Question about Spectre 2003 Buick Rendezvous - 3.4L V6 - Air Filter
Nesecito cambiar la bomba de aceite
Como cambiar bomba de aceite
Where does (light green) ground wire attach to, came loose mhen I opened top thank you
We will need to know the make and modek in order to help you.
Apr 25, 2015 | Air Purifiers
Window fogging up inside
Hot air on clod windscreen will cause the window to fog up. You have to remove the humidity ( water in the air) inside the car to stop fogging up. The answer is to run the a/con which de humidifies the air then the heater can.do the job Run both together.r it is sometimes called climate control in cars.
Mar 21, 2013 | aFe 2001 Dodge Durango - 4.7L V8 - Air...
Epson GS6000 llamada al servicio 1136
this is the carriage not releasing and thinks its a paperjam. it could be the release clip, cr motor, sensor or even the main board. I had the same problem.
first try to turn off, remove media. manually release and slid out the carriage to the middle. turn on and see it it clear the error.
Jan 15, 2013 | Epson Stylus Pro GS6000 Printer
XL-15S, NO OZONE
Hello fleamrk,
Several possiblities here. Not static sound means the plasma discharge plates aren't energized.
1) Missing, cracked or defective discharge plate (you say you cleaned the filter - did you mean the lint screen in back, or the glass or white ceramic plate inside)? No plate, no ozone (O3) production.
2) Bad connection in the high voltage leads*.
3) Bad electrical components*.
*I'm not an electrician, and recommend that only qualified personnel troubleshoot high voltage electronic, both for safety, and for preventing further damage to circuitry. Visible problems, such as corroded or broken terminals that can be swapped when it's de-energized (unplugged) is one thing; having to dig deeper into the electronics is something that I expect to rapidly end up costing more than it's worth.
Sep 29, 2008 | Ecoquest Living Air Classic Air Purifier
How to Clean The Unit
There is a screw on the bottom of the unit. When you remove it, the whole insides can be slid out. Then just blow the dust off with canned air. Wal la, you're done!
Jan 16, 2008 | Ecoquest Flair Air Purifier
Living Air Classic Emitting awful Smoke smell
Hello DWolfS,
1) Are you still looking for a solution?
2) Are you able to trace the odor (e.g. do you see any visible signs of scorching or burning, esp. with the electronics components?
3) Unless you are an electronics technician, you won't be swapping out cooked parts from a circuitboard (and if you were, you wouldn't need my advice......(;^]). If the circuitboard is bad, it's probably more trouble than it's worth to fix.
EcoQuest Int'l, manufacturer of the Living Air, no longer provides repair or refurbishment of the Classic product, but they do offer a trade-in on a newer version. If you can't locate the dealer you purchased it from to assist you, you can likely find a dealer in the LA area (Google or Yahoo keyword search "EcoQuest Dealer, Los Angeles"), or contact EcoQuest directly aT 1-800-989-2299 or customerservice@ecoquestintl.net.; I'm sure they can put you in-touch with a dealer in your area.
The company website is www.ecoquestintl.com/
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance,
Jon
Jan 15, 2008 | Ecoquest Living Air Classic Air Purifier
Spectre 2003 Buick Rendezvous - 3.4L V6 - Air Filter Logo
Top Spectre Air Purifiers Experts
 Russ Hill
Russ Hill
Bill Boyd
Lawrence Oravetz
Are you a Spectre Air Purifier Expert? Answer questions, earn points and help others
