Question about Acer Aspire 5735 Notebook
Audio problem acer aspire 5735, there is an awfull echo sound on the laptop, it just isnt right.plz can u help
    Problem Solver:
  • 4 Answers
If it has a microphone you may be having you're microphone echoing whats coming out of you're speakers to disable it
windows vista:right click the speaker in you're tray click recording devices and click disable
windows xp:rigt click speaker icon in you're tray and click open volume comtrol and mute the current microphone
or if that's not the problem you may have to download new sound card drivers i can help you with that too!
Posted on Mar 11, 2009
  • 4 Answers
Uninstall the sound drivers altogether and diconnect the device and reboot, let windows detect it again.
Posted on Feb 02, 2011
    Novelist:
  • 113 Answers
Right click desktop> properties> sounds> playback> properties> enhancemenets
make sure that the sound effects settings are off (none)
also check the advanced tab while your there and hit the test button. if the echo is still there try lowering the bit rate and retesting after each change is made until the echo stops,
im thinking its set to advanced cave settings and needs to be reset..
Good Luck!!!!
My Acer Aspire 5735z has no sound on dvds in Real
use the driver cd which came along with your laptop and reinstall the audio driver from it. After that reinstall the real player as well if needed.
After that everything should work fine.
I hope this is helpful to you.
Thanks
May 04, 2010 | Acer Aspire 5735 Notebook
Laptop will only charge when switched off
get orignal charger for acer aspire 5735 pc and then try again
May 03, 2010 | Acer Aspire 5735 Notebook
I am having trouble locating mic on my 5735.I can get picture contact but no sound.I have checked sound level and that seems fine.Just can't communicate with the other person.Hope you can help.
Have you tried a plug in headset mic ? Right click the little speaker icon in the bottom right corner of your screen.Left click Adjust audio properties and go from there.
Apr 09, 2010 | Acer Aspire 5735 Notebook
My Acer aspire 5735 will play sound when I stream music or tv but there is no sound when I try to play a dvd, can you help? The drivers are realtec, thanks
I know this sounds stupid, but check the volume settings.
If that checks out, make sure your drivers are up to date. I don't know what Operating System you have (version of Windows) but I can point you in the right direction.
To get your drivers click on THIS link. It will take you to Acer's drivers page. Once on that page, simply click Notebook > Aspire > Aspire 5735
Then under that there will be a box where you can select your version of Windows, which will show you the appropriate drivers which is where you'll find the Realtek driver.
Hope this helped :)
Nov 28, 2009 | Acer Aspire 5735 Notebook
Hi i have an acer 5735 aspire running vista. I cant get the sound to play when trying to listen to the radio on line. it has happened before but now no sound at all. the mute is off. The volume is up and...
Make sure that the drivers are properly installed by viewing it on Device Manager System menu located at the control panel. If there's no problem, check the sounds menu found also in the control panel then check the playback setting if it's selected to the right audio driver.
Nov 21, 2009 | Acer Aspire 5735 Notebook
How to replace a acer aspire 5735 keyboard
Here is the factory service guide that explains complete servicing of the laptop. Make sure to save a copy for yourself, the file is free to use.
http://tim.id.au/laptops/acer/aspire%205735%205735z%205335.pdf
Oct 11, 2009 | Acer Aspire 5735 Notebook
ASPIRE 5735Z no sound
jus call me i will solve it...00393275597091
when first time i installed sp3 i got the same problem....but now ..i can install..
jus call me ..
thanks..
May 18, 2009 | Acer Aspire 5735 Notebook
Can you help me where to find an ethernet driver for my acer?
Acer Aspire 5735?
Right here,
http://gd.panam.acer.com/home/
If this just comes up with the Acer Pan-Am home page, and not the exact driver download page, for the Acer Aspire 5735 that I linked, do this,
1.In the left hand light blue column, click on Drivers & Downloads.
2.To the right will be a small window, that states -> Select Product Family.
Click on Notebook.
3.Another small window will come up -> Select Product Line.
Click on Aspire.
4.Another small window will come up -> Select Product Model.
Use the slider on the right of the Select Product Model window. Click on the down arrow of the slider.
When it scrolls down to Aspire 5735, click on it.
(Make SURE you do not have the Aspire 5735Z. Look on the bottom of the laptop. This model number will be stated, if so. If it is the Aspire 5735Z, click on it)
Once you click on the Product Model you have, the drivers will be shown at the bottom.
Click on -> Lan......Marvell......LAN Driver (LAN = Local Area Network. This is your Ethernet driver)
Apr 24, 2009 | Acer Aspire 5735 Notebook
Soundcard problem acer aspire 5735
Try reinstalling sound driver. if still the same issue try external speaker to check if they have same issue. if external speakers work fine that mean its not driver issue and problem with your notebook speakers replace them.
Good Luck
Feb 04, 2009 | Acer Aspire 5735 Notebook
Acer Aspire 5735 Notebook Logo
321 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
