Question about Philips Televison & Video
Time Warner Remote AT8560 - device code for Phillips HTS8100/37
I would like to operate my Phillips Soundbar from my Time Warner Cable Remote
2 Suggested Answers
SOURCE: Tv Code for Time Warner Cable Remote
I need got a different tv tan i had when my tv was installed s i need the code
Posted on May 26, 2009
I need a remote code for a NB3520A LG Soundbar to program my ur5u-8780L remote on Time Warner Cable....700, and the find code using info are not working
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
Jun 25, 2016 | LG Televison & Video
I have the urc-4330b03 big easy remote and need the code for my time warner cbl box.
Please check with the following link and key in your device details :
.http://www.timewarnercable.com/en/support/program-your-remote.html http://www.timewarnercable.com/en/support/program-your-remote.html
Feb 02, 2016 | TimeWarner Cable Time-warner cable...
Time Warner codes for Mitsubishi tv
If Time Warner remote is universal, you probably can use its code search feature to find something that will control your Mitsubishi TV. Also, Time Warner might be able to tell you what code to use.
Jan 14, 2015 | TimeWarner Cable Time-warner cable...
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
Vizio soundbar remote code for TIME WARNER
If it is not in the manual for the soundbar, There is no possible way to get it to work, Unless it mentions auto search in the manual,
Dec 02, 2012 | Vizio Vsb211 - Home Theater Sound Bar...
My tv remote quit working. I would like the code for Daewoo TV, model No. DTQ-13P2FC to enter in another remote.
For Time Warner Cable TV Remote Codes for DAEWOO-TV's - Go to Time Warner Cable web site to PROGRAM REMOTE -- Site URL is http://www.timewarnercable.com/en/residential-home/support/pyr.html Then select TW Cable remote model. Under Control a Device -- first select type of device (TV) Then select Brand Name (DAEWOO). TW Cable lists several codes to cover different models. Choose a code and input into remote to see which code works. Try all codes. There were several codes to choose from and to try inputting into my TW Cable remote. Finally, the next to last code worked on my TW Cable remote -The Atlas OCAP 5-Device Remote Control by Universal Electronics. The code for this remote for Daewoo TV Model DTQ-13P2FC is 1661. Hope this helps. Otherwise, try checking the site of your cable or satellite provider & you should be able to get their add device codes for free.
Jun 21, 2011 | Daewoo DTQ-13P2FC 13" TV
CODE FOR A REMOTE CONTROL
I am not sure of the model remote but, on the newer TW remotes you would press tv then press and hold set up until the tv light blinks twice. then enter 991 on the number pad and then press power once. then press the channel up button until the tv turns off. as soon as it turns off - press the power button and if it turns on then you have the right code. If it doesn't turn on then press channel down until it turns on. either way, when the tv turns on then press set up again to lock that code in. Hope that helps.
Feb 10, 2009 | Emerson Televison & Video
Nov 14, 2008 | Televison & Video
Time warner cable box doesnt have a code for maxent mx-26x3
Code for gateway works. I used 206 on my universal remote. I have a Phillips remote.
Aug 08, 2008 | Maxent MX-26X3 Television
Televison & Video Logo
1,526 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
