Question about Samsung WF218ANW 4.0 cu. ft. High Efficiency Front Load Washer
Wf220anw/xaa01 will not fill
Was working fine when last used,went to do a load and everything else seems normal just no water .
  • Valerie Jun 07, 2013
    did you find a solution? i am having the same issue with mine too... and I cannot be without a washer!
Water not filling.
r u using auto fill mode?if u r then try selecting high medium or low. check water pressure coming out of inlet hose, could b faulty valve not letting enough pressure thru.please reply if u need more help
Mar 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
First became aware there was a problem when machine overfilled resulting inj flooding,cold water fill would stop when i turned on a tap ,suspected water pessure switch.new water pressure switch fitted...
If it works O.K. in a different wash cycle, then the timer could well be the issue.
Using that last cycle you described, will it perform a complete normal cycle ???
Jan 05, 2010 | Washing Machines
99 Sunfire Coolant keeps dumping
You need to find the source of the leak. it hasn't overheated yet because you keep catching it and re-filling. From your description, it sounds a lot like a bad water pump seal (part of pump) but without physically looking you can't be sure of that. when the pump seal begins to fail, internal pressure while running often will drive the seal tighter against the shaft stopping the leak. as pressure drops as the engine cools, the seal relaxes and permits seepage.
With time, that will change and it will leak all the time.
Oct 06, 2009 | 1999 Pontiac Sunfire
The rinse cycle does not work, but everything else does
I don't know if the problem is solved but last night we ran the washer without any clothes in it and everything seemed to work fine. My wife was able to run a load of laundry and it seemed to work. I hope it was just too much clothes the first time it stopped or the washer was just acting up. Either way, I had nothing to do with the fix. Sorry I couldn't be any more help. Thank you for the link to assistance plan, it might come in handy in the future.
Thanks again,
Sandro Micocci
Mar 30, 2009 | Kenmore Washing Machines
Roper Top Load Washer Does Not Fill To The Top on ''Extra Large''
the water level switch can be adjusted to raise the water level but is not recommended. The level you have is normal.
Jan 24, 2009 | Roper RAS8445KQ Top Load Washer
Espresso machine loses steam than recovers in minutes
It sounds like a heating element issue. Those elements look like a single unit but are actually made up of 2 or 3 independent heating coils - one may not be working. So, you're only getting 1/2 to 2/3 heating capacity, which isn't noticeable until the machine is under heavy steam load.
Dec 11, 2008 | Nuova Simonelli Program VIP Coffee Maker,...
Beko washing machine fills with water when not in use!!
hi there.....you got a faulty water inlet valve on the machine ..change this and all will be fine again...
regards Sir Galahad
Dec 05, 2008 | Beko 24 in. D3421F Free-standing...
Water inlet not filling
check it has drained completely after the last cycle.
if that is ok, take top off and check continuity thro the inlet valve coils
Aug 21, 2008 | Bosch Classixx WFC 2465 Front Load Washer
6 months old. Now no water will fill drum! Works as normal but no water!
Hurlewan Your washer is still under manufacturer's warranty which is one full year. If it has Kenmore's name on it you do not need proof of purchase. The only thing you need is your mother-in-law's home phone number at time of purchase because Sears keeps all their records based on phone numbers. Good luck, Gendos post back....
Jun 27, 2007 | Kenmore 43142 Front Load Washer
Samsung WF218ANW 4.0 cu. ft. High Efficiency Front Load Washer Logo
51 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
