Question about Master Lock 643D Combination Padlock
Jammed master lock 643d - Master Lock 643D Combination Padlock
Rover Range Rover HSE 1996 braking system locking
either the master cylinder needs bleed or the slaves and servos need bleed
or both
i think if the pedal is hard then the master is jammed up and needs either replaced or a rebuild seal kit
if its soft its the slaves and the master is jammed on preasure
if you release the bleed points and fluid squirts out
its already compressed
so it must be one of the compression cylinders jamed on with preasure still in the system
so...
Dec 11, 2014 | Cars & Trucks
Brake jam in two wheels and brake paddle becom hard
It sounds like you have lost air pressure to your master cylinder via a tube from your engine. Or a Immobiliser has interferred with the operation of the braking.
Jun 02, 2014 | 2004 Ford Freestar
Service code interrupt
Error type T11 [Pressure-control motor lock]
T11-***
!!System Error!!
Press Reset Key
If Recovery has Failed, Call Service
Reset method Jam reset or switch on power again
Error point Error conditions
600
Timeout error for reducing pressure (OFF -> ON) during print-pressure home
positioning.
601
Timeout error for increasing pressure (ON -> OFF) during print-pressure home
positioning.
602 The print-pressure limit sensor does not change during print-pressure operation.
620 Print-pressure operation was called with the print-pressure motor locked.
621
Incorrect print-pressure operation timing (print-pressure operation command was
received when the print-pressure should not change).
622 Sensor A is ON and sensor B is OFF during movement from area A to area D.
623 Either sensor A or sensor B is ON during movement from area D to area A.
624 The current area data is undefined.
625 The target area data is undefined.
626 Timeout during relative print-pressure movement.
Error type T12 [Master-disposal-section motor lock]
T12-***
!!System Error!!
Press Reset Key
305
The master compression sensor does not go ON within 6.5 s after the master
compression motor operates in the return direction.
306
Master compression sensor does not go OFF within 2 s after the master
compression motor operates in the compress direction.
307
compression motor operates in the compress direction, and the mastercompression-
motor limit sensor cannot count up until the compression-limit
position.
309
The master-compression-motor limit sensor does not change within 200 ms
during compression operation.
hope to be of help
Sep 27, 2013 | Riso RP 3700
How do I use the child lock feature?
Usually there are switches inside the door jam of the rear doors. Move lever over to use the child safety locks. Occasionally the drivers side window/locks master controls will have a switch for this also. Mike
Jun 21, 2011 | 2001 Chrysler 300M
Bike lock enters half way and then jams, possibly reset by accident, how do you start over and reset?
Go to masterlock.com and they should have your answer. You can recover you combination etc, so I am sure that they can help you
Sep 08, 2010 | Master Lock Bicycle Lock
The lock is jammed with our keys inside
Assuming that you have definitely entered the correct combination, then try jarring the mechanism free using a hammer to give the lock a few sharp taps. If this fails then try heating the lock with a blowtorch. If these options fail, then the only remaining solution is to get the lock cut open using an angle grinder.
Aug 19, 2010 | Master Lock 5400d: Portable Select Access...
Riso in Jam and on the creen say: Check setting and red light on number 4. When I press * key it say -227 and P-08. I don't know what to do please help. Thanks
I found an error D08-227. Have you scrambled 'D' and 'P'?
Error type D08: Master making unit not set Error point 227: Master making unit lock sensor is still OFF when the master making unit is set in position (timeout: 5 seconds).
Hint: Check mentioned sensor.
In addition:Error type P08: Communication error with CI
Aug 10, 2010 | Riso RZ220 Duplicator
I did not close the lock all of thwe way on my Master coil type device. I spun the tumblers and realized that it was only 3/4 of the way in and pulled. It locked in that position and no amount of dialing...
Its jammed..
Do the combo correctly and whack it open with a small hammer..
If that does not work - you might be sol..
Hope this helps !!
rate me good ;o)
Jul 14, 2009 | Master Lock Bicycle Lock
I had a Master jam while making a new master. Code A-04-303
Under the drum and master unit is there a round openning .Take a sckrew driver and push it in there to unlock the master and drum.Remove the jam and switch riso off and on.
Jan 16, 2009 | Riso RZ220 Duplicator
POWER WINDOWS
It's either the passen. side window switch OR the lock function on the master switch assembly isnt right or a pinched wire that goes thru the door jam.
Try "playing " with the master switch while someone else tries the other side window switch. Also ...check for pinched wires in the door jam boot.
May 27, 2008 | 2001 GMC Jimmy
Master Lock 643D Combination Padlock Logo
129 people viewed this question
Top Master Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Master Lock and Locksmithing Expert? Answer questions, earn points and help others
