Question about LG Refrigerators
Knocking noise occurs about 20 seconds after compressor starts. Sounds like someone knocking on a wood door. It last about 8-12 knocks and then stops. It does not occur everytime the compressor starts but more times than not. There is no water hooked up and the ice maker is turned off.
  • steve
    steve May 11, 2010
    Check the compressor fan motor for something stuck in it or the fan blade tipping on something.
    And let me know.
    President:
  • 1,314 Answers
Its Freon expansion at the part where the lines come in to the evaporator in the freezer its a nuisance but supposed to be normal go to your local appliance parts and ask for some sound damping pads and wrap them around the lines where they come into the evaporator lots of times this stops it
Posted on Mar 11, 2009
Knocking noise about every hour or so,lasts 5 or 10 sec's. just started after 7 years .
This is the first sign of the compressor going out. You will either need to replace the compressor or purchase a new unit.
Oct 22, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Period loud tapping noise right side of dash 2010 Taurus
could be one of the doors in the heater box
May 28, 2012 | 2010 Ford Taurus
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
Knocking noise
it could be the compressor
Apr 20, 2009 | Refrigerators
I having a sporadic knocking from the bottom of the reffer side
ProbabyTry to Change Rubber Base Groumet for Compressor motor and there is nothing with freon
Kindly inform me When Solved
Good Luck
Feb 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Amana refridgerator mdl abl2222fes knock noise
sounds like the compressor vibration dampers are wearing out. the dampers are the rubber washers that seperate the compressor from the chassis of the fridge. when they start to deteriorate, and the compressor kicks on, it will bounce against something in the chassis, causing a knocking noise.
Jan 22, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Knocking/banging sound on compressor start up
Check the compressor mounts. They are usually springs mounted with rubber. If they are two loose the compessor wil hit some other metal part when starting up. Shakle it and see what it is hitting. Ajust accordingly.
Dec 27, 2008 | Refrigerators
Knocking noise coming from Whirlpool Gold refrigerator
I also have a new Whirlpool Gold fridge (bottom freezer with French doors) and it was making a knocking sound. The knocking sound would start when the fridge kicks in and starts running to cool, and would last for about a minute or less and be a slow knock.
I called Whirpool customer service since it is new and on warranty. They sent out a technician and he said the knocking is from gas/air built up in the copper tubing for the freezer because the copper tubing is too cold, and when the fridge first turns on it forces the air through, making the knocking sound.
His "fix" was to adjust the copper tubing so that it is closer to the heat of the motor/compressor and heat of another copper line so that the cooler line stays warm so the air/gas doesn't build up. His fix worked slightly, but the fridge is still knocking, just not as bad and not as long - it knocks fast for about 5 to 10 seconds instead of a minute.
Going to call customer service again soon and see where to go from here.
Dec 15, 2008 | Refrigerators
Refrigerator knocking noise
the motor could be on the way out. Put your hand (carefully) on the motor (back of the refridgerator), if it is too hot to touch then the motor is burning out and will need to be replaced.
Nov 15, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Kenmore Refrigerator making loud noise
Does the sound occur when the compressor is starting or shutting down? and only lasts for a couple of seconds? I had one do the exact same thing. Sometimes it would also wake me up at night. If so, I'm afraid he is right. On the bright side, it worked fine for years. I gave it to a girlfriend when I purchased a bigger one and it is still working today. The only thing you can do is change the compressor, which is probably not $$ practical.
Nov 05, 2007 | Samsung RS2556 Side by Side Refrigerator
Refrigerators Logo
424 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
