Question about Brother MFC-9440CN Laser Printer
Brother MFC-9450CN Laser Printer fuser unit end
SOURCE: Fuser replacement on Brother MFC 8860DN
Yes I did it myself, however I am savvy with most hardware, I wouldnt suggest it for the novice. It cost around $NZ245 for the fusing unit, which from doing a quick search online is about the same in most countries.
Posted on Sep 03, 2008
SOURCE: Need info on replacing Laser & Fuser for Brother MFC 8860 DN
i have the same problem there is a phone number in the maual wich is the Brother support center 18772768437, after a few unnecesary question they will give a phone number of a company near your area that do maintenances services to copy machines, they are the one who will replace those parts, well at least that is what i think i just called them they are getting the prices, good luck.
Posted on Mar 12, 2009
  • 17 Answers
SOURCE: How to change the fuser gear in Brother MFC 8660DN Printer
I recently changed the fuser gear on my MFC-8840DN (a similar machine) and type up detailed information. The pdf file of the instructions has been posted at:
http://www.sharperminds.net/downloads/instructions_for_changing_a_fuser_gear_on_a_brother_printer.pdf
Hope you find this helpful.
Ed
Posted on Feb 25, 2010
SOURCE: brother hl-5250dn fuser unit faliure
I have 2 printers that dosn´t work. Brother HL-5250 dn One with fuser that dosn´t work. Can I take thee fuser from the other and attach it into the first one. Or do you ned spcial tools and knowldge to do it?
rolf@edeborg.se
Posted on Mar 10, 2010
  • 59 Answers
SOURCE: Problem for Brother MFC-8860DN Printer How do i
press menu 7 3 2. this will bring you into the parts reset, and reset the fuser
Posted on Mar 31, 2010
The printer says "fuser 0%"
The fuser unit is not a commercially available consumable for this printer. I would recommend contatcing a printer technicain or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother MFC-8370DN Laser Multifunction...
How do I install a fuser unit on my brother mfc-9440CN?
l.- Take the back cover off
2.- Remove two screws
3.- Remove one connector
4.- Pull the fuser unit out
5.- Replace with a new one .
Feb 14, 2011 | Brother MFC-9440CN Laser Printer
Part number brother 9840cdw fuser
Part# LU4103001
About $150
The service manual will be hard if not impossible to find. They only release those to factory authorized service centers. If you just need it for the fuser replacement instructions then often those will be either in the operators manual which is easy to find or the instructions will be in the box that the fuser comes in.
Good Luck and Thank You for using Fixya.
Apr 01, 2010 | Brother MFC-9840CDW Laser Printer
Brother mfc 9880 fax/copier makes grinding noise and has paper jams
Probably a broken Hot Roller gear in the fuser. The fuser is the section in the back, that presses the print between a pair of hot rollers to melt the powdered toner into the paper, making the image permanent. That combination of heat and pressure makes the fuser vulnerable to breakage in any laser printer or copier. The HR (hot roller) gear is a ring around one end of the heated roller, and it sometimes breaks apart.
The MFC 9880 isn't listed on Brother's US service website, so I can't tell you whether you need to buy a whole fuser assembly or just that gear.
Mar 31, 2010 | Brother MFC-8860DN All-In-One Laser...
Brother MFC-9700 Machine Error 71
71 says the fuser unit is not installed, it means the fuser lamp is burned out, or the temp. sensors are bad. In either case the best repair is a new fuser which you'll find at www.precisionroller.com
Jan 18, 2010 | Brother MFC 9700 All-In-One Laser Printer
Fuser problem with Brother MFC 9420CN laser all in one
Unplug the printer and allow it to cool.  Then gently wipe off the surface of the photo-sensitive drum with a cotton swab.  If this doesn't work you may need to replace the drum.
Nov 20, 2008 | Brother MFC-9420CN All-In-One Laser...
Replacing Brother MFC-8440 Fuser
To remove the fuser - remove the tray at the bottom and the back tray (4 screws, 2 either side) lift out the phone line box on the right (looking from the back - 2 screws) and swing it out of the way (careful as cable isn't too long) 2 screws either side of the fuser (long black object at the bottom) unplug the halogen lamp (white plug on left) and small 5 wire plug on right, and lift out fuser unit.
Aug 25, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-9440CN Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
