Question about HP LaserJet M3035 MFP Printer
The display on my M3035 does not show an administration menu
From computer How can i scan document from HP LaserJet M3035 MFP
From the search I did that printer is not an all in one and does not hacv a scanner function
Feb 13, 2016 | HP Office Equipment & Supplies
110/1003 (0X3EB)
on HP Laserjet m3035 MFP can not scan in PC we have WIN 7 32BIT edhe show error code 110/1003(0X3EB) Help me
Dec 16, 2013 | HP LaserJet M3035 MFP Printer
How to get print count off of an HPLJ3035MFP
Usage page
Shows a page count for each size of
paper printed, the number of one-sided
(simplexed) or two-sided (duplexed)
pages, and the average percentage of
coverage.
1. From the Home screen, touch Administration.
2. Touch Information.
3. Touch Configuration/Status Pages.
4. Touch Usage Page.
5. Touch Print.
Nov 30, 2012 | HP LaserJet M3035 MFP Printer
I have a laserjet m3035 no display on screen 2 LED light not work
Shut down the printer and remove the power cord. Leave the unit off for a minute or two. Replace the power cord.
  • 2 Press the "Power" button on the printer. Hold down the "Select" button on the printer as you turn the unit on. Continue holding the "Select" button until the LED lights on the printer flash once and then remain on.
  • 3 Use the up arrow to scroll to "New Maintenance Kit." Press the "Select" button to reset the maintenance kit counter.
  • Oct 20, 2011 | HP LaserJet M3035 MFP Printer
    My touch screen doesn't respond to touch and I am unable to make copies.
    Does it respond to any touches or is it greyed out? This problem can be caused by either a bad touch pad or a defective scanner. Try accessing other options on the front such as the administrative menu. If those work, then the scanner might be bad or locked? Lift the automatic document feeder lid and check the lock on the left hand side to make sure the scanner is not locked. Restart the machine as well, could be an intermittent problem or static discharge.
    Jun 06, 2011 | HP LaserJet M3035 MFP Printer
    Hp m3035 won't print page comes out warm but no toner
    Load paper in tray 1. Print a few pages, as it's printing open the top cover, remove the toner, look at the paper in the printer. Does it have printing on it? If it does, the laser/scanner is working. It could be the transfer roller, it could be Hi Voltage Power Supply. Look in Print Quality Menu/Toner Density. Increase the density.
    Mar 10, 2010 | HP LaserJet M3035 MFP Printer
    No Icons show up
    When you have your desktop up & displayed, click the right mouse button & it will bring up a menu. Hover your mouse above the "Arrange Icons By" option and it will bring up a sub menu. If the "Show Desktop Icons" option does not have a check mark to the left of it, that is your problem. If there is no check mark, navigate down to it and click on it with your left mouse button and that will make your icons display.
    May 20, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
    HP LaserJet M3035 MFP Printer Logo
    109 people viewed this question
    Seeker5211
    Seeker5211
