Question about Swanstone CS-1616 Corner Shower Seat, White
Metal bracket with Corner Seat, is it installed prior to tile?
Reference Swanstone CS-1616 Corner Shower Seat:
We are doing a complete renovation of a bathroom. The corner seat is on back order and not due for 3 weeks. I pulled up a installation sheet with a diagram. Verbal instructions did not indicate if after the reinforcement by a 2x6 between studs in the corner were also supplemented with the metal bracket coming with the corner seat...or is it applied after the tile is complete. As I don't have the spec sheets with specific instructions, and this corner seat is to be done after the tile is complete, I am concerned as to whether the metal goes into the wall prior to tile, or not? Anybody out there have any experience installing one of these corner Swanstone seats?
    Problem Solver:
  • 11 Answers
The metal bracket is applied after the tile. That is the reason for the reinforcement between the studs.
Posted on Jul 30, 2009
What are some good websites for information & pictures of remodeled small bathrooms using ceramic tile?
This is the car and truck section, but you might try youtube for videos.
Dec 18, 2012 | Cars & Trucks
Getting ready to install the Moen DN2160 Curved shower Rod. In reading through the instructions I am confused about what is necessary to install in a tile shower
hi doug. the only issue with tile is that drilling holes in tile requires a special tile cutting drill bit. These are common. I got some last week at a home depot. J.
Jul 08, 2011 | Moen Home
For Danze Sheriton/Plymouth tub/shower faucet, I am finishing the wall with ceramic tile and have set plumbing so plastic guard face will be flush with finished tile. One drawing in the instructions shows...
Don't cover area where plastic guard should be. Make it flush. Some trim is designed to recess into the wall before it's flush. Screws, adapters, trim etc. all will need to be installed when tile is set. Make sure you have nipples extending out from shower head and spout area's as well. If you do this and think ahead a little, you will have fewer problems assembling trim.
Apr 23, 2011 | Danze & Single Handle Tub And Shower...
The shower pan came with no installation instruction, it looked so well designed that I thought it would easily drain fully by just putting it in place. However since I have know completed the project I...
sounds like you will have to remove the tile and shower pan. The pan needs to be level along all walls. Use a level. I had to cut wood shims to support the pan and keep it level before screwing it to the side walls
Mar 11, 2011 | Home
Moen 3836...lost installation manual...what size drill bit for the hand held brkt.
There is no single answer that I can give you because it will vary due to material you are mounting to. If you are going to be mounting on ceramic tile or fiberglass shower wall I would recommend you use the plastic anchors that come with the bracket and mounting screws. Use drill size 3/16 drill holes and insert anchors. Mount bracket and screw in place. If you have hollow wall with nothing but sheetrock to hold the bracket I would get small butterfly anchors from hardware store and drill hole slightly larger than the wings on fastener when they are folded back along side the screws.If you have a wood backer board behind shower wall then drill holes with 1/8 inch bit and use screws long enough to reach through shower wall and sheet rock and mount bracket. Hope this helps you. Thanks P.S. If you have to drill thru ceramic tile you will need a carbide tipped bit.
Nov 26, 2010 | Moen Plumbing
Tiled shower is leaking in one corner , installed 1 year ago
I don't really know the specifics. It sounds like you might need use some caulking on it.You can get it at a hardware store.
Mar 04, 2010 | Home
The weight of the arm and rain head is too heavy for fixing
can you at all shorten the length of the arm to make the head lighter or can you do the adjustment near the tiles up tighter apart from this attach unsightly bracket from the head back to the wall at worst mate start pulling tiles off ouch ! wish i could more help glenn..
Nov 20, 2008 | Grohe 27.217.EN0 Rainshower 6" Ceiling...
Swanstone CS-1616  Corner Shower Seat, White Logo
328 people viewed this question
Top Swanstone Home Experts
Gene Haynes
Tony Crow
Are you a Swanstone Home Expert? Answer questions, earn points and help others
