Question about Garden
Tecumseh carb kit
I have a tecumseh carb the # on carb is127700h1 where would I find want kit to buy thank you
  • 40 Answers
Take the carb with you to a mower shop and ask they should sell you the kit. the rubber seat that has to be replaced only goes in one way. there will be a ring on one side that needs to face down. if put in upside down it will leak gas.
Posted on Mar 12, 2009
Gasoline pouring out od carberator,what is cauing this ? help
You said you replaced the needle, but did you replace the seat that the needle moves in to? If the seat is bad, it may not be sealing well even when the carb is full of gas and the float is pushing the needle in to the closed position. If it is a tecumseh carb, you can buy a kit that comes with a new needle, new seat, new bowl gasket and new bowl nut gasket. The kit is about 3 dollars and should fix you up. The kit i am referring to is part #1606506, but you may want to check and make sure that will work for your model. Regardless, the same pieces that fit your carb should do the trick.
Dec 27, 2013 | Garden
My 20hp TVT691 Tecumseh intermittently misses on one cylinder and has no power ????
Hello! The engine has two carb's...There are know for varnish build-up in their passageways...The carb associated with the problem cylinder is more than likely the fault...Spray cleaners do not work...Buy a gallon of "Gunk" which has a parts tray...Disassemble the carb and let it soak overnight...There are literally hundreds of different carb types on that engine...There is an extension # after the model # that begins with the # 6...And also a # on the Carb...You'll need that information when you buy a rebuild kit...Kit cost is under $10...The gallon of Gunk Carb cleaner, although expensive, will last a very long time...Send a comment...
Guru...saailer
Jan 10, 2012 | Cars & Trucks
Looking for carburetor assembly drawing thanks Tecumseh 4hp TVS105 53048D SER. 4159B
I didn't find a schematic, but here is a site that may be able to help you:
www.lawnmowerpros.com/Tecumseh/tecumseh-Carburetor-Kits.asp
Contact the number at the upper right of the page if you can't find a schematic close to yours. They may send you one for free if they have it.
Good Luck!
Jim
Oct 10, 2010 | Mtd 22" Yard Machine Push Mower
How to set up a carb with 31840 rebuild kit
what exactly do you want to know? Carb. mixture settings are as follows: L-head engines
Tecumseh carbs.........mainscrew 1 3/4 turns idle screw 1 1/4 turns
Walboro carbs........... mainscrew 1 1/2 turns idle screw 1 1/4 turns
L-head and OHV heavy duty engines 1 turns for both
Dec 21, 2009 | Toro Garden
Unable to start after long period of inactivity
stale fuel varnish in the carburetor? See your dealer for a carb kit (1 kit does pretty much all Tecumseh lawnmower engines, but there will be parts left over), drain the fuel from the float bowl on the carburetor before storage
Oct 25, 2009 | Tecumseh Garden
Tecumseh ohv130 engine wont start. It has spark,fuel,clean air filter, good battery,I have checked the valve clearance and set them to .004'', the plug sparks, the flywheel key is not sheared,the carb is...
Replace the carburetor. It is not fixable, even though you can buy a rebuild kit for it. Been there, done that-- had to learn the hard way. What?? I said to myself. I've been fixing these small engines (shade tree) for years, and we always could rebuild the carb and adjust for peak performance. I absolutely refused to believe that my "rebuild" didn't "fix" this carb. Hard to believe, but true. Replace the carburetor. This is your "something new" you've learned for today.
Apr 21, 2009 | Mtd Products Yard Machines 158CC Tiller
Tecumseh HM80 on coleman generator. won"t stabilize, backfires. new plug, fresh gas 'carb cleaned. starts first time'new air filter. any suggestions?
check to see if it has a smeared or worn key way it is what times the fly wheel to the engine if not it is possible that it coul have problem with a valve or engine timming
Mar 01, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Troy bilt tuffy with 3.0 tecumseh engine.
Contact Information:
http://www.tecumsehpower.com
900 North Street
Grafton, Wisconsin
53024 USA
Phone: 262-377-2700
Jan 25, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Ariens ST724 carb issue
You'll need the model and serial number and also the carb will be helpful, if you take that info and the carb to your local lawnmower shop they will be able to supply you with the right kit.
Dec 31, 2008 | Garden
Garden Logo
268 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
