Question about Swingline 1703000 GBC Heatseal QuickStart H320 Laminator
Heat seal quick start h320 laminator won't turn on
My laminator suddenly stopped working when it was plugged in. what do I do?
Check the circuit breaker on the bottom left corner of the machine. It is under the machine. You may need assistance lifting the laminator a few inches to get your fingers under it. Push on it and listen or feel for it to click. If it continues to open after you plug it in then you may have a problem with the machine electronics. I also have had weak circuit breakers that needed to be replaced.
Dec 09, 2015 | Gbc Heatseal H320 Laminator, 12.5" Wide, 5...
Why doesn't our laminator always roll?
It sounds like the control panel switch membrane( under the panel buttons) needs to be replaced. The bad sound may be your heat roller bearings failing. They dry out and start squealing. They also can cause your machine too slow down or stop. There are 2 bearings on either side of the laminator, 4 total.
Sep 08, 2015 | Gbc Heat Seal Ultima 65 Laminator 1710740
How can I fix the edges of my laminator to seal.
make sure you are at 300 degrees temp, you can slightly adjust the pressure on each side by tightening down the 5mm hex nuts on top of each bearing housing. There is alot of foreign films out there right now that also have substandard glue that are causing all kinds of lamination problems. USA film always works
Mar 13, 2015 | Gbc HeatSeal Ultima 65 Laminating System
Scotch Thermal Laminator not heating up.
well it sounds like you may have cut a wire or pull one somewhere. i would go ahead and take it apart carefully and check everything. may have unplugged something hopfully! let me know whwat happens!
Jan 31, 2014 | 3M TL902VP Scotch 9" Thermal Laminator...
My gbc creative laminator won't heat up
We have an Ulitma 65 and it won't heat up...Any suggestions on how to fix this? We are at a school and no $ to replace the whole unit. Thanks in advance.
Mar 29, 2013 | Office Equipment & Supplies
The heat button won't turn on
either the top or lower heater shoe TCO is blown out. take the right side cover off, trace the wires back to the heat shoe and check for continuity, (unplug machine first) find out which TCO is blown order another one, replace it and your off to the races. I've fixed many of them.
Mar 11, 2013 | Gbc 1701720: Pinnacle 27 EZload Laminator
GBC Pinnacle 27 won't come on
each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime.
Feb 20, 2013 | Gbc ® Pinnacle 27 Two-Heat Roll Laminator,...
My laminator won't stop heating
so what model are you having troubles with
Aug 30, 2012 | Gbc HeatSeal H425 Laminator
Swingline 1703000 GBC Heatseal QuickStart H320 Laminator Logo
226 people viewed this question
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Andrew Taylor
Andrew Taylor
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
