Question about Maxtor Hard Drive
Maxtor 160gb External Hard disk stoped working
Please any1 can help me in external hd has just stopd workin.. it just has this light on and is makin some kinda weird do i get to make it right :(
  • shreyas_cn Mar 23, 2009
    when hard drive is connected it says usb not recognise
  • Anonymous Mar 31, 2009
    My Maxtor stopped working, all I hear is a clicking noise, the power light is still on. When I go to My Computer I cannot view the icon for the maxtor. What do I do?
Do you have two males, if so one of them , the one with the two leads coming out needs to go into a usb port that gives out a charge , not all of them do, so try all your ports individually until yiu find the right one i had the same problem with mine when i first bought it hope this helps,,john i
Posted on Mar 25, 2009
  • 252 Answers
You're probablly SOL but-
Check your hard disk for errors
You can help solve some computer problems and improve the performance of your computer by making sure that your hard disk has no errors.
  1. Click on start, then computer (or my computer)
  2. Right-click the hard disk drive that you want to check, and then click Properties.
  3. Click the Tools tab, and then, under Error-checking, click Check Now. maxtor 160gb External Hard disk stoped working - getcontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=signed1 If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
    To automatically repair problems with files and folders that the scan detects, select Automatically fix file system errors. Otherwise, the disk check will simply report problems but not fix them.
    To perform a thorough disk check, select Scan for and attempt recovery of bad sectors. This scan attempts to find and repair physical errors on the hard disk itself, and it can take much longer to complete.
    To check for both file errors and physical errors, select both Automatically fix file system errors and Scan for and attempt recovery of bad sectors.
  4. Click Start.
Depending upon the size of your hard disk, this may take several minutes. For best results, don't use your computer for any other tasks while it's checking for errors.
  • If you select Automatically fix file system errors for a disk that is in use (for example, the partition that contains Windows), you'll be prompted to reschedule the disk check for the next time you restart your computer.
Posted on Mar 11, 2009
My maxtor onetouch 4 mini 160gb didnot open help me
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 25, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
The cable, where it slots into my hard drive has come apart, (the metal sleeve is loose) and is no longer even lighting up the drive, I've not been able to find where to buy a replacement, or what the...
This one looks justt what you want and is only £3.25 post free!
Oct 11, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
I have a maxtor III usb 2.0 500 GB external hard drive. the light on the front goes out and works sometimes. when the light goes out the external drive gets disconnected . i checked for loose connections....
Possibly, the USB is not receiving current enough and occasionally it resets the USB interface. Try connecting it to another system, or to a powered USB host, and see what happens.
Another possibility (but you'd need to disassemble the external enclosure and connect directly the disk inside to a SMART-capable motherboard) is that the hard disk is developing a fault.
Apr 15, 2010 | Maxtor 160GB OneTouch III Mini USB 2.0...
Any computer i connect to it is not accessing the data, but it recognizes that it is there. I just want it on long enough to move data to my computer.
you have to "mount" the hard drive..... search that terms out in conjunction with your operating system name and you should be okay
Apr 12, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
Cannot get external hard drive to work
- Make sure that the hard drive (HD) is properly connected to the computer.
- Try connecting it to a different computer to make sure that the HD is the problem.
- Check the Disk Management in your computer to see if the HD could still be detected. Once detected, reformat the HD and it should work again.
To check the Disk Management:
NOTE: Make sure that the external HD is connected and turned ON.
1. Right-click "My Computer" (XP) or "Computer" icon (Vista)
2. Select Manage and click on "Disk Management".
3. From the Disk Management, you will see a drive letters
4. Write down all the drive letters and then disconnect the Maxtor HD from the computer.
5. If there's a drive letter that disappears, then that is your Maxtor HD.
6. Reconnect the Maxtor HD and reformat it. You may right-click the drive letter and there's an option to format the HD.
If you're hearing a clicking sound while the HD is turned on, mostly, it's already defective.
Have a great day!
Oct 17, 2009 | Maxtor Hard Drive
Maxtor basics 160gb portable hard drive is showing error performi
go to my computer p[roperty then hardware -> device amnager then uninstall usb drivers from it then install aagain.
then connect your harddisk then it found.
Jun 23, 2009 | Fantom Drives Titanium II (TFD160U2) 160...
Broke external hard drive
It depends on how badly bent it is. If you're stable with your hands, and can use a small nail to pry the deformed peice straight, do so carefully. If however you absolutely need to save the data on the drive and can't afford to have the bent peice fully break off, take it to your local computer repair store and they should be able to replace the connection.
May 05, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Does it give you an error message ? Are you running Windows XP or Vista? If so post it here so the problem can be further narrowed down.
You might want to try a chkdsk.
In Windows XP and Vista both, a shortcut to get to the command console is holding the Windows Key and pressing R.
in the command console, type:
chkdsk X: /f /r
Where X is the drive letter of the drive giving you problems.
This will run a chkdsk on your external, restoring files and folders that cannot be accessed.
I also have a Maxtor External hard drive and have to do this quite often. It's pretty frustrating.
Apr 04, 2009 | Maxtor 160GB OneTouch III Mini USB 2.0...
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
Maxtor Hard Drive Logo
306 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
