Question about Troy-Bilt Electric Cultivator Tb 154 110v 6.5 Amp Motor
Troy bilt electric cultivator will not start
Have checked electrical connections and they are good....
5 Suggested Answers
  • 9 Answers
SOURCE: engine stalls when engaging cultivator tines
im 99 percent sure all you have to do is get the carburator cleaned out.
Posted on Jun 28, 2009
  • 26 Answers
SOURCE: troy-bilt horse engiine runs good , tines work,
The wheel shaft on a Horse tiller is one piece so if the shaft turns on one side it will turn on the other. make sure the pin that holds the wheel on is not missing that would let it spin on the shaft.
That's the only thing I can think of that would cause that problem. Hope that helps.
Frank
Posted on Oct 07, 2010
  • 4 Answers
SOURCE: I have a 4 cycle Troy Bilt TB144 cultivator and
hi remove pull cord and replace the pins
Posted on Sep 03, 2011
Electric start on Troy Bilt 21" single stage snow blower doesn't work. Recoil starter does. Electric start worked last year, but today, nothing. All cords good, power, etc.
The starter could be bad. Remove starter and see if it will turn over when 120v is applied.Check the wires to starter first! Good-Day!
Nov 16, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
How do you clean the carberator on a tb110?
Take the bowl off of the carburetor take off float and remove needle.
clean the needle the reinstall everything.
That usually take care of the problem with small engine fuel problems.
Jun 10, 2014 | Troy-Bilt Electric Cultivator Tb 154 110v...
Troy- bilt electric cultivatar tb154 wont start. Could it be the overload protection button?
it could be the overload protector or the electrical cord has broken inside so it isn't getting the power it needs or the brushes in the motor have gone out
Mar 28, 2013 | Troy Bilt Tiller/Edger 26cc, Model No....
Troy bilt G C 720 manual
I have a new troy built garden cultivator (modelGC720). It won't turn and the motor stalls when the trigger is pulled. Should I return it or is there a easy fix ?
Feb 13, 2013 | Troy-Bilt Troy Bilt Gc720 Trimmer Plus...
It just clicks when i try to start it, wont turn over
ureCheck battery charge it should have 12 to 13 volts if it is fully charged.Check all electrical connections from battery to starter and ground wires. Check the solinoid ,it must make a good electrical connection internally to make the starter motor run.If you are getting at least 12 volts to the starter motor and it still wont turn the starter may be bad. Also be sure that the engine can be rotated normally.
Jun 10, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Need an Operating Manual & a parts Manual for a Snow Blower.
Hello and Welcome to FixYa!
Here is the link from where, you can get the manual...
Click Here.
Just enter the Serial number as quoted above in the serial no; text box and click search. It contains all the link of online manuals available in this model...
Please do RATE my solution, If found HELPFUL,
Regards.
May 24, 2010 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Troy bilt hasn't been used in 2yrs.; has oil and gas in it but will not electric or pull cord start...
1st I would drain the gas and put new in. It loses octane over time. Then try new spark plug. Also you may need a new diaphram in the carburetor. They are cheap and sell them at most hardware stores.
Dec 20, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy-Bilt Electric Cultivator Tb 154 110v 6.5 Amp Motor Logo
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
