Question about Pioneer VSX-D2011 Receiver
My pioneer VSX D2011 cuts to standby when playing music
Seems to be fine when the TV is running through but cuts out when i use either my DVD player or PS3 for playing music.got a party on Saturday so need help please!!!!
  • jim_hughes Mar 12, 2009
    thanks very much a very usefull service with oustanding advise.world claass.kind regards jim hughes
    Novelist:
  • 98 Answers
Your receiver is basically going into protect mode.
Are you pumping up the volume when you connect the TV?
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate. Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck and have a great party!! Thanks for using FixYa!
Posted on Mar 12, 2009
Why will my pioneer bdp-lx70 play only cd's and blu ray discs but not any ordinary dvd's ?
Check and replace its laser pickup unit. If you wish to get some details; check the site linked here. Pull up older posts.
Nov 26, 2012 | Pioneer BDP-LX70 Installed
Stereo without sub woofer how this setting
i have -VSX-D2011 when i want to stereo mode the sub woofer is automatic
play in stereo mode and disturb
i check all setting and much time waste on manual instruction
Stereo mode play only two front speakers if any one have knowledge about setting please help with advance thanks
Jun 26, 2012 | Pioneer VSX-D2011 Receiver
No TV sound, only DVD and CD players
Check your tv settings may need to change from speaker out to line out.
Check the tv input on the receiver, put the cd or dvd cables into the tv input. If you get audio the receiver is fine. No audio check the receiver settings.
Nov 16, 2009 | Pioneer VSX-54TX Receiver
I have the Multi Channel VSX-D2011 which is fine when used at low volume. As soon as the volume rises to a fairly normal level the amp cuts out and switches off. Any ideas?
Hiya,
First try checking all the speaker cables and speakers. Listen to them all make sure they are all playing when playing softly, if not there could be a short in the speaker cable/speaker causing it to protect. Another way, disconnect them all and connect one at a time, test it etc, when the fault re-occurs, in that line.
If thats not it then sorry will have to go to a tech as it sounds like protection is kicking in or PSU fault
Jul 07, 2009 | Pioneer Audio Players & Recorders
Problems with Sharp Blu Ray Player "copy protected signal"
Possible solution: You set up your remote to run your amp from the TV control, using the AQUOS Link. Even though your amp is out of the loop, it's still recognized by the TV. You might have to reset the TV back to default and run the AQUOS Link again.
Apr 19, 2009 | Pioneer VSX-D514 Receiver
Proper input for TV audio signal
Do you have your DVD player running through your receiver? You want the red and white (audio) cables to go from your DVD player to your receiver and the yellow (video) cable to go from your DVD player to your TV. Separate the red, white, and yellow cable into separate strands if you need to, but be careful not to tear the insulation. They should pull apart fairly easily. If I'm totally off or you're using a coaxial or component video/audio cables or a fiber optic cable, let me know. Hope this helps
Feb 16, 2008 | Pioneer VSX-D812 Receiver
Pioneer VSX-D509S 5.1- No voice audio on DVDs
try the dvd player settings to bitstream out in setting menu ok not pcm best to use coxal cable to get fiull 5.1 suround
Jan 20, 2008 | Pioneer VSX-D509S Receiver
DVD movies do not play
A blue screen means the TV is not receiving a video signal. Check all connections, then try another player, cable, etc. Also, check DVD and TV AV settings.
Dec 10, 2007 | Pioneer VSX-D912 Receiver
HDMI Compatibility
It sounds to me like you have a HDMI Control issue. It sounds like the DVD player wants to control the receiver. Try turning off hdmi control on the TV, reciever, and the dvd player in their setup menus.
Let me know if this helped,
Joe
Oct 03, 2007 | Pioneer VSX-81TXV Receiver
Pioneer VSX-D2011 Receiver Logo
368 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
