Question about Brinkmann 5 Burner with Smoker 8101750S
Changing burner orfices on a brinkmman grill - Brinkmann 5 Burner with Smoker 8101750S
I have a Brinkman Gas Grill Elite dual Sear 5 Burner.
Check the reg sounds like its not giving full rate
Oct 08, 2017 | Brinkmann Grilling
My grill has full propane bottle but doesn't seem to be getting propane! Any help would be appreciated.
Check there is gas at the burners and that the orfices are not block or the burners are bot blocked .
Turn on burners let pressure out of line turn off tank remove gas line then reconnect to tank and turn on tank slowly see if this works
Mar 12, 2012 | Weber Baby Q Grill
Why can't I get rid of the yellow flame in my gas grill? I've replaced every component - propane tank, valve, venturi tube, burner, regulator etc. Still...the flame burns yellow and creates soot.
You have the wrong orfices in the gas manifold...they are too big and they are allowing too much gas out...if you are running LP gas and you have natural gas orfices it will do that...that is what I think your problem is...
heatman101
Aug 13, 2010 | Thermos Gas Grill 4617222
My grill is not working. What could be the
The first thing you will need to do is try lighting the burner manually with a match or bbq lighter. Bring the flame next to the burner then turn on the griddle knob. It should light up. If it does then it is either a weak spark on the ignition system due to debris on the electrode or there is blockage in the burner eyes at the electrode. Try poking out the eyes of the burner with a safety pin or sewing needle. And try using a wire brush to lightly clean the electrode head(where the spark comes from). If your tried lighting the burner with a match or bbq lighter and it did not light or a very small flame came out then there is a restriction in either the burner eyes, venturri, or burner orfice. Frist inspect the burner eyes for any blockage(grease or particles of food) and then use the sewing needle or safety pin to clean out all the burner eyes. If the burner is easily removed then go ahead and remove it and check the venturri(burner pipe) for any debris inside it. A small bottle brush can be used to clear the venturri. And finally with the burner removed you should be able to see the burner orfice. It will look like a small nut(usually brass) with a very small hole in it. This is where the gas comes out and if this hole becomes plugged then the burner will not work. The best way to clear this hole is to use a very small wire like the wire on a sandwich bag tie strap. Burn the plastic off of the tie strap to expose the thin metal wire and then use the wire to clear out the hole. DO NOT USE ANYTHING LARGE to try and clear out this hole. It is tiny for a reason and the soft brass can be opened up easily while try to clear the orfice hole causing a huge increase in gas pressure. If you clear the orfice hole and still do not get any gas pressure then the next step would be to remove the orfice(this requires a orfice wrench) and verify that you get gas coming from the burner tube with the orfice removed. If you do not get any gas after removing the orfice the more than likely the problem lies with the burner valve restricted internally and will need to be re-built or replaced.
Apr 24, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Convert a 2009 S-320 LP to NG ?
Most grille or outdoor type stores (bass pro, walmart, lowes)sell the burners to swap the fuel type. The orfices in the burner are what is different and you must change it or complete combustion will not occur and your meat will taste horrible.
Mar 17, 2010 | Weber Spirit SP-310 Propane Grill
I can not get any gas pressure in main burners or side burner, i have a new propane tank, just a trickle of gas not even enough to keep side burner going when only using side burner, will only produce a...
Look for spider webs in the venturi tubes, check the orfices or it could be faulty controls. Verify the tank working properly by trying on another grill.
Eric
Jan 24, 2010 | Brinkmann Charmglow 810-7400-S Propane...
Orfices for the grand turbo double side burner
bbq galore call 214-696-0030 even if your not in dallas they can send them to you
Aug 22, 2009 | Barbeques Galore 38" Grand Turbo built-in...
What are the btu ratings for a jenn air model 720-0100 ng grill. i am converting this to lp gas...
does not matter just change out the orfices on all burners and back burner even if you have a IR buners, the orfices let enough gas in for your grill call jenn air they will sell you the kit to convert it over
Jul 29, 2009 | Jenn-Air Grilling
Low pressur on gas grill
orfices are possibly clogged with spider web
and the check to see if your dial on tank is fully open and check to see if your tank is almost empty...
Jun 01, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Brinkmann 5 Burner with Smoker 8101750S Logo
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
