Question about Microsoft Windows Mobile 2003 for Pocket PC
Notification Error After putting the device on each time I receive a notification error which I could not get rid of . It reads Cannot execute\Storage Card\Program Files\eWallet\eWallet.exe This is due to a wrong unloading of e Wallet software programme which I tried to delete all remainin parts in my mobile phone . The version is Mobile Windows 5.0 . Can you pls help me how to manage that and get rid of that nerve racking notification which comes to my eyesight all the time ? Thanks®ards Mehmet
    President:
  • 2,961 Answers
Make a backup of all files and contacts, because if you have removed the software and still get ewallet popping up you will have to do a factory reset. To do this go to start>settings>system>clear storage and then type in the password normally default 1234 and press yes if you want to lose all data and revert to factory settings.
Posted on Aug 07, 2007
SOURCE:
Hi. I took my moto g5 plus phone to Walgreens to upload photos to develop. It would not open. The workers have never seen a phone that you could not get the photos off to develop. Thanks
1.When you plugged in your phone to PC, did you slide down the notification bar on your phone and set USB settings to MTP mode?
2.Is your sd card formatted as internal or external storage? Have you tried to select MTP mode?
3.f you formatted the card as adoptable storage then you only have one folder. The whole point of adoptable is to create one storage area out of the internal and external sd card storage. From what I've read it seems like portable is a better option due to reliability issues with sd cards and the ability to read the card in another device. I just use my SD card for music and other files that are backed up someplace else.
When you look at the folder in Windows Explorer it should be the size of your internal storage and SD card combined.
Hope This Helps!! ,Best
Oct 12, 2017 | Cell Phones
How to transfer LG cyon 2MP camera photos to computer
1. Connect your LG Cyon to your computer via it's USB cable.
2. Upon receiving a "USB Connected" notification atop the Notification bar, drag the bar down and select "USB Connected."
3. Now select the option corresponding to "Turn On USB Storage" or connect as "Mass Storage Device"
You should now see a new flash drive or storage device connected to your computer. Browse/Move/Copy/Delete files (including photos) as you would with any other flash drive or thumb stick.
Sep 25, 2011 | LG Cyon
How do i download music from my laptop to tablrt
I highly recommend installing DoubleTwist after you follow the instructions below. The DoubleTwist program lets you do media sync to any android device, it's slick and simple.
Connect your tablet to the computer using the included USB cable (small end to tablet, normal sized USB end to PC)
A USB icon will appear in your notifications bar at the top of your tablet's screen, drag the bar down to open the notification.
From here you'll choose to mount the storage drive (either internal or an external card if you have an SD card installed).
Once that's done your tablet should appear as a "Mass Storage Drive" or another hard drive on your PC. From here you can drag and drop files into it, or use DoubleTwist to do that automatically.
Feb 28, 2011 | Coby Kyros 716829701508 Tablet PC
Xppro on startup box appears with ref to Twonkymedia startup application error
A program that contained Twonkymedia was probably deleted. Even though it was deleted a reference remains in the start up files and when start up files are executed it can not find the program to start it thus "start up application error". To get rid of the error message you can remove the reference to the program in the start up menu or reinstall the program and let it execute normally on start up.
Oct 12, 2009 | Microsoft Windows XP Professional
Ricoh aficio 2090 gives sc 866 when i put sd card for work as printer and scaner
SC866 B SD Card Error 1: Confirmation
The machine detects an electronic license
error in the application on the SD card
inserted in the controller slot when the
machine is powered on.
The program stored on the SD card contains
electronic confirmation license data. If the
program does not contain this license data,
or if the result of the check reveals the
license data in the program on the SD card is
incorrect, then the checked program cannot
execute and this SC code is displayed.
• Required program missing or
incorrect
• Download the correct
program for this machine
onto the SD card.
SC867 B SD Card Error 2: SD Card Removal
The SD
Jul 03, 2009 | Office Equipment & Supplies
My g1 keeps saving my music to the phone and not the sd card
this may help you get around your problem
1. Make sure the microSD card is inserted in the phone.
2. Plug the phone into the USB slot on your computer using the G1 USB cable.
3. Watch the notification bar at the top of the G1 main screen. After the computer connects on the USB port, you will see a small USB icon appear on the notification bar.
4. Drag the notification bar down and select the USB connection notification. A popup will appear asking you if you want to mount the microSD card on the computer. Select "mount." After a second, the PC should detect the card.
5. You can now copy files to and from the card like any other USB storage device.
When you're finished, open the Music app, and select the Songs icon and you should see all your music files listed. The phone will read the files and sort them by album name and artist name as well.
Jun 05, 2009 | HTC G1 Smartphone
Storage card slot not reading my storage card
im having the same problem i put the storage card in my phone but it says storage card not found.
HELP!!!!!!!!!!!!!!
Apr 10, 2009 | Sharp Sidekick LX Smartphone
What does Windows Vista error 0x00000005 mean?
Applications that are reading file allocation table (FAT) based storage devices at the time of a resume may receive the following error message from the file system: ERROR_ACCESS_DENIED (0x00000005) This occurs although the file has appropriate sharing and access permission.
Examples of storage media that frequently use the FAT file system on Pocket PC 2002 are the PCMCIA PC Card ATA, the Compact Flash (CF) Storage Card, and the Secure Digital (SD) Memory Card.
This behavior is observed when using Pocket PC 2002 Adaptation Kit Update 4 (AKU4) and later.
RESOLUTION:
Applications can handle this situation by detecting the specific error code while reading a storage card file, and then retrying for a short period until the device is ready. The following is an example C code fragment that demonstrates this concept: while ( !WriteFile( hFile, achBuffer, dwBytesRequested, &dwBytesReturned, 0 ) &&
( ERROR_ACCESS_DENIED == GetLastError() ) )
// Access Denied: Maybe the file system is not ready yet.
tries++;
if ( tries > 4 )
break;
Sleep(500);
// It has been a few seconds. The file cannot be accessed.
You can use the same approach for other programming languages. For applications that access the storage card through middleware libraries that do not provide direct access to the file system, you may have to implement transactional or block verification methods to get reliable data transfer across a suspend resume.
Mar 09, 2009 | Microsoft Windows Vista Home Premium with...
Map storage error
This means that there is an error with the data on the CF card..Try reloading the maps another time..
Jul 25, 2008 | Garmin StreetPilot 2610 GPS Receiver
Error 30
The "E30" error code is displayed when reading/writing data on a storage card has failed. Especially, the error code "E30" may appears when you tried to remove a storage card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another storage card. If you have another storage card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the storage card for errors. Use ScanDisk to check the storage card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the storage card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the storage card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the storage card with your camera Try to format the storage card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting CF cards. Also, please note that formatting a storage card will erase all data on the card. Once the storage card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the CF card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the storage card. If turning the camera off and then on again, and then performing steps 1 to 3 above fails to clear the error, a camera malfunction may have occurred. Please contact the retail store where you purchased the camera or the nearest Canon service center. If the error code is displayed right after you took a picture, the image may not have been recorded. Switch the camera to playback mode to check if it was recorded. Precautions for handling a storage card: - Do not remove a storage card or turn the camera off while the camera is recording, loading, or erasing data on a storage card. - storage cards are high-precision electronic devices. Do not bend, force, or subject them to shocks or vibration. - Do not attempt to disassemble or alter a storage card. - Place the storage card in the supplied case for storage. - Moving a storage card rapidly between temperature extremes may cause condensation in the card, leading to potential malfunctions. To avoid condensation, place the storage card in a sealed plastic bag before moving it into a different temperature area and allow it to adjust slowly to the new temperature. If condens
Aug 31, 2005 | Canon PowerShot S1 IS Digital Camera
Open Questions:
Phone number 18OO-8O3[[1O69 for aol customer support + number*v*~u.s.a ygh Usa AOL USA phone number is ranked #2 out of 2 because 7,728 AOL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO::8O31069 is to reach t he AOL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AOL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AOL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AOL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AOL USA Calling AOL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AOL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AOL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AOL USA's phone numbers against each other. Contacting AOL USA in General While I8OO8O31O69 is AOL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AOL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AOL USA.
Oct 19, 2019 | AOL Computers & Internet
See all Microsoft Windows Mobile 2003 for Pocket PC Questions
Microsoft Windows Mobile 2003 for Pocket PC Logo
252 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
