Question about Danby Refrigerators
Danby fridge-YEAR- 2011 Model-SFF1144W-RH -- Why won't my fridge motor/fan turn on? Ev erything was fine 12hrs ago and now just the lights come on but everything's melted.
Year 2011 Model SFF1144W- RH
HVACRH20
  • 237 Answers
SOURCE: Fridge/Frezer stop working
Can you tell if the compressor (black soccer ball looking thing in the rear of the unit) is running? Is it really hot? Is the little fan running near it? If the compressor isn't running it won't cool. Also check that the coil in the freezer section isn't frozen solid blocking all air flow inside the unit. The other thing is that the defrost cycle may be "stuck" so it thinks it should be defrosting (therefore not running the compressor, etc.) Lots of things to check but that info will help decide which way to go so post what you find please.
Posted on Dec 31, 2006
aborcass
  • 2651 Answers
SOURCE: refrigidare model # plhs267za
sounds like the air damper control for refrig is freezing in the open positon. not a really consumer freindly repair,(dropping side control panel checking damper door for ice build up, removing ice and applying a silicone lubricant(vasiline) to prevent further freezing of air damper motor. sounds easy enoug but that panel is real tricky to drop and mount back in.
Posted on Mar 04, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
appldoctom
  • 311 Answers
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Posted on Jan 30, 2009
  • 363 Answers
SOURCE: maytag french door fridge crapped out....again
buzzing sound comes from freezer fan or ice maker fan. They are located behind the freezer rear wall. These freezer fan cools the freezer and the refrigerator. The ice maker fan supply air to ice maker.
Posted on Jul 22, 2009
GESS25LGMB WW Side-by-side fridge/freezer won't cool.
call a repair service it probably need freon added to system and that is not a consumer FIX
Aug 27, 2017 | General Electric Refrigerators
Noisy fan problem solved..... at least for now.
Not familiar with Danby or wine coolers, but I have messed with enough appliances including fridges. The same exact fan and motor are often used by different manufacturers and are "off the shelf" items you can get at most appliance parts suppliers. See if you can get any part numbers or info off the fan motor or from Danby's web site. Then see if a local supplier has one. If the fan has spade connectors, you may be able to swap it out without having to cut/splice wires.
Oct 15, 2012 | Danby DWC283BLS Wine Cooler
Fridge won't cool past 57 degrees
Guessing ether a fan, damper our defrost issue. Sorry cant be much help.
Aug 19, 2012 | Samsung RF266ABRS Bottom Freezer...
2011 hyundai sonata won't start. battery seems fine. loud clicking/knocking when i turn the key. would it be the starter?
Unusual for the starter to fail on a one year old car.
You are having it towed to a dealer for warranty repairs, right ?
Jul 01, 2012 | 2011 Hyundai Sonata
My fridge gets really hot on top and between the fridge and freezer where the door meets
next time send the model number and brand name.usually when this happens is the condenser fan motor isn't working.pull the fridge out,remove the bottom back panel and check the fan to see if it's working,if it is check the condenser coil to see if it's filled with lint and dust,it could just need to be cleaned out but if it's that hot most likely the fan isn't running,if you get this tonight check it now,if the fan isn't running you could blow the compressor,the condenser fan blows and keeps the compressor cool enough so it doesn't overheat by moving the hot air and the heat also esscapes through the condenser coil so if that's clogged with dust the machine will run hotter than normal,if the fan isn't running you can stick any window fan back there and blow it onto the compressor to keep it cool until you fix the condenser fan motor,this way you won't loose any food and if the compressor goes it's new fridge time,to much to repair.hope this helps and good luck with your machine.one more thing,i've found the fans not running and by pushing the blade it runs again,if this happens the fan could run and never have a problem or it could stop an hour later but i would change it out no matter what.if it's a G.E. fridge and the motor isn't running,most likely it will be the computer board,i've found 10 machines doing this and the temp. settings turning on and off or the evap fan motor in the freezer runs slow and then fast and the condenser fan isn't running or running slowly,this is why you have to send the brand name and model number.
Oct 28, 2011 | Refrigerators
Our Danby model dpac 11006 was working fine yesterday but came to put it on today just to find out the ac doesn't work the fan still blows just no cool air . we do hear something in and out like a...
The intermittent sound you're hearing is probably the compressor trying to start. This could be caused by a bad circuit or the compressor motor is seized If the latter is the case, it's time to start shopping for a new AC. As the cost to repair would be almost as much as a new unit depending on the age of your unit. However, compressors usually have a 5 year limited warranty. So check you Owners Manual for details. It may still be in warranty.
Hope this helped you and thanks for choosing FixYa.
Aug 11, 2011 | Danby Portable Air Conditioner
I have a DPAC 13009 that was purchased a year ago at COSTCO. It has worked fine until now. It began making weird noises and then kept shutting off. Upon further examination there were pieces of white...
From your description, I would have to agree with you on the pieces being from a broken fan. The good news is, that your model has a 24 month in home service warranty, so the parts and labor to repair are covered. But, the real key is having a Proof of Purchase. Armed with that, you're good to go.
Contact Danby Consumer Support 1-800-263-2629, to file a Warranty Claim.
I hope this helped you and thanks for choosing FixYa.
Jul 26, 2011 | Danby DPAC12031 Air Conditioner
Refrigerators Logo
197 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
