Question about Frigidaire FRS26R4A Side by Side Refrigerator
My new frigidaire refrigerator model# FRT18S6AWX is unusually noisey . It makes gurgleing sound and it last for 10 seconds . it does this throughout the day once every half hour. We reported it and were told it is normal and the noise comes from the line that brings refrigerant up to the freezer? They refused to fix it without charge . We live with it ,we can hear it from the kitchen to the other end of our house a distance of 42 feet. Quite annoying we hope it last but question its electrical effecientcy?
  • 1 more comment
  • jonathan88tu May 07, 2009
    my newly brought Frigidaire FRS6R5ESB making the annoying noise which you can even hear since you step into the house, and you can even hear that sound when I switched on the TV. It drives me crazy but the technican come to check and insist it is "normal". Finally the technican agreed to change the compressor but the dealer rejected because they said that if the refrigerator running OK then the sound is normal!!!!!!
  • robert samples May 11, 2010
    the sound that usally goes with what tech assit is talking about is a tapping or knocking sount what you are talking is just what it sounds like to you water related pull your fridge out and check the drain pan behind the back panel and let me know about the drain tube comming to the drain pan also
    Problem Solver:
  • 4 Answers
I have heard probably 50 refrigerators that make this sound on startup in the lst 5 years. After they changed from Freon 12 to 134A, the running pressure of the sealed system acts slightly different, an causes the liquid freon to initially pulsate from the capillary tube into the evaporator. This causes the 10 second knocking, or a tapping sound on start up, untill the compressor reaches normal running pressure. incidentally, they are not all Frigidaire brand. We are Frigidaire and Maytag factory service, and they both do this to a certain extent, which is considered normal.
Posted on May 12, 2010
  • 6,784 Answers
Hi, this is not normal at all. this is a manufacturing flaw the resides in the compressor build. there is way to much pressure being produced threw the lines. the compressor regulator seems to be flawed in its design. i would recommend purchasing a aftermarket compressor Assembly for this unit. the noise itself is a dead give away for flawed compression in the core Assembly.
Posted on Mar 11, 2009
When freezer starts p makes a gurgling sound
As long as it's running properly, I wouldn't worry about it. Refrigerant can make noises throughout the sealed system
Aug 12, 2016 | Danby Freezers
Emits a loud coarse noise, about 10 seconds long, intermittently throughout the day & nite
What type of compressor does it have? Some brands use a compressor that makes this sounds every time when it starts up. And its normal. Last for 5-20 seconds.
Feb 17, 2016 | Refrigerators
I just got the side by side Frigidaire professional and every few hours there is a loud noise that comes out of it that last like 3 seconds
Thanks for your post, friend!
I see that your Frigidaire side by side refrigerator is making a loud noise every few hours. There are a lot of normal operating noises within a refrigerator. It is possible that your evaporator may create a boiling or gurgling noise. Or you could be hearing ice being released into your ice bin. If you have your manual they should list some normal operating noises within your refrigerator. I hope this information has been helpful. -Matt
Oct 19, 2014 | Frigidaire Refrigerators
Why is my frt18s6awx not getting cold enough in freezer & fridge?
Good Afternoon Friend,
I understand that your Frigidaire freezer, model# FRT18S6AWX, is not getting cold enough in either the freezer or refrigerator. I suggest changing the settings to a colder setting and give it 24 hours to stabilize at the set temperatures. Also, I recommend cleaning the toe grille and condenser coils. You can do this by taking the toe grille off and cleaning it with soap and water and rinsing it thoroughly with water. While the toe grille is off, get your vacuum with extension, and vacuum underneath your refrigerator. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
May 26, 2014 | Frigidaire FRT18S6AW Top Freezer...
Freezer gurgles
    • Give it mouth wash lol
      Check the water valve on the back of the refrigerator if it has an ice maker. Make sure the valve is turned completely on and not constricting the flow of water to the refrigerator via the water supply line. You might also hear a simultaneous buzzing sound when the gurgling noise occurs. In some refrigerator models, this filling process is on a timer, and you might hear the buzzing and/or gurgling every 15 minutes or so.
    • Check the water supply line for leaks or damage. You might see a puddle of liquid on the floor. If air is pulled into the water line as the refrigerator is pulling in water, that can create a gurgling noise. Replace the damaged hose yourself, or contact an appliance repair technician for assistance
      • f he refrigerator to feel a slight vibration. This is probably the compressor processing the refrigerant, which is a liquid. This flow of refrigerant can produce a gurgling sound, and it is normal. However, a simple way to reduce this noise is to make fewer trips to the fridge. When you open the door, you let hot air in, which means the compressor has to work harder (and gurgle the refrigerant more) to cool things back down.
    • Wait while the refrigerator completes its defrosting cycle if you hear water dripping and gurgling in the freezer area. When the heating coil turns on, the melted water from the frost flows down to a drain pan for evaporation to take place. The defrost process usually takes about 30 minutes. This is automatic and cannot be prevented in most refrigerators. Keep the closed to try to prevent unnecessary frost buildup.
    • Wait while the water equalizes in the refrigerator if you hear a gurgling sound when shutting the door. This is normal and is a result of air being forced through the drain tube. The gurgling can last several seconds but should eventually dissipate this usually happens with old fridges upgrade its a good investment
Dec 10, 2013 | Freezers
Unusually noisey when running
80% is coming from evaporator fan and condenser fan motor, 5% from compressor and 5% from flow of refrigerant ( gurgling ), 10% from the rest.
Mar 07, 2010 | Refrigerators
GE side by side refrigerator water dispenser slow starts.
Well, the age doesnt help it, but have you ever changed the filter and had it all cleaned, if not all must be cleaned and filter changed, that should do it
Feb 09, 2010 | GE GSH25JFR Side by Side Refrigerator
Compressor makes a loud gurgling sound when it shuts off.
The gurgling sound is normal. When the compressor shuts off the refrigerant is still flowing through the system until the pressure equalizes... probably 5-10 minutes
Dec 07, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Sub-zero 650 makes loud gurgling sound
gurgling is not unusual and is caused exactly by fluid bubbling thro a pipe.
Nov 04, 2008 | Sub-Zero 650 / O Bottom Freezer...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
445 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
