Question about Panasonic DVD-LA95 Portable DVD Player
Panasonic LA95 Portable DVD
Friend borrowed our unit in Mexico and it came back dead. We plug in the chord and get nothing. I am wondering if something happened with the charger and now it is so dead it won't give us anything. Hate to throw it out if the unit is OK and it is just the charger, but don't know how to determine....
  • bmwsss Apr 08, 2009
    Same problem. Unit does not play and charger does not show as working. I put the charger on another LA95 and the charger is working so the problem is in the unit itself.
    Problem Solver:
  • 11 Answers
Any flashing red powerlight ?? (assuming theres any charge left)
if the powerlight flashes quickly then the units kaput ( bin it)
slow flashing means the microswitch may be stuck (the one that turns off the screen when you close the lid.
you may have to be sneaky at a dealer and ask to plug in to a new mains unit ( most new panasonics still use the same power supply voltage and ampage. if it works then run away quickly and go buy a universal power supply, if it doesnt , well your in the right place tobuy a new one ??
Posted on Feb 07, 2010
Panasonic dvd-la95 is region locked What do i do?
Hi, Unfortunately there's no way to unlock the DVD player, you have to buy one that isn't region locked.
Jul 19, 2011 | Panasonic DVD-LA95 Portable DVD Player
I have just bought a Panasonic DVD-LA95 but did not realise that it is Region 1 only. I need to change it to region 2 to be able to use it here. Can you help please.
you need to check that it supports pal output, if its a european unit (check the manual and player bottom for the ce mark) then it will play pal discs and will need reverting to the multiregion upgrade ( a disc and a few button presses about £20 online)) if its an american unit then it wont play pal discs even if you do manage to multiregion it.
Jun 25, 2009 | Panasonic DVD-LA95 Portable DVD Player
Stopped working while running.
flashing power light ??
thought you had to turn them off to charge it.
Jun 02, 2009 | Panasonic DVD-LA95 Portable DVD Player
Flashing red light Panasonic portable DVD-LA95
check the microswith near the hinge . its generally located on near the back right corner of the player , on the control surface. it looks like a very small white plastic button or pip. sometimes these stick down and look like part of the player casing, when they actually are a switch. it needs to be raised , so when the lid is closed it pushes the pip down and turns the screen off. Try prising it gently free with a pin or needle. this happened tome and i was on the verge of binning it. when i looked at the manual and it says power light flashing slowly means screen turned off.
if the light is flashing very quickly then im afraid its knackerred and just not worth repairing.
if this is helpful to you then just drop me a line at choonzy@googlemail.com
good luck
choonzy
Jan 03, 2009 | Panasonic DVD-LA95 Portable DVD Player
PANASONIC PORTABLE DVD PLAYER ERROR CODE 3. MODEL NUMBER LS5
This could be the laser going or a dirty track. I suggest that you first clean the laser gently. If this doesn't work you must take the player apart and clean the track that the laser moves on along with everything around it (keeping in mind that the laser is fragile).
Dec 03, 2007 | Panasonic DVD-LA95 Portable DVD Player
Getting sound from speakers when heaphones are plugged in.
Hi,I know that the earphone jack usually has the switch built in, and often it takes a certain "End Shape" on the Headphone Plug to actually "Activate" it... I am wondering if this is not actually your problem? and maybe ya just gotta get the "Right One"? Sometimes I have seen the "Switch" in the Jack fail and cease to "Cut out" the speakers... which generally means replacement.
Aug 31, 2007 | Panasonic DVD-LA95 Portable DVD Player
Screen very dark
hi sir you got a burnt fluriecent or a deffect transistor driver to it refer to qualified person to re change , but this is the fault sharply cost i2 20$ please don't forget to do excelent rate cause i here to help you regards
May 06, 2007 | Panasonic DVD-LA95 Portable DVD Player
Panasonic LA95
You bought it on Ebay ! ! Why did the seller move it on...
I suspect that the decoder is getting 'hot' - same principle as the processor on your PC.
If you are able - I would suggest opeing the unit up (so that the main board is visible) but still able to power up.
Obtain a hair dryer that has a 'cool' blow on it. Start your unit up, while blowing with cool air - this will identify if this is thermal related...
Sep 07, 2006 | Panasonic DVD-LA95 Portable DVD Player
Panasonic DVD-LA95 Portable DVD Player Logo
149 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
