Question about Motorola Talkabout T5320 (14 Channels) 2-Way Radio
Programming motorola talkabout use T5320 - Motorola Talkabout T5320 (14 Channels) 2-Way Radio
2 Suggested Answers
Agent Ken
  • 250 Answers
SOURCE: Will a Motorola TalkAbout T5320 transmit to a Motorola TalkAbout T5530?
Hello Blindmaster,
Check the Continuous Tone Coded Squelch (CTCSS) settings on all the radios. (Note that some manufacturers refer to this feature as a “Privacy Code” or “Quiet Code.” The actual name of the feature may vary.) This feature encodes a low-frequency signal on your radio transmission. This signal is below the range of human hearing but can be detected by other radios. When the CTCSS feature is active your radio will ignore any signal that it receives that does not have the proper tone encoded on it.
In order for these radios to communicate, all of the radios need to be on the same channel and have the same CTCSS code programmed or the CTCSS feature must be disabled.
I suspect that CTCSS is activated on your T5530s but is not enabled on your T5320. This would result in the situation you describe.
Also take note that when using different brands / models of radios to communicate with one another that the CTCSS code numbering scheme may not necessarily be the same from radio to radio. For instance, CTCSS code “4” on the Motorola TalkAbout series actually corresponds to code “A” on the Motorola Sport models.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Posted on Apr 07, 2008
Constant static on talkabout t5320
Could be a sign of a bad battery. Static is a good indicator of a rechargeable battery nearing end of life.
Jan 18, 2014 | Motorola Talkabout T5320 (14 Channels)...
Issues with Motorola TalkAbout T5900 (14 Channels) 2-Way Radio. Do they need FCC programing & licensing to operate? Because I can not get the to communicate with each other!
Yes they do.The thing about the talkabout is that they work according to the network area they are connected to and the number of the talkabout they are also connected to.So all you need do now is to take the talkabout to motorola shop so that they can confrigure it for you.
Jan 22, 2011 | Motorola TalkAbout T5900 (14 Channels)...
Will motorola t 5320 and t 5720 work in the same frequency
Yes. Set all programming to match one another. Turn off the Qt filter, if any. Below are links to the owners manuals where you will find programming instructions to program the Frequency and Interference Eliminator Code.
http://www.giantintl.com/ContentManage/manuals/Moto/T5300_T5400_User_Manual_E.pdf
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards, post a comment or another question if you need further assistance.
Sep 12, 2009 | Motorola TalkAbout T5530 2-Way Radio
I have a bunch of two-way radios and one set is the talkabout 250. The problem is I dont know anything about two-ways and I want to get all the radios to work together. help
The Talkabout is a user programable radio. You will need to put the radio in the programing mode and program it to the other radios.
Go here for the manual.
http://www.motorola.com/mdirect/manuals/SX700_userguide.pdf
Aug 11, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
How do I change the channel on my T5320 2way radio?
With the radio on press the MENU button. The current channel will begin to flash. Use the + or - button to change the channel while it is flashing. Press the PTT button to lock in your selection.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T5300_T5400_User_Manual_E.pdf
Aug 04, 2009 | Motorola Talkabout T5320 (14 Channels)...
Hello Blindmaster,
Best Regards,
Agent Ken
Go Ahead. Use Us.
Mar 31, 2008 | Motorola TalkAbout T5530 2-Way Radio
Communications
Yes, but depends on the configuration/setup and programming/frequency assignation of the MTS2000.
To my knowledge, the UHF version of the Motorola MTS2000 are designed to operate either in the 403~470Mhz or the 450~512 or 520MHz band.
On the other hand, Motorola TalkAbout Radio are design limited to operate in the FRS band which is 462.5625~462.7250MHZ and/or the GMRS band which is 462.550~467.725.
So technically, both the MTS2000 and the FRS/GMRS share some frequencies. What needs to be done is to re-program the frequency allocation of the MTS2000 into its channels to match the TalkAbouts frequencies. The other way around is not possible. TalkAbouts frequency assignments can not be reprogrammed/changed. Below are typical TalkAbout Channels/Frequencies.de11c4e.jpg
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 04, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola Talkabout T5320 (14 Channels) 2-Way Radio Logo
49 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
