Question about GE Spacemaker JVM1640SJ Microwave Oven
GE microwv-doesn't heat, strong electrical smell, all else ok
This is an above stove microwave, about 5 years old, model JVM1430BD002.
Has worked perfect, never any problems until today, went to heat up some coffee for one minute. Noticed it 'hummed' a little differently, and after the minute, there was a strong electrical smell and it didn't heat the coffee.
Always taken good care of it, we fix most things ourselves, but unfamiliar with microwaves. Any suggestions?
Thanks!
    Prodigy:
    An expert who has answered 500 questions.
  • 547 Answers
The smell most likely indicates a shorted high voltage rectifier, or the high voltage/filiament transformer is self-destructing. Normally, magnetrons do not emit an odor when they fail. However, arcing high voltage wire near the magnetron could.
Posted on May 06, 2016
  • 38 Answers
The most common problem would be your magnetron. Check your purchase date, magnetron's usually have a five year warranty. Not a part I recomend trying to fix yourself (high voltage ).
Posted on Mar 11, 2009
JVM16331BB005 over the range microwave oven will not heat everything else works ok
That is a sign the magnetron has shorted and is the most expensive part to replace.
Apr 28, 2012 | GE Microwave Ovens
I Have a GE Spacemaker over the stove microwave. I think it is 1000 watts. It's 7 years old. Everything works but it doesn't heat anything. There is 23 volts going to the fan unit in the...
HELLO.
Since there is an amount of volts from the outlet, the fault is from the microwave breaker.
The solution is given below.
Reset the microwave breaker.
Take the back cover of the microwave off with a screwdriver.
Inside you will find a motor.
Most microwave motors have a small red reset button on them. Hit that button.
Your microwave should work again if the breaker was the issue.
Thanks
Sep 21, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The exhaust fan works, the light below the microwave that shines on the stove top works. It appears to be functioning properly except that it won't heat up food. The GE Spacemaker Model JVM131001 is...
I'm all for fixing appliances but in your case I would suggest replacement. After 24 years of service the magnetron is probably only putting out half of its rated wattage. It could also be one of the reasons of the no heat condition.
Jun 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Mircowave runs but doesn't heat and it has a load hum.
You may need a new microwave..however, the diode may be defective or the magnatron tube may need replacing,,The magnatron tube is only warranted for 5 years so it may be used up as the model is (10years)fairly old.
Jun 18, 2010 | General Electric Microwave Oven
I have a ge spacemaker XL1400. It was manufacture
it sounds to me like the magnetron is shot in it. this is the part that creates the heat. not worth repairing on a 10 year old unit. Sorry.
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need to know how to remove Advantium 120 convection/microwave oven Model SCA1000DWW03 from mounting above stove so that it can be taken to repair shop - problem is completely dead after power surge during...
Usually there are 3 or 4 mounting bolts located in the floor of the cabinet above. First you will have to disconnect the power and then the duck work if the unit is ventde to the outside. To remove the unit requires two people, one to support the unit and the other to remove the bolts. If you are doing it alone, quite difficult, you'll have to juryrig a deadman support. Ther is a wall plate behind the unit that has a lip that the back bottom of the microwve is locked into. After the bolts are removed slowly lower the front until you are able free the unit from the lip of the support plate.
Jun 28, 2009 | GE Advantium 120 Convection/Microwave Oven
MODEL JVM1630WH003-WILL NOT HEAT-LOW BUZZ AND SMELL-CLOCK WORKS
Assuming your inside light and turntable come on when you try to microwave, with the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Some manufacturers will send you the magnetron to do it yourself. If nothing else, you can save about $75 by taking it to the shop yourself.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
GE Customer Service is here if you want to check no the warranty or find a local servicer.
Feb 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Door inside and metal vent area smells strongly of fumes
Did you find an answer toyour question?
My microwave smells also of petrol in the same areas.
Jun 05, 2008 | GE JVM1653 Microwave Oven
Buzz, plastic smell and no heat
Chances are you have a magnetron that's failing. GE had a rash of "underperforming" magnetrons on these units. They replace the magnetron, stirrer and high-voltage diode at no charge for parts as long as a GE-authorized service center does the work. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. The bulletin shows you where tyo check. To see if yours is covered, see this bulletin: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf Otherwise, you need to contact GE Customer Relations at 1-800-386-1215 as soon as possible and tell them your problem and they will put you in touch with a local authorized servicer.
Apr 10, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
379 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
