Question about Maytag Dryers
Dryer won't come on
Admiral Electric Dryer won't turn on----nothing
Light comes on when door is open so it is getting power.
Close door and push button-----Nothing
  • steve
    steve May 11, 2010
    Replace the thermal fuse and the hi-limit thermostat located on the heating element canister.
    Make sure your vent is clean before restarting the dryer.
  • 686 Answers
And also change your cycling thermostat if your thermal fuse is bad chances are the thermostat is bad too
Posted on Mar 12, 2009
Door is ajar message when shut light comes on but doesnt run
That's because the door switch isn't getting pushed when you're closing the dryer door for some reason or another. Its located at the top of the door. Try pushing the switch by hand and seeing if the light shuts off when you manually push it.
Nov 27, 2013 | Samsung DV337 Electric Dryer
Dryer won't start..light clicking noises
There is a switch inside the unit that stops it when the belt breaks or comes loose. Check that.
Mar 15, 2017 | LG Home Applaince LG DLE2101W 7.3 Cu. Ft....
Ge repair manuals
The fuse is a we4x800. It is mounted on the heater housing on the back wall of the dryer.
Apr 30, 2013 | GE DCSR483EA Electric Dryer
I have a bran new Admiral dyer that won't work
The dryer may have been wired incorrectly, e.g., 115v rather than 230v.
May 23, 2017 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
MAY MAYTAG DRYER WONT START I HAVE POWER WHEN I PRESS THE START BUTTON IT SOUND LIKE IT SHORTED OUT
HI
Need to know what the unit does, Buzz, nothing? Because if it buzzes it could be a clogged blower or bad motor, its important to know this information.
Please get back to me
Sep 08, 2011 | Maytag PYE2300AY Electric Dryer
I did a load of laundry and everything was fine. Later I put another load in the dryer and pushed the button and nothing happened. When you open the door the light comes on and then when I close the door...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 04, 2010 | Whirlpool LEQ9858P Electric Dryer
Dryer has power - we can hear the timer ticking and the light comes on when the door is opened, but when we push the start button nothing happens model # leq9558ko 8 yrs old electric
does the light close when the door is closed??? poosible that the door switch has gone bad. or a bad thermal fuse behind the unit is also a common culprit of this.. its a white thermostat on back of unit behind the panel (-----------------------) approx this long ad white,,
Oct 13, 2010 | Whirlpool LEQ9858P Electric Dryer
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
I have an electric dryer. The breaker went off and when reset the dryer would not come back on. I am not sure if the push button on/off switch is now working or if there is a reset on the dryer
I have a Kenmore 80 series electric dryer. The light comes on when the door is open so I know it is getting power but dryer will not turn on. Is the push button not working or can I reset the dyer?
Dec 06, 2009 | Roper REX4634KQ Electric Dryer
Dryer not starting
Luckily, these units usually have a wiring schematic on the back, if not google it. The first thing on a washer or dryer to fail is the door switch. It's easy to replace or bypass. After that the start button itself may be bad. Follow the circuit, be careful. Use a continuity meter that beeps to check stuff. You mention a light. That means the door switch controls the light and the dryer, there will be a normally open leg and a normally closed leg. Good luck.
Nov 18, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
146 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
