No sound I have polk audio speakers and there is no sound when i plug them in and my computer cannot find them on new hardware i don't have a specific on the type of speakers there is no info on them
    Problem Solver:
  • 5 Answers
Run the software program again dont plug the speakers in till the software has completed.
Posted on Mar 12, 2009
I have windows xp, my speakers are Polk Audio HP-3, I am not getting any sound, but they play in other things..can you help me please?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 09, 2011 | Polk Audio AMR50 Computer Speakers
I DON'T HEAR ANY SOUND. BUT SOMEONE HAS WORKED ON MY COMPUTER. HAD TO PUT IN MOTHER BOARD. IS THERE AN UPDATE I CAN DO?
also
hope this helps
don
Feb 27, 2011 | Polk Audio AMR50 Computer Speakers
How do I install Polk audio speakers on my computer?
plug the speakers into the speaker outlet usually at the back of a computer then
hope this helps
Oct 26, 2010 | Polk Audio AMR2 Computer Speakers
I have polk audio speakers that came with my old hp f50. I just purchased a new hp but can't get my speakers to work
The old speakers are not compatible. Your new computer is looking for an external power source for the speakers, the older polk speakers that came with Hp computers have none.
Sep 15, 2010 | Polk Audio AMR50 Computer Speakers
Speakrs don't work on new HP Pavilion desktop.
If you're using Windows XP, go to the Control Panel, then double-click on Sound, then go to the Audio tab and make sure the playback device is set to your Realtek output.
If you're using Windows Vista, go to Control Panel and click on Hardware and Sound, then click on Sound. Make sure your Realtek device is selected with a green check mark. If it isn't, just click on it and then click the Set as Default button down below. Vista sound configuration is kinda quirky, and it does do some kind of detection when you plug a cable into an audio jack, so you might leave this screen up while you plug your speakers into the green audio jack in the sound card and see if it pops anything weird up.
Apr 17, 2009 | Computers & Internet
My polk audio speakers volume wont go up
i have 2.1 creative sound speaker .after system formattednosound observed.pse solve the problem.
Dec 07, 2008 | Polk Audio AMR50 Computer Speakers
Polk speakers with Windows Vista don't work
I doubt the speakers need a driver. Is there output from the soundcard? Connect the speakers to an alternate audio source, such as the headphone jack of a CD player or radio. If the
speakers produce sound, the problem is probably
with your soundcard. Recheck your soundcard
installation and setup procedure. Consult the sound
card’s manual. Check the “mute” and “volume” controls on your
soundcard or media player software and keyboard.
Are the speakers connected properly? Make sure the
plugs are securely connected in the proper location
according to their colorcoding and the diagram on th
front of this manual. Make sure the left speaker wire
with the white stripe is connected to the (+) speaker
terminal on the subwoofer.
Dec 03, 2008 | Polk Audio AMR50 Computer Speakers
Can i add any speakers to my dell vostro 200?
No you don't. As long as you can plug the speakers to the green port on the back of the computer, the speakers are powered and the volume knob on the speakers is turned all the way up. You should hear sound.
Also make sure the sound is not muted in windows.
Sep 27, 2008 | Dell A215 Computer Speakers
Low sound from speakers.........polk audio speaker
Hello Minikish
well, some DELL models, have an internal audio, and it is cheap sound card, others have problems with this sound cards, and must be replace. or if you want to buy a PCI X-FI from creative, really Rocks the sound to a new level 5.1 surround sound, up to 7.1
Dec 06, 2007 | Audio Players & Recorders
61 people viewed this question
 Grubhead
Grubhead
