Question about Quickie Wheelchairs Quickie S-646 Power Chair - Smart Seat Tilt and Recline - Included
What is the neutral part of a quikie power wheelchair
What does 7 yellow flashing wrenches mean?
With most wheelchair electronics a 7 flash means the joystick is bad. A 7 flash means "joystick is out of neutral".
Sep 20, 2014 | Health & Beauty
I have a error code of 5
This is a right brake fault code, usually from bumping the lever that takes the motor out of gear so that the drive wheel will turn so you can push the chair. Put the lever in the full neutral position, then put back into gear to drive to see if this fixes it. If it still flashes, unplug the cable from the right motor to the controller and plug back in again, that should do it. If not, you have an issue that a technician will need to look at that is more serious.
May 02, 2014 | Invacare Pronto M51 Power Wheelchair
I HAVE STORM TDX5 CAN BE SITTING STILL AND THE CHAIR WILL TAKE OFF BY ITSELF AND GO WILD WHEN I SHUT IT OFF FINALLY IT COMES UP NEUTRAL TESTING AND WON'T GO ANYWHERE CAN YOU TELL ME IF IT IS THE JOYSTICK
Yes, it definitely sounds like a bad joystick control or a bad joystick wiring harness to the controller. Using a hand held programmer you can read the fault log to verify the number of fault codes attributed to the joystick and joystick out of neutral at start-up. Most dealers and certified technicians have the proper HHP to read the fault log and make this determination.
With the power wheelchair off you can feel a bad joystick gimbal by rotating it in circles and forward and back, feeling for rough and dead spots. If it does not come back to neutral when you release it i.e. it is off center, you have a bad gimbal. Because it sounds like a safety issue, I would recommend having this repair done before using the chair again. Hope this helps.
Jan 06, 2011 | Health & Beauty
We have a CTM HS-2800 power wheelchair that has 2 red, 2 green & 2 yellow lights that come on flash 8 times and then go off. What might be the problem when this happens?
You have a module problem:
Evaluate your batteries. 12v Single or 24 together.
Flash codes:
1. Stall Timeout, Joystic out of neutral
2. Battery Voltage too over 32VDC hi or too low under 17VDC
3. Left motor Fault
4. Right Motor Fault
5. Left Brake Motor fault
6. Right Brak Motor fault
7. Shark Control Module Faul
8. Power Module Faul
9.Shark Module Faul
Nov 24, 2010 | Ctm HS-2800 Power Wheelchair
Ctm hs 2800 turn on key light come on and blink 7 time then go out push joystick foward motors kicks in and out and lights blink 7 times and then frist red light keeps flashing
3. Left motor Fault
7. Shark Control Module Faul****this will be your problem***
9.Shark Module Faul
Contact me Direct 909-590-1388 x115 CTM HOMECARE OFFICE
Oct 31, 2010 | Ctm HS-2800 Power Wheelchair
Invacare pronto m51 moving very slow. moves free and easy when in neutral
Check that the speed control on your joystick is set to high. If it is then you probably have a battery problem. Even with all the lights lit on the joystick you can have one battery of the two on the chair that is not charging fully. This will cause the M51 to creep and not work correctly
Aug 11, 2010 | Invacare Supply Group Invacare Pronto M51...
Power good, but no motor functionality - Jazzy Select
hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked
Jul 04, 2010 | Pride Jazzy Select 6 Indoor Power...
Sudden jerks to right
Sounds like you've got one motor which is beginning to fail or your joystick gimbal is out of alignment. A bad joystick gimbal will give a joystick out of neutral fault at start-up. A weak motor will give you the sympton you describe. A bad or non-freewheeling caster will give a similar symptom.
May 14, 2010 | Invacare Pronto M51 Power Wheelchair
I have a ctm scooter the battries are charged fully when i switch on the scooter will not work switch off and on again it then will travel a few feet before stopping
The joystick will display a sequence of flash codes. Count them and find the count here: This could be several issues, But the flash code will tell you for sure.
3. Left motor Fault
9.Shark Module Faul
Mar 07, 2010 | Ctm HS-2800 Power Wheelchair
Quickie Wheelchairs Quickie S-646 Power Chair - Smart Seat Tilt and Recline - Included Logo
515 people viewed this question
Top Quickie Wheelchairs Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Quickie Wheelchairs Furniture Expert? Answer questions, earn points and help others
