Question about Price Pfister Home
How to replace price pfister 807 shower valve
SOURCE: shower spout
There is a threaded stem that passes through the spout and attaches to the white plastic diveter valve. If you are starting from scratch (everything apart), you can put it back together in this order:
1) Place the white plastic diverter inside the spout. the circular side with the black round washer should face the the wall side of the shower (mating up against the threads for the water pipe).
2) The stem can now be inserted from the top and into the notched section of the white plastic diverter valve. The threaded end of the stem shoud be outside of the spout (from the top side).
3) A round black washer fits over the threads. It should sit right where the threads end. Dont push it all the way on to the unthreaded portion of the stem.
4) Screw the threaded knob onto the threads.
Should be ready to install now. Including the spout itself, there are 5 parts and are configured in this order from top to bottom.
1) Female threaded knob (the knob for operating the spout)
2) Threaded stem (threads on top)
3) Round black washer
4) Spout
5) Whit plastic diverter valve.
Mine leaks when I turn on the shower, thus reducing shower pressure. I looks like a poor design to me. The stem is not a tight fit in the spout and this allows the diverter to "wobble". The washer on the diverter valve does not seat tightly and allows water to leak out the tub spout when showering. I would replace the spout.
Posted on Jan 30, 2009
  • 19 Answers
SOURCE: price pfister single handle shower faucet
home depot has all the parts for price fister
Posted on Feb 04, 2009
rahnzkie_18
  • 32 Answers
SOURCE: Fluctuating water temperature in new Price-Pfister Treviso shower
hi there! there is a technical problem in concern with that for sure...try checking the handle it might be loose already. things like that do happened all the time. thanks, kindly rate.
Posted on May 02, 2009
bloues
  • 56 Answers
SOURCE: The cold water stop working in my shower. I have a
Two posebel coses i can think of.
1. the taps plunger is stuck in the off posision or 2. there is dirt loged in cold side of tap.
take off head part of cold tap and c if mabe the rubber is stuck or if u maby see some dirt in the tap ietself
hope it helps
Posted on Jul 20, 2010
SOURCE: i need a replacement cartridge # 17196-0100k for a
I have a single handle price pfister shower valve Model 17196-0100k .No cold water.It's coming hot on both sides.
Posted on Aug 10, 2011
Price-Pfister shower clogged after work elsewhere on water lines
remove cartridge blow out water lines be careful
Feb 09, 2013 | Price Pfister Home
Set water temp
remove the handle, find the plastic disk with teeth, pull out disk and turn to left for hot, right for cold, set disk back in place, then replace the handle, repeat as necessary.
Feb 22, 2012 | Price Pfister Plumbing
I need a replacement cartridge # 17196-0100k for a single handle price pfiser shower valve. where can i order one?
Mar 28, 2011 | Price Pfister R89-7PC0 Chrome Portland...
I just installed a Price Fister shower only mixing valve. 07-807 I have 70 psi coming to the house, i have maybe 30 psi coming out of the shower head. How do I get more pressure?
70 lbs, you must have city water, were lucky to get 30 lbs out here in well country. Most mixers sold now days are restricted, water saver devices, but most are also in the ends of faucets. You might not be able to get more pressure out of it, but if you look at the diagram of the faucet, you might see something that says, water saver, or restricter. If it can come out, take it out. Hope this helps.
Jun 09, 2010 | Price Pfister Home
Hot watwer leaks from the hot side of the facet
Replace the stem assembly (ceramic cartridge) with Price Pfister service part #910-030. Be sure to turn water on briefly to flush out any debris in the valve body before installing new part. NOTE: this valve does not like old galvanized plumbing.
May 21, 2010 | Price Pfister 01-31xa Shower Head, Tub...
I have a Price Pfister Model no. 808 DK00 single handle bath tub/shower faucet. I am only getting hot water coming out when the handle is turned on. This problem just started. It was working fine for about...
It's likely that you have some sediment that has accumulated in the cold water valve and has clogged it. The model number you have cited above is only for the trim (rather than for the valves behind it). Assuming that you have a Price Pfister valve, they don't have built in filters, so you're probably going to have to either clean or replace the valve.
Sep 17, 2009 | Price Pfister R89-7PC0 Chrome Portland...
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
Swaping Pfister Shower leaver handle
it must be the same model number,most models come in different colors and styles.
Feb 27, 2009 | Price Pfister 01-111 Shower Head, Tub...
Home Logo
46 people viewed this question
Top Price Pfister Home Experts
Mike
Tim Whalen
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
