Question about Motorola iTECH iQfive iQplus -VISAR Compatible Two Way Adapters 2-Way Radio
Motorola DM3600 Reset
Motorola DM3600. I have corrupted the code plug while in the Tuner mode. The radio works fine but I am no longer able to adjust the power level. Do you know a way of resetting the Tuner to default or the whole radio to original factory settings? The RSS still works fine.
  • 11,896 Answers
Rather that typing everything here. I will give you a link to a website with the instructions to reset your motorola. (copy and paste this link in your address bar)
www.pce-exeter.com/radio.php?pageNum_all_radio_products_filtered=2&totalRows_all_radio...25...Motorola
Posted on Mar 11, 2009
Auto tuner detects no signals
D a reset to this set, and check. If it do not help you, the main system control memory IC to this set is faulty, and should he replaced. Contact any service technician. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Dec 04, 2014 | LG 32LC7D Television
How to reset dm3600
Contact Motorola Solutions.
Get Support
Mark Motorola Mobility Support
May 17, 2014 | Motorola Dm3600 Digital Mobile Radio With...
Radio worked fine......then I was trying to find another channel by turning the tuner knob and all of a sudden it just locked and when I turn the tuner knob it won't change stations. Nothing works but the...
This may help: If you take off the front of the radio (don't forget 2 screws in back!) you will notice a set of black and red wires running from the 2 AA backup batteries to the digital display circuit board. The wires plug into the board with a little white plug. If you unplug this the display will fade to nothing. If you plug it back in it will display an unset digital clock format. This seems to reset the radio, after which it should work.
Feb 08, 2011 | Dewalt DC011 AM/FM Radio
I have a Motorola Talkabout T5710. I no longer
Perhaps the privacy code has been changed on one of the radios? If you have a manual follow the instructions for setting the codes and make sure they are the same on both radios.
Jan 01, 2010 | Motorola Talkabout T4500 (7 Channels)...
The sound stopped working on my koss KS2503. Yesterday everything worked perfectly fine. Today there is no sound. Everything else seems to work. I checked all the connections and have had no success. Is...
unplugg your tuner from the AC wall outlet then check the setting on the tuner do not try to watch and listen to the tv only try to listen to the radio or a CD and select the right option on the tuner to do so. If you have sound on any of the functions....radio or CD/MP3 then the problem lies on the setting not correct for the TV/VCR/DVD mode.
Sep 12, 2009 | Koss KS2503 System
After reading programming Radio Died
Unfortunately you have a corrupted code plug. The radio will need to be serviced to clear the corruption. Or if you have a clean copy of the original programming, you can try reprogramming it. (Note: Do not use the version you had saved which led to the corruption.)
Aug 24, 2008 | Motorola For MT1000 MTX800 MTX90010v...
Car Radio
I have the same head unit and disconnected from the battery. There was no input code required when reconnecting the battery You should be ok! I can't help with your Tuner problem though! Good Luck!
Aug 20, 2008 | Sony CDX-L580X CD Player
Xm radio
How do you use fm radio signal to access speakers, in lieu of cassett adapter?
Jul 22, 2008 | XM Radio (XMP6000)
Pioneer X MT- 2000 Stereo Bookshelf Unit - No sound!
It definitely sounds like it took a surge. yhe Power Amop IC in those things are pretty sensitive. Any decent repair shop should be able to repair it for under $125.
Sep 18, 2007 | Audio Players & Recorders
Motorola iTECH iQfive iQplus -VISAR Compatible Two Way Adapters 2-Way Radio Logo
215 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
