by left foot. It will be located under the foot pedal that has the routing diagram specifically for your Troy-Bilt mower model. Note that owner's manuals may not have the most current schematic.
Also you can check this link to download the diagram:-
http://www.seapyramid.net/rt/belt-diagram-troy-bilt-riding-lawnmower/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
What size hydro drive belt can I use to replace the craftsman belt, part# 140218??
The Craftsman drive belt #140218 is a 1/2" by 84.3" belt with an aramid fiber wrap.
Since this belt is contacted on both sides (inside and outside) as it runs the pattern on your mower, it must be replaced with another belt of exact size and construction. If you were to use an 84" belt, then the tension pulley would not have enough slack to disengage the transmission. Likewise, an 85" belt would have too much slack and cause the trans to slip.
The original belt is available through www.searspartsdirect.com for about $25 plus shipping. Check with your local lawnmower repair shop, they probably stock this belt and will be competitive in price.
Oct 29, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Poulan Pro Hydro 18.5-42 riding lawnmower- no drive...are there shear pins in the axle drives?
First check that the purge valve is not engaged. Usually a small rod sticking out the back plate of the unit toward the right side. It should be pushed in.
Next check your drive belt. Best bet is to remove the deck and lay under the unit. Check for locked up pulleys and that the belt is seated properly on all the pulleys and that the belt is not stretched, cracked, or burnt. Make sure the belt gets taught when brake/clutch is released.
Lastly, there are keys in the drive axles. I have never seen one fail but they do get lost on occassion when the wheels are removed.
Dec 10, 2009 | Poulan Garden
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
