Question about Kenmore Freezer 14.8 cu. ft. Manual Defrost Chest Freezer
Defrost freezer with wd40
I have an older chest type freezer and want to know if it's safe to use WD40 to help to defrost it.
4 Suggested Answers
  • 1462 Answers
SOURCE: freezer/kenmore
the settings usually are:
off - on - superfreeze. you just want "on"
Posted on Nov 16, 2008
tborn6
  • 700 Answers
SOURCE: Can I Mount Casters with Screws into Bottom of Chest Freezer?
youyr best bet would be to build a frame that the casters are welded to and there are no holes in the outer shell of the freezer. some L shaped angle would work nicely for this application and then there would be plenty of support for when the freezer is loaded up with product. Be sure that teo of the casters are lockable and two in the swivel freely.
Posted on Dec 27, 2008
  • 10865 Answers
SOURCE: Only one half of my chest type freezer freezes?
My recommendation is to get rid of this 18 year old freezer as it is costing u a fortune to keep it plugged in. Then ask yourself if you really need an additional freezer at all?? If you do, consider purchasing a new small one that is really energy efficient. You will be way money ahead I assure u.
Posted on Apr 26, 2009
I cleaned my freezer and now it won't freeze
When you say "cleaned", did you defrost it? And. if so, could you have damaged the internal lining? Often the coil inside the wall of a chest freezer can fracture if hit or stabbed at during defrosting.
Other than that, is the compressor running (you would hear it)? it may have overheated. If not running, see if it feels hot (siezed) or cold (no power from thermostat). If cold, put it on fast freeze and see if it kicks into life (thermostat faulty) or not (compressor fault, time for a new freezer!)
Let me know how you get on!
Jul 05, 2012 | GE 14.8 cu. ft. General Electric Chest...
What type of light bulb does the freezer use
May I get the model # so I can help you get the right bulb
Aug 22, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
I don't know what the lights mean on my Beko chest freezer. Have just found it defrosted and want to make sure the defrost is off. It is switched on at the mains. What lights should be on? I've lost the...
two reds and green are the auto max freeze on indecators the reds go off one at a time when unit drops to safe temp mode.also means unit needs defrosting manually when too much ice is present.
Feb 03, 2010 | Freezers
I have a Kenmore chest type frost free freezer
I am not aware of a chest freezer that is auto defrost.Go ahead and defrost it like you would any chest freezer. Eric
Aug 10, 2009 | Freezers
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
General electric 5.0 chest freezer has water coming all over the floor.
The reason this happens is because the defrost timer is not turning back on when it needs to, causing the freezer to thou out and overfill the drip tray sitting on top of the compressor. A new defrost timer should be available from the local refrigeration wholesalers in your area.
May 11, 2009 | General Electric Chest Freezer FCM5SU
Freezer/kenmore
Nov 16, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Kenmore Freezer 14.8 cu. ft. Manual Defrost Chest Freezer Logo
59 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
