Question about Music Hall MMF-2.1 Turntable
Music hall mmf 2 not working with pre amp
I own a Music Hall MMF 2 turntable and a Parasound PPH 100 Phono Pre Amp. However, when I plug everything in-turntable to pre amp and pre amp to speakers-sound will not play. Sound will play if I plug the turntable directly into my speakers, but, obviously, there is no amplification. What is the problem here and what can I do? Thanks
  • Music Hall Master
  • 5,190 Answers
The pre-amp has failed. Since you can hear the signal with the deck plugged into the amp that proves the cartridge and deck are working.
Posted on May 19, 2013
2 Suggested Answers
  • 357 Answers
SOURCE: No Volume For My Music Hall MMF-5 Turtable
Cambridge amps do not come fitted with the OPTIONAL phono preamp. At present you are plugging it into the AUX option hence why you get no/quiet rubbish sound. You can buy an external one or purchase the correct cambridge one to fit internally.
Posted on Nov 15, 2011
New drive motor for MMF-5 turntable
Can I suggest you visit and contact their website and ask for the spare parts for the turntable in reguards for the motor. However belts are available on E-Bay and other places.
http://musichallaudio.com/
Feb 10, 2014 | Music Hall MMF-2.1 Turntable
Music volume low when digitizing vinyls
The software itself should come with an sound imput level control. But if you can't find it or it's on full then there are ways round it. However it depends on how the turntable is connected to your computer. Most turntables require in an amp to have a magnetic cartridge pre-amp to boost the level to that say of a tape. Rather than mess around sometimes it's better to get one of these pre-amps and have that between the turntable and the computer. Then the sound should be the same level as a tape signal. You will have to bypass that pre-amp if you are recording anything else such as tapes to your computer. Or you will get a noisy loud signal!
Just search for a "magnetic cartridge pre-amp" on the web.
Jan 31, 2014 | Music Hall USB-1 - turntable
Very low sound after new needle installed
Firstly the cartridge could be faulty or incorectly wired. I think what you are refering to is a magnetic cartridge pre-amp. If the turnatable has seperate audio connectors these should be plugged into the "phono" socket. And not an "aux" or "CD" input. If there is no phono socket, you wouldn't be able to plug a pre-amp in anyway. Yes the deck if it is built in should have this pre-amp built in. However these pre-amp can fail!
To test if the pre-amp is working, even if has no phono socket, unclip the leads to the cartridge. With your amp on, touch the end of each wire with your finger. On two you should hear a buzz - one for each channel. If it's not loud then there's a problem with the pre-amp. If you do get a decent buzz the cartridge is faulty.
You can also trace the wiring to the pre-amp inside the unit, if you wish to fix it. It will almost certainly end up at an IC, which should be replaced.
Jan 15, 2013 | Audio Players & Recorders
JVC auto return turntABLE - mODEL al-a95bk
when you said "no sound enough to enjoy listening" did you mean that you could hear something coming thru the speakers, but it isn't loud enough? if so, you may be plugging the turntable into a "ceramic" phono input on your stereo. it may be that your stereo doesn't have a pre-amplifier on the phono inputs. Ceramic tonearm cartridges (the part that holds the stylus - which you may call the needle) have enough output level to drive an amplifier. if your cartridge is magnetic, the output is very low compared o the ceramic. the trade off is that magnetic cartridges have a much wider dynamic range than the ceramic, and when properly pre-amplified, sound MUCH better than a ceramic unit. you can probably find a separate pre-amp at radio shack (i know they sold them several years ago). you plug the turntable into the inputs of the pre-amp, then plug the pre-amps output into your stereo. hope this helps.
Dec 19, 2011 | Audio Players & Recorders
I have a turntable...an Music Hall MMf5 that I bought for my husband. i dont know how to connect it up to speakers so that we can actually use it...can someone help???
If it has RCA jacks (white and red jacks) coming from the unit it needs to be connected to the inputs of a stereo amplifier of receiver to produce sound. Most AM/FM receivers have inputs for phono in back. Just plug the cords into the inputs for phono and put your selection knob on your stereo to the phono setting.
Dec 01, 2010 | Music Hall MMF-5 Turntable
Connected to turn table. having sound problem. At 99, sound hardly audible.
The bose as most all in one systems do not have an inbuilt phono stage. Phono especially MM type have a very low signal and an eq curve that gets altered in the phono stage. Without a phono stage (known as a phon pre amp) you will not get much fun from your turntable. To connect : turntable out - into phono preamp - phono pre amp out into bose line in/aux in
Sep 28, 2010 | Bose Wave Music System CD Shelf System
Distorted sounds
The AT-PL120 uses a magnetic cartridge to extract a music signal from the record. Magnetic cartridges all put out a very weak electric signal, and so their output must be strengthened, or amplified, to where it is as strong as the input from, say, a CD player. This amplification is provided by a pre-amp. If your receiver has dedicated "phono" inputs the pre-amp circuits are already in the receiver. If you do not have dedicated phono inputs you must either buy a pre-amp, or buy a magnetic cartridge turntable with a pre-amp built into itself. The AT-PL120 has a built in pre-amp. You can switch the AT-PL120's preamp on or off. The switch is located under the platter at the back side of the turntable. Take the platter mat off and turn one of the platter's holes to the back and you should see the switch through the hole. If you push the switch to LINE OUT the preamp is turned on and the turntable sends an amplified cartridge signal out the cables which MUST be connected to a receiver inout suitable for a CD player (a "high level" input). If you push the pre-amp selector switch to PHONO OUT the turntable sends the weak unstrengthened cartridge signal out the cables which MUST be connected to the receiver's dedicated PHONO inputs so the signal can be amplified with the receiver's own pre-amp circuits.
If everything is set wrong (i.e. LINE OUT (pre-amp on), and connected to phono inputs) you are applying two steps of strengthening to the turntable's signal which is too much. The resultant sound will be garbled. Try not to do this!
The other way to do everything wrong is set the pre-amp switch to PHONO OUT (pre-amp off) and connect the turntable's cables to a high level input. If this happens the turntable signal receives no amplification and the resultant sound will be thin and weak.
May 09, 2009 | Audio Technica AT-PL120 Turntable
You will need to obtain a phono preamp to connect between the deck and the amplifier. I do not think this turntable is fitted with its own preamp - check the User Guide.
Jan 12, 2009 | Music Hall MMF-5 Turntable
Volume
Please let me know how your turntable is connected to the music system. I mean, to which input ? (Tape/Aux/Phono/VCR/CD) ?
Aug 24, 2008 | Technics SL-1200MK2 Turntable
No music
Where do you have the turntable connected? Is it going into a DJ Mixer, a Receiver, or a Power Amp?
No matter the unit, make sure you have it plugged into the PHONO INPUT connection on the rear. If your receiver/amp does not have this, then you will need a PHONO PRE-AMP - The turntable connects to the PHONO PRE-AMP, and the PRE-AMP connects to the LINE IN or AUX IN of your receiver.
If you are connected to the PHONO INPUT of your mixer/receiver/amp, then the problem might be one of the following on the turntable:
1) Tonearm
2) RCA Cables
3) Cartridge
There is no easy way to see which one of these is the culprit, it's just a matter of elimination.
But, you didn't provide much information. If you can be more specific as to how you have your turntable connected, what kind of cartridge your using, and whether or not, you've determined that the problem is indeed the turntable and not your mixer/receiver/amp, or even your speakers. This would help in determining what the issue might be.
- Davis
DJ Pro Audio
www.DJPROAUDIO.com
www.DJPROLAB.com
Jul 16, 2008 | Audio Players & Recorders
Music Hall MMF-2.1 Turntable Logo
95 people viewed this question
Top Music Hall Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Music Hall Audio Player and Recorder Expert? Answer questions, earn points and help others
