Question about Craftsman Air Tools & Compressors
Air compressor regulator installatlion
I just bought a regulator, part # AC-0007, for a Craftsman air compressor, but it came with no directions. The housing of the regulator has a small arrow embossed on one end, but I am unclear whether the arrow should point toward the body of the compressor or toward the air hose. Please advise me. Compressor is mod # 919.165250
    Problem Solver:
  • 17 Answers
The arrow denotes direction of air flow; It should point towards the air hose connection(s)
Posted on Mar 14, 2009
Craftsman compressor
Prior to starting the unit. Look at the pressure gauge. 1. Make sure the regulator is set to the desired PSI. 2. Make sure the unit is connected to an AC circuit that is required to support this machine. If you have high end AC outlets that are intended for a low power i.e. 10 AMP and you connect this unit to the circuit it may disconnect. So try an outlet on the outside of the house intended for higher amperage machines like those used outdoors.
The problem may be with the power source. Check that first.
Now for the unit itself. 1. Connect the unit and set the pressure regulator to max pressure. 2. Turn the unit to Auto/On the unit should only run until the pressure is reached. 3. Connect a pneumatic tool to the unit and drain off pressure. Once the pressure gauge drops below the set value the unit should start again. If not then you need to take the unit to a certified service center to have the regulator checked.
Oct 31, 2013 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
May have installed regulator wrong.
The regulator will have an arrow cast into the body indicating the direction of air flow.
Aug 27, 2012 | Craftsman 15 gal Air Compressor 3 hp UMC...
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Low air pressure
This sounds like it is either the pump is leaking from the piston or more commonly, the rubber seal that seals the outlet tube to the cylinder head blew out like mine. Let me guess, it got a lot louder than it was originally? The seals are readily available from sears parts direct, its like 3 bucks but shipping is around $8. Hope this helped
May 23, 2010 | Craftsman Air Tools & Compressors
Regulator knob won't turn
Change the whole regulater . this will fix it . Thanx for using fixya
Jun 19, 2009 | Air Tools & Compressors
Craftsman 3 gal ari compressor low presure
put a blower on the hose and see if air comes out
very possible there is a blockage in the hose or if you are using quick connects they may have failed
Apr 17, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Pressure regulator gauge wont work on my 3 gal. air compressor how do i fix it or where do i get a new one (craftsman) i also lost my book , how often do i change the oil ?
If the regulator is inline you need de-energize the compressor to remove the regulator.
Sears parts and service:
http://www.sears.com/shc/s/c_10153_12605_Home+Services_Repair+%26+Maintenance?adCell=W4
Compressor Information:
http://www.sears.com/shc/s/c_10153_12605_Tools_Compressors+%26+Air+Tools
Wiki Buying Guide for Craftsman Regulators:
http://www.shopwiki.com/search/Craftsman+Regulator+with+Gauge
Sears / Craftsman Forum & Repair Information:
http://www.sears.com/shc/s/nb_10153_12605_NB_CSHome
3rd Party Regulator Retailer:
http://www.controlair.com/
If you feel that your problem is too serious for you to repairyourself, please contact a licensed/certified technician.
If you wish,you can call Sears HomeCentral at 1-800-4-MY-HOME tomake an appointment for a technician to visit. (There is a charge forthis service.)
Mar 11, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
1,159 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
