Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
My sharp aquos won't power on
CHANGE IC202 WITH TL431 OR TRY PUSH INPUT AND VOLUME DOWN THEN PLUG THE POWER UNTIL THE GREEN LIGHT START ,,, WHEN IT START PUSH VOL DOWN AND CHANNEL DOWN AT THE SAME TIME AND PLAY WITH THE SETTING
Posted on Jul 16, 2013
SOURCE:
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
SOURCE: sharp Aquos will not power on. OPC flashes green
I had it picked up to be fixed on warranty. Downside is I'm out a TV for a week.
Posted on Nov 23, 2009
eagle338
  • 4889 Answers
SOURCE: my sharp aquos powe lite
IS the light on the tv blining or on the media receiver box? How many times does it blink in between each pause? Please provide this info so that we can continue the diagnosis
Posted on May 16, 2011
sodeep
  • 3267 Answers
SOURCE: sharp aquos 32" lcd. power and opc flash once,
replace input board
Posted on Jun 28, 2011
bugoy31
  • 1238 Answers
SOURCE: 60' Sharp Aquos tv power bar flashing but TV wont turn on. Any help??
Good day!!!
please try to count the exact number of blinking lights to diagnose where the fault came from..
Also try to open the cover and look for any bulged capacitors on power supply board..
Posted on Dec 19, 2011
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
Sep 22, 2012 | Sharp AQUOS LC-22SB28UT 22" LCD TV
It won't turn on
is there power to your dvd if there is then maybe turn your disc over and make sure it is a blue ray disc
Sep 19, 2012 | Sharp AQUOS Blu-ray Disc Player
My sharp aquos 52" power button is blinking blue and won't come on.
power supply which can be ruled out or confirmed with voltage checks on that board.
Aug 31, 2012 | Sharp AQUOS 52" Flat-Panel LCD HDTV
I'm trying to hook up a sharp aquos tv to an rca surround sound receiver and it won't work? any suggestions? I have tried turning off the speakers on the tv....
First thing to do is get the owner manual for each and start checking both settings and actual hookup---usually a surround system will work on all types of sets---when in doubt read the owner manuals.
If need either manual Google that model number with "manual" to try to locate it.
As far as the set goes it may require either a variable audio output source or in some cases the out to be a fixed level.
May 23, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
After power surge aquos tv won't turn on
hi ther is a overload fuse on the psu board which will blow after a surge of power but to get to it you will have to take the back off
Nov 09, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
My 32 inch Sharp Aquos acts like it isn't plugged in..The power light doesn't even come on...
Can you take the back off the set and check the fuse? Located to where the AC plug wire goes into the set. Can be checked with a ohmmeter for continuity. If bad do not exceed the amps of the original fuse when replacing because there may be a short in the circuit that will blow the new fuse and a higher amp may damage the set to a worse condition. Inspect the power supply for charred components across the AC line and replace.
Nov 03, 2011 | Televison & Video
TURN TV ON JUST PLAIN SCREEN (NO IMAGE), THEN HEAR A CLICK & TV TURNS ITSELF OFF- THEN ON AGAIN... CHANGED BATTERIES IN REMOTE & TRIED TO TURN TV ON DIRECTLY FROM TOP... NOTHING WORK. THIS IS A...
Do you see the backlight ever coming to the screen?
You will want to open the cover, disconnect the backlight inverter and try again to see if it will stay on even without an image.
If it does it's the inverter.
if it still shuts it's most likely (not guaranteed) either the power board itself or the main board.
A good tech should be able to test the power board independantly fairly quickly.
Jun 30, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I need some information on buying a ac adapter or power cord for the Sharp Aquos Model LC-22SV2U.
Cord: http://www.newremotecontrol.com/catalog/dyn_accy_data.php?catnum=QACCD3097CEPA
Adapter: http://www.newremotecontrol.com/catalog/dyn_accy_data.php?catnum=UADP-0243CEPZ
On the adapter: I've seen them a LOT less expensive just recently. Google it and choose "shopping" to narrow results. There won't be many, but I think you'll find one at better price in just a few minutes. Try ebay as well; that's where I found repair parts for the same model. Good luck!
Dec 20, 2010 | Sharp Aquos LC-22SV2U 22 in. LCD...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
699 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
