Question about Kyocera KM-1510 Copier
A400 error code on Kyocera KM-1810 - Kyocera KM-1510 Copier
4 Suggested Answers
Copier_God
  • 57 Answers
SOURCE: I need to know what error code A400 means?
The polygon motor in the laser unit is faulty, you must replace the laser unit.
Posted on Oct 16, 2009
SOURCE: kyocera model km-1810 laser copier error code a400
MOI BARNI TECHNICIENT
CLIC SUR TOUCHE GOUCHE ET STOP ET TOUCHE VERT AU MEME TONS OK APRE MACHINE C4AFICHE U.000
APRE ENTRE U.20 PRINT ET TOUCHE AUTU MATIQUE APRE TOUCHE PRINT VERT BON CHANCE
Posted on Dec 10, 2009
UberTechzor
  • 295 Answers
SOURCE: Kyocera 1810 A400 error.
This error refers to a bad laser unit. The laser is what "etches" your image onto the drum as it transfers to the paper.
This is the cheapest replacement unit I have found for you.
Here
Posted on Aug 23, 2011
What happen when kyocera KM-1505 is bringing error code J98
There's probably a time piece of paper or something blocking a sensor or pressing down on an actuator or something
try checking this then do a good clean of the unit.
Jan 16, 2015 | Kyocera Mita Km 1810 1510 1505 Copier Drum...
Kyocera 1810 A400 error. What is wrong and how do I fix it?
Here
Aug 23, 2011 | Kyocera KM-1510 Copier
DISCULPE REQUIERO SABER EL ERROR A 400 DE MI COPIADORA KYOCERA MITA KM 1505, todo opera casi normal pero me bloquea con ese error a 400
bonjour ,j'ai une photocopieuse kyocera km 1505 et me marque le message erreur A400 ,y a t 'il quelqu'un qui pourrait me dire quesque c'est ce message là je vous remercie d'avance
May 02, 2010 | Kyocera KM-1505 Copier
a400 is a trouble code for Laser Scanning Unit problem.
Jun 24, 2009 | Kyocera KM-1510 Copier
Hello- We have the Kyocera KM 1510 and have an error message A400 coming up on the printer. No functions will work..do you have a suggestion or what would cause this problem. The toner cartridge was just...
Inside the printer, in the laser assembly, the zoom motor is not working anymore. Try to open it, stay clear of the lens, remove the little board with the motor atached to it, open the motor and clean it. Normaly it should run smoothly. i had the same problem, solved it, but now i get the A100 message. Any ideas?
Jan 29, 2009 | Kyocera KM-1510 Copier
I have a machine error
Does your machine have a ADF ( document feeder) on it? IF it does check the connection between the ADF and the machine. Also check the connection between the scanner PWB and the DF drive PWB. These are the 2 boards that let the machine communicate with the ADF. If your machine does not have an ADF, check to make sure that the side covers are closed securely.
Jan 05, 2009 | Kyocera KM-1510 Copier
Kyocera model km-1810 laser copier error code a400
dependds on what the problem is and $ of repair ??????????????
Oct 06, 2008 | Kyocera KM-1510 Copier
Kyocera KM-1510 Copier Logo
66 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
