Question about Winsor Windsor Sensor S15 Commercial Upright Vacuum Cleaner
Windsor sensor s15 bag full light comes on and machine shuts down
Where is vacuum chamber on a Windsor sensor xp12
it comes up from the back,it is probably plugged or the sensor is dirty
Apr 21, 2015 | Windsor Vacuums
How to fix sensor s12. red light for bag stays on even when vacuum bag is not full and the vacuum is clear
You most likely will need to change the Yoke assembly. There is a sensor built in that gets clogged with fine debris over time. This will take care of the problem.
Feb 09, 2015 | Windsor SR12 Sensor Bagged Upright Vacuum
I have windsor s12 red light for bag is full is on and it's not clogged. what next
Check the line going from the bottom of the vacuum to the bag, it may be clogged. A coat hanger can help you clear any jams, but be careful not to puncture the duct.
Jan 27, 2015 | Windsor SR12 Sensor Bagged Upright Vacuum
Windsor sensor vacuum lights flashing then motor shuts off
I've worked on these a lot. What I think you're explaining is the bypass flow switch which is a common failure. It's located in the base inside the auction side of motor housing...
May 01, 2014 | Windsor SR12 Sensor Bagged Upright Vacuum
I have a Windsor Sensor s12 and power shuts off after 5 min. of vacuuming. I'm wondering if it's overheating of if there is some other sensor that causes it to shut off.
Your Sensor most likely has an internal heat sensor that is shutting off the motor. Some vacuums install an external heat sensor with a reset button that you must push to re-start the vacuum. If your model does not have an external reset button it is most likely a sensor inside the motor. If it is defective the motor must be replaced to solve the problem. But first make sure the overheating is not being caused by a blockage somewhere or the bag is too full. Air must pass completely through a vacuum starting at the floor where it picks up the dirt through all the canisters, filters, bags, etc. and then is exhausted from the vacuum. Any restrictions or blockage can cause the motor to over heat.
That Vac Guy
Jan 04, 2013 | Windsor SR12 Sensor Bagged Upright Vacuum
Sensor xp 15 shutting down
If you have one of your red lights flashing or on all the time that will indicate where you need to look for your repair. Beater bar light will indicate a brush roll replacement and the bag light indicates a need to empty the bag or look for a clog somewhere in the air flow area of the hose or wand. These machines are designed to shut down if you keep trying to run them with a red light coming on.
Aug 25, 2012 | Winsor Windsor SENSOR XP 12 Vacuum
I have windsor s12 vaccum this one have brush up light on
The windsor Sensor brush indicator light will come on when:
  • Something stuck in the brushroller
  • Brushroller is worn and needs replacement
  • height is wrong (indicates a problem with height adjustment)
  • a bad circut board/sensor
more than likely your brushroller just needs to be replaced, very common.
Jun 03, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
Windsor sensor says bag is full when its not
Are you vacuuming up fine particals like pet dander or just large amounts of regular dust? Also when was the last time you replaced your filters?
Just some sugestions.
Mar 17, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Windsor Sensor Vacuum
Sounds like you have a clog, either in the hose, or the inlet down at the bottom. When there is a clog, the red light will come on and may also shut down to protect the motor.
Nov 19, 2007 | Vacuums
Winsor Windsor Sensor S15 Commercial Upright Vacuum Cleaner Logo
Top Winsor Vacuums Experts
JoeVacs
Are you a Winsor Vacuum Expert? Answer questions, earn points and help others
