Question about Kitchen Ranges
Samsung 5.9 cu ft covection range NE595ROABSR
Reviews
  • 102 Answers
SOURCE: Samsung RS267LBBP 26.1 Cu. Ft. icemaker won't stop making ice
UP.
Posted on Aug 07, 2009
localwonder
  • 6784 Answers
SOURCE: no power. outlets is fine. please help. thanx
This will occur if the inverter has experienced a surge or, if the cut off fuse has blown. you can check the cut-off fuse by removing the cover. it is located near the magnetron tube. replace it if it is blown. if the fuse is ok, this will confirm inverter failure. replace the inverter in this case.
Posted on Aug 29, 2009
toolkits
  • 1099 Answers
SOURCE: 27 cu. ft. samsung refrigerator, side by side with
Troubleshooting an Ice Maker that won't Make Ice
Troubleshooting an ice maker is very important if you have problems with it. If you are having problems making ice with your ice maker then this is a very serious issue which will need to correct. If you are suffering from problems with your ice maker then there are a few simple things that you can do to diagnose and correct the problem yourself.
Checking the LinesThe first thing that you should do is check the water supply lines to ensure that they are not blocked. Sometimes ice can block the lines which may mean that they need to be cleaned out.
If the fill tube is frozen then this might need to be defrosted so that you can use it again. If the tube is too badly damaged then it might need to be replaced.
Broken LinesIf the lines break or become damaged then they can prevent water from getting to the ice maker. In this case the lines will need to be replaced so that you can restore the functioning of your ice maker.
Not Connected to WaterIt's also worthwhile checking the connections between your freezer and the water lines. If your freezer is not connected to the water lines, or if the tap is turned off then this will cause the same problems. There will not be any water available to make into ice. This is a very easy problem to correct and shouldn't take long to identify.
If you are not able to get any water from your freezer either then this suggests it could be a problem with the water supply. You will probably hear a buzzing noise when you're trying to make ice, this means that the freezer is trying to pump water which isn't available.
ValvesThe valve which is connected to the tap could also be damaged or broken. Check the valve opens and closes correctly and consider replacing it if it is damaged.
Too WarmIf the freezer is set to a too warm temperature then this will also create problems with producing ice. You will also notice that this isn't keeping your food as long as it should do. To correct this problem you will need to change the thermostat on your freezer so that it is lower.
Checking the Bail WireThere is a bail wire inside the ice maker which will lift when the ice maker is full of ice. This is designed to prevent too much ice being produced. If the bail wire is stuck in the up position then this will be preventing ice production.
Check the position of the bail wire by locating it inside your freezer. The instruction manual should help you to locate this wire.
SolenoidUnplug the freezer and pull it out from the wall. The water will travel to a solenoid located at the back of your freezer before being sent to the ice maker. If the solenoid is not working or is not getting power then this could be a reason for concern. If you're not skilled at home electronics then you might want to hire a specialist to help compete this task for you
Good luck
Posted on Jul 14, 2010
walterkunesk
  • 683 Answers
SOURCE: How much amps, volts and
all this is on label on equipment.
Posted on Feb 28, 2011
RyanFanMan
  • 342 Answers
SOURCE: Samsung Model DV220AEW/XAA 7.3 CU
sounds like the heating element has gone or the themal component has died. you can test it with a multimeter by setting it to ohms and putting it across the terminals of the heater and if you get a reading then it is not an open circuit after that test the thermal cutoff the same way if it has a reading then it is good but if it stays at 0 then it is no good
Posted on Mar 04, 2011
How can I clean burned tin foil from the bottom of my gas range
You may have to scrub it off using something that will not destroy the bottom material.
Sep 16, 2016 | Samsung FX510BGS 30" Freestanding Gas...
Manual available?
SAMSUNG RS261MDRS/XAA USER MANUAL Pdf Download.
www.manualslib.com > ... > Refrigerator > RS261MDRS/XAA
Samsung side-by-side refrigerator service manual (33 pages). Refrigerator ... 26 cu.ft. french door refrigerator rf267aebp user manual (ver.0.4) (44 pages).
Samsung - RS261MDRS - 26.0 cu. ft. Side-by-Side ...
www.searsoutlet.com > Refrigerators & Freezers
Rating: 4 - ‎228 reviews
Side-by-Side Refrigerator - Stainless Steel (RS261MDRS) at Sears Outlet today! ...Overview; Specifications; Manual & Warranty; Reviews ... 26 cu. ft. for greater space, convenience and access - Spacious enough to fit about 19 bags of ...
Jan 12, 2016 | Samsung Rs261mdrs 26 Cu. Ft. Sxs...
Why won't my Samsung Front Load Washer Model # WA45H7000AW turn off automatically?
Samsung Top Load Washer WA45H7000AW/A2 ' Front ...
www.samsung.com > ... > Top Load Washers
Samsung Electronics Rating: 3.9 - ‎254 reviews - ‎$699.00
4.5 cu. ft. Capacity. Washer capacity has a direct impact on how much time you spend doing laundry. ... Top Load Washer with VRT (White) ... Owner's Manual.
Oct 16, 2015 | Samsung Washing Machines
Samsung over the range microwave oven model# SMK9175ST the microwave part stopped heating
If "everything" works and your microwave just stopped heating, the problem might be with the internal door switches, the high voltage circuitry, or the circuit board or quite probalby your magnetron is dead. If you don't have the technical knowledge to repair microwaves, you should take it to a repair service for diagnostics.
Jul 16, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
I want to convert my Samsung FX510BGS gas range to propane
You have to order from a Samsung supplier GPL type nozzles for each burner, including the oven and replace the original who was factory installed.
Oct 14, 2014 | Samsung FX510BGS 5.8 cu.ft. Freestanding...
My microwave is not working at all. It is showing a code that says E-5 or S-5, I can't tell. What is this?
Sorry to hear your having problems! Are you able to reach the plug, if so try unplugging it and plugging back in! This may reset your microwave? If not, here are a couple of website links you might try...
www.applianceaid.com/procedures.html
www.espares.coo.uk/advice/microwaves/a/2 This one shows Videos!
Or you can do a web- search typing in: Samsung Microwave 1.8 Cu Ft Codes
If you would like me to do the searches for you, I'll be happy too, just reply back.
Kind Regards!
Martie
Sep 15, 2011 | Samsung 1.8 Cu. Ft. Over-the-Range...
Kitchen Ranges Logo
259 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
